View Full Version : Small Blocks
Pages : 1 2 3 [4] 5
  1. Lets start over
  2. Hooker problems
  3. Priming the oil pump
  4. 307/350 swap, vacuum nightmare!! (77' rocket)
  5. Ram Air Hood...vendor problems!
  6. I found my problem
  7. more power for my 403 smallblock
  8. more power for my 403 smallblock
  9. 350 doesn't like wide open throttle
  10. Aftermarket intake for the 215
  11. Fresh Paint...Wadda Ya think?!
  12. 64 olds cutlass f85 body mounts
  13. 350 Rocket?
  14. rochester carb info help
  15. Dnyo run today
  16. olds 350 rocket heads
  17. Intake swap
  18. Cold Air Intake
  19. 350 Diesel to 440 kit on ebay, Cheap!
  20. Can't find piston for 350
  21. Lag Question
  22. Exhaust question
  23. Rocket to SBC swap
  24. A Few 350 Questions
  25. Air fuel problems
  26. Know where to find a rubber bump stop kit?
  27. 75 OLDS 350 CR
  28. HYD lifter pre load
  29. gear drive's good or bad
  30. refreshed 350
  31. Carb Question
  32. Timing for a 77 350
  33. Enginenumber
  34. lower radiator hose on 330ci
  35. Cam 180 out?
  36. Damer bolt..
  37. Suddenly Rich (a little O/T)
  38. Max Valve Spring on stock springs
  39. Head Gaskets Olds 260 4,3 V8
  40. 71 Cutlass supreme Headers
  41. i have a stock 1972 350 with # 7 heads
  42. POR 15 engine paint
  43. Ported Vacuum Switch
  44. Aurora engine swap
  45. 2 core or 3 core?
  46. olds 8.5 rearend question
  47. performer rpm intake on # 7 heads
  48. Alternator Bracket
  49. I could use some carburetor ideas.
  50. TEAR DROP VALVE GUIDES
  51. Grrrr My new dilema
  52. 350 SB Heads
  53. OIL Pump
  54. Pulleys for a 350
  55. The '69 dual snorkel breather...
  56. Need to find out what kind of motor this is in my cutlass
  57. Having trouble with intake...
  58. Holley carb question
  59. What size is my carb?
  60. heater delete
  61. bolt size?
  62. 350 rebuild
  63. Electric choke
  64. Olds 350 Refresh
  65. Headers
  66. 750 cfm Holley carb question
  67. Timing indicator question
  68. Timing Marks
  69. vacume line routing
  70. headers
  71. need help
  72. Small block and I mean really small
  73. Distributor HEI conversion
  74. Should I keep the 307 or uprgrade to 350
  75. 307 or 350 ?
  76. Dipstick removal
  77. 350 motor mounts
  78. Small Block Identification help
  79. Engine decoding?
  80. oil pressure? in the 85 olds
  81. Engine ID help
  82. Rebuilding the 350!
  83. 350 vacuum issues
  84. 371 bore
  85. Felpro Head Gaskets
  86. 1956 324ci oil capacity and fuel pump ?
  87. 56 Olds 88 324ci timing chain question
  88. Mystery block
  89. sonic check
  90. running a mechanical advance distributor
  91. Moisture out the tailpipes?
  92. my olds 350
  93. VACUUM ADVANCE
  94. Exhaust clamps
  95. '66 Cutlass 330 Build Advice
  96. Quick Question
  97. Where can I find Head Bolts?
  98. w/z exhaust manifolds on small block
  99. crankcase pressure
  100. Slight knock noise what could it be?
  101. Engine ID help please!!!!!!
  102. 403 Heads on a 350?
  103. 66 330 engine compression ratio
  104. Olds 330 ci VS. Chev 350 ci??
  105. Valve Pan Covers
  106. timing for a w-31 350 motor
  107. Backfire through intake??
  108. Starting my '72 Cutlass project
  109. Cam and lifter suggestions
  110. Looking for information on 76 350 motor?
  111. fixing a cast block?
  112. I need a new distributor!!
  113. Rear Main Seal/Lower End Bearings
  114. new here--looking for help with a 215
  115. What Carb for 65 330ci?
  116. knocking sound on passenger side
  117. no oil coming thru push rods
  118. What vacume advance springs should i use?
  119. Head Question
  120. 350 Machining
  121. Engine Identification
  122. Rebuild 330 or 350??
  123. average cost
  124. Edelbrock Carburetor
  125. Couple questions
  126. torque converter?
