ClassicOldsmobile.com Oldsmobile Enthusiast Community
Go Back   ClassicOldsmobile.com > Vehicle Lineup > Other Oldsmobiles
Forums Gallery Encyclopedia Tech Olds Junction Register All Albums FAQ Members List Calendar Search Today's Posts Mark Forums Read Used Cars
Other Oldsmobiles Anything not listed above, such as F-85 (1961-1963), Firenza (1982-1988), Starfire (1961-66 and 1975-80), Omega, etc.
Welcome to Classic Oldsmobile Forum!
Welcome to Classic Oldsmobile forum,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Classic Oldsmobile Forum today!
Thread Tools Display Modes
Old March 10th, 2009, 03:02 PM   #41 (permalink)
4speedBench
4speedBench's Avatar
My parents owned a '75 Omega brand new. I drove it many times as a high school kid at the time. Years later it went to my older sister for her first car upon graduating college. It racked up over 175,000 miles on the 260 V-8 before the body just gave out from rust. She lived around Buffalo NY.
It was dark brown w/ cream color vinyl top and Wire hubcaps...not a bad looking ride.
__________________
'68 442 Sport Coupe,455 4 speed(M20)& Bench
3:42 Posi. Force Air Induction Added.
4speedBench is offline   Reply With Quote
Sponsored Links
Register your account for free today or log in if already registered to remove this ad!
Old March 11th, 2009, 10:13 PM   #42 (permalink)
1973oldsomega
Quote:
Originally Posted by Oldsguy View Post
Yes you could use an electric fuel pump and block off the opening for the mechanical fuel pump. Why are you set on using the Edelbrock heads? Stock Oldsmobile heads work great and are cheaper. Unless you plan on racing and want that extra edge I guess.....Are you planning on spending a lot of money on the block too? What kind of camshaft and pistons are you going to use?
I am set on using the Edelbrock heads because they are aluminum and will give my engine more power and who dosent want more power under their hood. I have a new edelbrock performer rpm camshaft installed and i will be using some speedpro flat top pistons. I had the engine honed out and cleaned and had new freeze plugs and cam bearings installed and the engine shop the owner of the shop said that the engine was in very good condition and didnt need to be bored out unless i wanted it to be so i just had him hone it out. Another reason i am dead set on using the heads from edelbrock is the reason that they have the performer rpm cam and heads and the intake all dyno matched for peak performance. I want a nice strong running engine and one that will have the power there when i smash that gas pedal. I am looking for at least 400 hp when all is said and done. Also the headers that i will be using are the hooker super comp headers. I also had my crank polished and cleaned up and the engine shop owener said that was in very good shape also. When i took the engine aprart there was nothing wrong with it, it ran fine no knocks no leaks but i just want more power is all.
1973oldsomega is offline   Reply With Quote
Old April 4th, 2009, 07:03 PM   #43 (permalink)
1973oldsomega
Well i was going back and forth about what heads to use and i have decided to just go with the edelbrock heads. I went to the engine shop and he said it would be around 500 buck to rebuild the heads including parts and labor. So i am not going to pay that 500 now when i planned on putting aluminum heads on it later on anyways so i might as well save the money and use that 500 towards the aluminum heads. I have some pics of the engine bay im going to post. In the pics you can see that i have closed up the holes in the fire wall and have undercoated and painted.
Old April 4th, 2009, 07:11 PM   #44 (permalink)
1973oldsomega
Old April 4th, 2009, 07:13 PM   #45 (permalink)
1973oldsomega
OH yeah you can see the buckets ive installed in place of the bench seat so i could install a floor shifter i got those for 30 bucks i just need to get them recovered had to drill some new holes but everything came out good.
Old May 3rd, 2009, 04:57 PM   #46 (permalink)
angee
angee's Avatar
Well, we went to move our olds (on a tow truck) to our new house and found that the freeze-out plugs had blown over the winter...so much for garage storage... He got a late 60s 350 small block (sorry to the hard-core-keep-it-original peeps) we're going to end up dropping in it once it's built. We're going to keep the numbers matching engine on the side and I suppose we'll eventually rebuild it. He (my SO) is on the lookout for what he needs to get her running now, but I doubt she'll be ready this season. I was kinda hoping.....
__________________
Breathing new life into an old car one bolt at a time.
'73 Olds Omega
Down for rebuilding
angee is offline   Reply With Quote
Old May 17th, 2009, 10:39 PM   #47 (permalink)
1973oldsomega
Quote:
Any updates on the Omega. How is the engine swap/rebuild going?
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
74 old omega adolfshatner Other Oldsmobiles 4 May 16th, 2008 06:29 AM
omega 1973 omega73 Other 5 August 2nd, 2006 10:33 AM
1974 omega omega74 Other 3 March 7th, 2005 07:41 AM
74 Omega header issues <Brian> Small Blocks 1 September 9th, 2004 10:38 AM
HEADERS FOR OMEGA <CHRIS L.> Small Blocks 0 March 5th, 2004 04:15 PM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.0.0
All content Copyright © 2008 by Internet Brands, Inc.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
