dual quads setup
Old March 25th, 2016, 03:25 PM
olds330's Avatar
dual quads setup
ok, getting ready to setup offie 360 dual quads... any suggestions and help
would be great.. already placed the Mallory MBI in, the carbs are edelbrock
1406...
thanks
olds330 is offline
Old March 25th, 2016, 03:53 PM
Do you have the engine to support dual 600 cfm carbs?
oldcutlass is offline
Old March 25th, 2016, 04:01 PM
olds330's Avatar
yes... flywheel numbers 596hp 535tor pretty sure it will handle two 600
olds330 is offline
Old March 25th, 2016, 04:21 PM
Most of the kits I've seen use the Thunder series AVS carbs. Do you already have your linkage setup?
Old March 25th, 2016, 05:35 PM
olds330's Avatar
yes, came as a whole unit... off a stock 67 442... ran good...
olds330 is offline
Old May 30th, 2016, 07:17 AM
SeanMiller063's Avatar
How did it go running well?
SeanMiller063 is offline
Old May 30th, 2016, 01:52 PM
olds330's Avatar
could not be happier with this setup ;-)
olds330 is offline
Old May 30th, 2016, 02:02 PM
seansolds's Avatar
When i start mine cold I keep the rpm up around 1500 until I reach 150-160 degrees, I have to do that running 92-93 octane. 100 octane no so much. I have 500's on mine for normal street use, with my cam they are useless below 3,000 rpm but good for cruising with a 4 speed. I've had to jet my primaries down a step, that fixed occasional plug fowling.. Mine runs great, plugs look recently new usually change them every 2 years.. Keep checking all your plugs to tune each bank properly, hope this helps.
Sean
seansolds is offline
Old May 30th, 2016, 02:37 PM
Any chance a guy could see a few pictures?
Old May 30th, 2016, 03:37 PM
olds330's Avatar
I'll get some pictures soon.. I am running 400E using 30 over forged flat top 350 pistons, comp cam 2-224-4 520/523 lift G heads cut 30 and ported 4 speed 3.73 12 bolt posi.... so far there is no problem running the 600's, not my choice, but the hand dealt me, I rebuilt them the forward carb is as closed on idle as it can be, rear is the primary carb, dialed them in with two vacuum gauges, so far they run far better than the carbs I have tried with the intakes I tried... forgot, I'm running gear to gear timing too
olds330 is offline
Old May 31st, 2016, 12:13 PM
Out of Line, Everytime😉
olds 307 and 403's Avatar
I am planning on running dual 625 cfm Street Demon carbs with the taller Offy dual quad on a 424 ci 403 based stroker, will be around 9.5 to 1 compression. Good part about the AVS and Street Demon carbs is the adjustable secondary air door, bound to help with over carbing the motor. Any track times with this combo?
olds 307 and 403 is offline
Ezln1688
September 13th, 2015 09:07 PM
garyr6169
December 21st, 2014 01:59 PM
Vader
February 26th, 2013 02:25 PM
Nasty455
March 15th, 2012 05:56 PM
agtw31
January 31st, 2009 06:42 AM
Quick Reply: dual quads setup
