Other Oldsmobiles Anything not listed above, such as F-85 (1961-1963), Firenza (1982-1988), Starfire (1961-66 and 1975-80), Omega, etc.
1962 Starfire Master Cyl/Booster Update Question
Old March 23rd, 2017, 10:13 AM
hurstoldz's Avatar
Question 1962 Starfire Master Cyl/Booster Update Question
Good afternoon everyone...
I am in process of updating my Starfire to a dual reservoir master cylinder and power brake booster from a 1966 Cadillac...
The original set up has the booster with a vacuum T that goes to a reserve vacuum tank. This operates with a check valve within the line so the vacuum does not bleed out of the tank.
The question I have is this...can I just eliminate that tank? Or do I need to add a plastic vacuum T, and if so, do I need to add a second check valve?
Any assistance will be greatly appreciated... I would like to know before I do any of the work.
Thanks!
Vinny
hurstoldz is offline
Old March 23rd, 2017, 01:37 PM
Don R.'s Avatar
It's nice to have the reserve tank since it gives you a couple of assisted stops if your motor should die, but its not absolutely necessary. If you have one in your car now test it with a Mityvac. If it holds vacuum its probably worth hooking it to your new booster with a tee fitting. You don't need a second check valve.
Don R. is offline
Old March 23rd, 2017, 01:40 PM
hurstoldz's Avatar
Thank you Doug... do you know anyone who has attempted this type of upgrade?
I appreciate your help!
Old March 23rd, 2017, 01:51 PM
Don R.'s Avatar
No I don't. I thought about a dual master but wound up buying a new single pot and getting my booster rebuilt.
Don R. is offline
Old March 23rd, 2017, 01:55 PM
hurstoldz's Avatar
Ok... thank you sir.
Old March 23rd, 2017, 07:13 PM
hurstoldz's Avatar
http://www.jalopyjournal.com/forum/t...ersion.978671/
geoff442
February 15th, 2016 02:53 PM
rspreen1
July 4th, 2015 01:13 PM
jag1886
Brakes/Hydraulic Systems
April 19th, 2011 11:49 PM
68conv455
January 12th, 2010 03:39 AM
aastm15
July 11th, 2008 06:09 AM
Quick Reply: 1962 Starfire Master Cyl/Booster Update Question