  127. 200r4 tc
  128. My pistons
  129. Identifying my olds 350
  130. 330 heads on 350 block
  131. Correct Vacuum Hoses on 72 Cutlass
  132. 307 to 403 swap?
  133. rough idle olds 350
  134. 403 motor mounts
  135. Does this sound right?
  136. Exhaust Manifold Gaskets
  137. How to raise the oil pressure
  138. 71 olds 350 rocket rebuild
  139. Max valve spring lift on small block heads
  140. compression help
  141. more horsepower on my 403cui engine
  142. 1956 350/LT1/LS1/LS6 engine swap
  143. Rocket 350 supercharger/ blower kit?
  144. 74 Rocket 350 Upgrade questions
  145. 1972 350 Rod Bearing Question
  146. HEI wiring up for older olds
  147. issue with Factory Olds Hi-Performance Manifold
  148. 72 350 rocket
  149. 1971 oldsmobile cutlass with a 307 engine trying to find the year the engine was made
  150. 330 cam recomendation
  151. Head locating pins
  152. #5 heads
  153. GENERAL PERFORMANCE QUESTIONS
  154. Carb Problems
  155. Damn thing won't shut off
  156. Fan Shroud
  157. edelbrock or holley?
  158. Olds Rocket help needed
  159. 303/324 heads
  160. Help I.D. Motor-if you can
  161. fuel pump question
  162. Is it ok to run without a thermostat?
  163. Head ?'s and other ?'s
  164. Need Engine Compartment Decal Help
  165. Could I?
  166. General question
  167. Why do Olds engine not always like aluminum intakes?
  168. light ticking sound
  169. Intake Manifold Question
  170. 76 350 rocket
  171. Is this cam any good?
  172. Fuel Delivery?
  173. Knock / detonation upon acceleration ONLY when motor is hot.
  174. Tuning a Rochester 4GC
  175. Rebuilding and up grading my 350 rocket.
  176. 425 cube small block
  177. This will be my olds 350 setup
  178. Have 350 chevy in my 69 cutlass, any experience with this out there?
  179. The Ol'girl still has the stuff!
  180. Boring after bored?
  181. radiator & heater hoses
  182. Olds engines
  183. removing the gasket
  184. Any preferred gasket?
  185. new guy need help
  186. Transmission/ radiator problem
  187. Engine rebuild question
  188. Question
  189. Oil Sending Unit
  190. Tune up/points
  191. Vacuum question
  192. 307..blue smoke!
  193. Time for a tune up...
  194. Exhaust help
  195. Loosing Prime
  196. Advice on 350 heads
  197. felpro head gaskets
  198. my olds 403cui donīt run good after tune
  199. Newb ? RE: Head ID
  200. 330 to 350 swap NEED ADVICE.
  201. break in of rebuilt eng
  202. '69 350 advice
  203. Post Tune Up Issues
  204. Oil filter Recommendation
  205. 324 / 371 help. Blow by question
  206. Cam break in question....
  207. Pusher puller?
  208. Newb with a '77 Cutlass Supreme Brougham
  209. 350 help
  210. 403 valve covers?
  211. Exhaust too raspy
  212. Dual Exhaust?
  213. Cam Installation
  214. Rebuilding 5 heads
  215. How to store an engine
  216. Quad 4 question
  217. Looking for a fan shroud for 1970 442
  218. Which 330 engine
  219. 330 question
  220. Hardened seats or not?
  221. New Header Questions
  222. Water Pump Question
  223. SBO/BBO Valve covers
  224. 350 Rocket not running good after oil change
  225. 330 Fuel pump... Same as a 350/400/455?
  226. Really hot exhaust gas
  227. We need help!!! and lots of it.
  228. Carb Question
  229. Which Pertronix?
  230. 69 cutlass 350 tune-up
  231. 12" electric fan replacing clutch fan
  232. Header Gaskets
  233. Engine ID ???
  234. Need Your Input - Motor Build
  235. 455 build need help.
  236. EGR block off
  237. headers
  238. strange problem
  239. Just bought a 1964 330 HC
  240. Original 350R
  241. Best 4bbl intake to convert to EFI
  242. Scored a 330 Olds
  243. Lifter question
  244. 69 quadrajet question
  245. plug gap and timing
  246. O2 Sensor on 307
  247. Timing Advice
  248. 350 gold engine
  249. Need a part# for a carb rebuild kit
  250. 72 350
