View Full Version : Transmission
Pages : 1 [2]
  1. Engine Chuggles when stopping
  2. Did I screw up my TH350?
  3. What Trans.
  4. Need Help With Trans Filter
  5. Adapters
  6. oldsmobile 2 speed powerglide rebuild
  7. trans help please!
  8. Jetaway dipstick help
  9. Is the TH 350 working properly
  10. 4l60E behind my toro engine
  11. Drivetrain options
  12. Late Shifting Problems
  13. Gearvendors fitment
  14. TCS question
  15. Kickdown cabel bolt size?
  16. Flexible trans cooler lines
  17. Coulmn shift to floor shift
  18. 200-4R shift kit question
  19. tried under search
  20. would this match up with my 455
  21. Rocket
  22. 1955 Olds Hydra, options? other year autos swaps??
  23. Tip of the day
  24. th350 kickdown cable
  25. olds vs chevy
  26. Trans rebuild
  27. will a 455 blot up to a 350 trans
  28. crossmembers
  29. powerglide?
  30. Electronic Shift Transmission
  31. Rebuilding a 1955 Hydramatic
  32. TH350 removal advice...asap
  33. TH400 GTO to Cutlass question
  34. TH350 identity
  35. t56 durability
  36. Switch Pitch converter
  37. tranny mounts
  38. Dual gate issue
  39. Converting from TH400 to 700R4
  40. troubles w/my 1964 hydramatic
  41. th350 upgrade
  42. TH400 Leaking Fluid
  43. 200 4r upgrade kit
  44. Kickdown Cable??
  45. 1961 slim jim rebuilder
  46. help!i dont want to rebuild!maybe quick fix?
  47. more help!pans off,now what?A.T.roto-5
  48. Kick Down Cable?
  49. Proper Rigging
  50. Pain in the Ass problem that confuses me
  51. Drive train clunk
  52. 4 speed shifter question
  53. t-5 swap
  54. T-5 swap
  55. transmission proplem
  56. 1966 M/T Shifter boot Where to buy?
  57. fitting leak
  58. looking for an extension housing,roto-hydramatic 5,'63Cutlass
  59. Turbo 400 rebuild help
  60. Hydramatic Transmission Disaster
  61. After-market floor shifter/factory console??
  62. Neutral Safety Switch -67 floor shift
  63. TH400? Kickdown? 67-442
  64. tranny cooler
  65. Fluid capacity
  66. Does anyone 'rebuild' kickdown switch?
  67. What tranny is this
  68. THM375 info and opinions wanted
  69. Swapping a ST300 for a th400
  70. 69 442 with T-10 Trans
  71. 1971 transmission 350
  72. 80s deltaa trans swap.
  73. Dual Gate to 200R4
  74. dimensions of slim jim?
  75. 4spd interchange
  76. another slim jim thread woo hooooo
  77. TH 200 4R TRANNY SWAP HELP!!!
  78. Information for installing a Dual Gate
  79. 86 cutlass
  80. Dual Gate conversion to 4 speed trans
  81. st-300
  82. Problem using old torque convertor?
  83. turbo 400 i.d. tags
  84. 700R4 in '62 Starfire
  85. 700R4 in '62 Starfire
  86. TH400 for dummies please
  87. What cars carry a thm350 with a 6 inch tailshaft?
  88. tranny swap and rear end ratio
  89. Transmission Cooler Routing
  90. Jetaway worth?
  91. 65 F-85 floor shifter. What year will work
  92. Torque converter opinions needed
  93. TH400 For the 394
  94. Installing my Kilduff ratchet shifter
  95. How to remove hurst shifter handle (66 manual tranny)
  96. 700r4 in a 71 convertible supreme
  97. 66 cutlass won't shift
  98. Hurst duel gate shifter question.
  99. trying to identify a TH400.
  100. 200-4R transmission troubles.
  101. change speedo gear? TH400, much trouble?
