View Full Version : Small Blocks
Pages : [1] 2 3 4
  1. Redline on '64 330
  2. 307/350
  3. OIL PRESSURE
  4. Hooker Headers
  5. 303.7 3/4 race cam
  6. joaquin
  7. What Motor Do I Have (Help)!!!
  8. intake clearance
  9. headers
  10. small block to big block455
  11. exhaust bolt with stud
  12. Vacuum Hose help???
  13. Somebody can help me?
  14. found short block
  15. found short block cond.
  16. Super 88 -59
  17. to much air in my fuel line
  18. HEADERS FOR OMEGA
  19. 1978 Omega NEED INFORMATION?
  20. Help ?
  21. rebuilding motor question
  22. Headers for '67 SB
  23. Engine color
  24. heater core installation
  25. my car
  26. seat options for a 78 cutlass supreme
  27. rear diffriintal convertion to posi
  28. headers for 72 cutlass supreme
  29. 350 Rocket Engine Temp
  30. 1977 Olds 350 with Rochester 4bbl - car dies after first start...
  31. Location of engine Identification Numbers
  32. 74 Omega header issues
  33. 84 - 307 locating water and oil pressure lines o
  34. Newbee here , saying hello
  35. headers
  36. 66 cutlass engine swap
  37. 77 98 regency needs help
  38. Engine swap...
  39. 77 olds omega heater core
  40. Should I swap
  41. More from my 350
  42. Headers
  43. A/C
  44. Valve/head specs
  45. Carb swap and vacuum problem
  46. Larger cam (or not)
  47. Stock HP rating for 77 olds 98
  48. Oil slinger
  49. 350 rocket Question
  50. Barrett-Jackson 55 Olds
  51. Positraction
  52. NEW TO FORUM
  53. more power out of a 307
  54. Whats my motor?
  55. would i be better off
  56. chevy powered olds!!!!!
  57. 1977 98 - cold starts fine then dies completely!
  58. restore or soup up
  59. Air cleaner 1955 olds
  60. engine identification
  61. 71 choke tubes
  62. newbie 66 f85 what engines fit?
  63. will a small block swap out with a v-6
  64. Diagnosis Needed - Oldsmobile Fouling Out
  65. 350 rocket
  66. New and Confused
  67. Engine Identification Please
  68. motor
  69. Torque Converter 69 w31 conv
  70. '86 307 vacuum & air hose problems
  71. camshaft
  72. replacement oil filter
  73. replacement oil filter
  74. HELP!! Need hot air choke tube...
  75. 330 to 350 overbore?
  76. timing chain
  77. 350rocket hp/torque?
  78. Type of Engine for my 85 Cutty for Sound
  79. Why when i give it gas it feels like i have to push it through the floor pan to go
  80. 350 305 carb question
  81. The car is an 88 cutlass
  82. Cam question
  83. 1966 400 oil pressure ?
  84. Engine trouble
  85. new owner of a '53 98 - with questions
  86. 57 Olds vacuum line question
  87. hey guy a little help on casting numbers.
  88. if the 350 comes off a convertible
  89. ol4b carb recommendations
  90. Valve Covers That Clear A/C Brackets
  91. carburator calibration
  92. engine block number....need help....decode it for me please....
  93. 1978 intake manifold
  94. 71cutlass s hp & tq figures
  95. Buddy Bar Intake Manifold for Olds
  96. need some oldsmobile 350 info
  97. my 68 has some secrets....
  98. OLDSMOBILE 350 hp?
  99. w-30 heads spotted
  100. Edelbrock valve covers?
  101. 1985 Cutlass Supreme 307 hesitation
  102. 70 olds 442 cutlas firing order
  103. Headers Spoiler Stripes
  104. Carb rebuild?
  105. noob questions!
  106. whats the best small block for my car?
  107. 1967 F-85 330 cam and hop up HELP Please
  108. any beefing to my 307?
  109. 1987 307 problem...need help...
  110. 86 cutlass wont start
  111. Acceleration Issues.
  112. HELP with engine color '63 394 2bbl
  113. 1979 Olds/Chevy Exhaust Manifold Interchange
  114. slow start
  115. recommendations for my #5 heads...