  102. Pivot ball on 455 FA block
  103. Flywheel Inspection Cover TH350
  104. T-56 6-speed will it bolt up??
  105. want to buy Turbo 350 or Turbo 400
  106. Just got a couple 200-4r's
  107. Question for a 65 cutlass f85 transmission
  108. what is the location of vaccum modulator valve?
  109. transmission Question
  110. Mounting an transmission cooler
  111. How do I remove the front seal on a TH350?
  112. trans making whining noise ?
  113. noise from th350 trans ?
  114. Torque converter
  115. transmission leak
  116. Can I Rebuild a My Transmission
  117. speedometer housing
  118. Same Tranny's?
  119. Mystery Turbo 400?
  120. transmission fluid capacity
  121. muncie number's
  122. 200-4R and 455
  123. 200r4 question
  124. 69 cutlass clutch and shifter issue
  125. TH400-How many leak points do I need to check?
  126. New member with a '64 Jetaway problem
  127. 64 Cutlass No Low Gear Help!
  128. '52?? Hydramatic question
  129. HELP! on a 1976 TH400
  130. Rear Transmission Seal
  131. having issuses with trans
  132. what tranneys fit a 1964 Dinamic 88 convertable with a 394?
  133. B&M TH350 separator plate
  134. 61 Slim Jim in and out lines
  135. 400 turbo tranny ?????
  136. Seal at speedo cable input on TH400?
  137. Pics request
  138. Thanks / Transmission pan leak
  139. 400 / 455 Flexplate same????
  140. Transmission Oil Change - Newbie
  141. Transmissioin coolant lines
  142. Ideas where to get a 4 speed
  143. 1955 - 88, How Difficult is it to remove speedometer?
  144. stock torgue converter
  145. what are my tranny options mating to my 394
  146. Tranny shifting problem
  147. Part name and part number
  148. 2speed wont shift out of the blue
  149. Turbo 400 trans from a 73 delta 88...
  150. TV Cable Adjustment
  151. no kickdown on 400
  152. 75 Turbo 400 in 65 Jetstar 1
  153. 200-4Rtransmission case paint
  154. Trans Problem... help!
  155. Half-moon shifter linkage
  156. shiftworks kit or aftermarket shifter in 64-66 auto console
  157. where does the filler/dipstick tube usually locate on 67 TH400?
  158. Aut transmission issues
  159. 2 flywheels-which one 62 Cutlass 215v8
  160. vacuumm hoses
  161. 61 transmission
  162. TH400 pump seal size????
  163. whats the difference in these th400's???
  164. th350 question
  165. PATC Products
  166. 700r4 coversion into 64 Starfire with 394... PICS!
  167. Slim Jim Parts
  168. Auto to Manual Conversion Parts
  169. stall converter question???
  170. 200r4 or th700 in cutlass
  171. Th400 Long Shaft
  172. 57 auto transmission
  173. shift cable to shift select shaft question
  174. 1956 Olds Jetaway slips in reverse only
  175. 350 turbo stall converter question???
  176. TH400 Serial Number Plate
  177. shiftworks cable
  178. Jetaway to TH350
  179. switch pitch conversion
  180. Torque Converter Leaking
  181. Anybody use the summit transmissions?
  182. Do I Need a New Torque/Stall Converter??
  183. TREMEC 5 speed
  184. kick down cable clip
  185. Help! Another Trans Question...
  186. 41 olds transmission
  187. 62 F-85-need to know what trans?
  188. 60 olds with 72 455 help with back up switch
  189. 2spd jetway trans- switch pitch questions...
  190. turbo 350
  191. TH 350 OR TH400
  192. What part number and how to replace
  193. sp th400 problems
  194. 2004r dust shield hardware size
  195. 2001 OLDS AURORA trans
  196. I need opinions and/or feedback
  197. 2 speed jetaway pitch/switch adjustment
  198. Opinions on this 200-4r
  199. do I need a trans cooler?
  200. My New TH400 Compared To Slim Jim
  201. 4L60-E, 4L65-E Oldsmobile Bellhousing
  202. HELP, with going into passing gear ?
  203. th425 OM w/factory stall conv
  204. 455 flywheel part number?
  205. odorless smoke