  116. 86 cutlass carburator
  117. Heater Core Woes
  118. 307 with bad crank
  119. rocket 350 build
  120. Rebuilt Olds 350 wont run...help
  121. primary metering rods Q-jet 4MC
  122. help please
  123. 350 Vin R in a 77 "98" Regency
  124. What's the difference?
  125. olds 5.7 L diesel
  126. 87 307 woes
  127. 307 coolant loss?
  128. chevy
  129. 307 Intake
  130. Bogs Out
  131. Engine cereal #
  132. New guy needs help
  133. 1985 Toronado 307 MAP sensor vacuum line
  134. Questions about 69 rocket
  135. need help with crank bearings for rocket 350
  136. Ported Vacuum Switch?
  137. What a difference a week makes...
  138. 1968 Olds Cutlass motor swap
  139. Electric fan Help
  140. Engine/heads?
  141. 350 questions
  142. lean adjustment stop
  143. Maybe a stupid question
  144. build up 350?
  145. engine & engine compartment colors
  146. high volume oil pump
  147. Need help with identifying my Olds Rocket V8:
  148. left or right heads
  149. fuel filter
  150. Engine rebuild
  151. What Is This Thing on the firewall?
  152. 72 350 rebuild
  153. 350
  154. oil light on 307
  155. engine rebuild
  156. Air Cleaner Color
  157. engine quesions
  158. more questions
  159. Pulleys on a 350
  160. how much
  161. Mini Starters, opinions
  162. olds 350 tri-power???
  163. lead alternitive
  164. 72 Cutlass with an oil problem
  165. Ch#vy coolent loss
  166. What to replace?????
  167. Carb questions
  168. 69 Cutlass 350
  169. New toy, have questions
  170. Bog...arghhhhhhhh!!!
  171. Water pump bearing stress
  172. 1966 330ci tuning question
  173. Exhaust Question: Flowmaster? Magnaflow?
  174. overhauling my 394
  175. Rhoads Lifters
  176. Water pump prices
  177. What is this??
  178. Divorced choke with Edelbrock intake
  179. For any one intrested
  180. Piston needed 350 1970 Cutlass
  181. Engine Upgrades
  182. 260 2bbl
  183. 350 Rocket horsepower
  184. Distributor Question
  185. 85 cutlass 307 to 350 swap
  186. Oldsmobile Engine Parts?
  187. Squeeling 307
  188. Header Question
  189. smokin!?
  190. engine question
  191. 1970 350 rocket divider plate
  192. vacuum lines
  193. Newbee and a question on total timing.
  194. Olds 330 advice needed...HELP!
  195. Hi I'm new!
  196. 1987 307 to 350 swap..350 buildup...
  197. Mondello JM 18-20 or JM 20-22???
  198. 350 rebuild
  199. Oil Pressure
  200. Timing Chain Help!
  201. 350 motor & trans for sale
  202. My 260v8 is knocking is it a rod or is it lifters?
  203. My S/B Olds "test Mule"
  204. Help please
  205. engine trouble
  206. 1984 307 overheat
  207. dtvs
  208. 350 Gold Rocket
  209. new lifters
  210. Ram ROD 350 specs?
  211. 89 cutlass cierra wont start (help)
  212. best carb?????
  213. power steering belt
  214. best carb for 69 350-Please help
  215. Computer controlled 307
  216. New problem old engine! ?you think?.
  217. 394 balancer pulley
  218. Engine and transmission swap
  219. rebuild to original, or go aftermarket?
  220. Any Info please!!!
  221. Head interchange
  222. Headders for a conv
  223. 330 cid question
  224. 303 to 350? advice
  225. Mani 4 '75 olds rocket 350?
  226. 69 Supreme wont start
  227. fan clutch
  228. difficulty to put a sbc in a 1970 cutlass?
  229. What is it for and can it be blocked off????
  230. Lady Skye
  231. Help my baby died
  232. Q-Jet for '71 350 auto
  233. 307 in a 84 cutlass
  234. Too Funny
  235. will it fit?
  236. W31 or not?
  237. Small block headers.
  238. What does this # mean?
  239. good aftermarket carb?
  240. opinions on best SBO heads?
  241. 53' 303 engine color???
  242. Help! Oil Pressure Sending Unit Hole
  243. tightening carburetor bolts
  244. milling my heads
  245. Pan Gasket Problem
  246. Got it
  247. 455 vs 454 pro's and con's of both no flaming plz
  248. mismatched exhaust manifolds?
  249. best bang 4 buck; 350 or 455?
  250. Oh Well,
