View Full Version : Eighty-Eight
Pages : 1 2 [3]
  1. Tire Pressure
  2. #8 Heads ?'s Porting rebuilding?'s
  3. New member/62 Olds
  4. 324 part numbers/interchangability.
  5. 64 3 speed
  6. 1978 delta 88 royal parts
  7. 85 Delta 88 Hoses Questions
  8. 1984 Olds 88 Cruise Control Switch wiring
  9. 64 dynamic 88 4dr frame
  10. Wire colors for '55 88 brake and turn out of column.
  11. Time To Barter People !!!...
  12. I never thought an Olds would look bad
  13. Help please
  14. Motor Overhaul
  15. Purty lookin ol girl
  16. 1958 olds 2 door hardtop with J2
  17. Value of a '49 Rocket 88 2dr hardtop
  18. 64 olds dynamic 4 door parts for sale
  19. Olds 98
  20. Merry Christmas
  21. 65 66 67 OLDSMOBILE F85 CUTLASS 88 REMAN 2BBL CARB
  22. Tri-5 Olds parts interchange
  23. Body Tag decoder
  24. citcapp's 57 Oldsmobile with 455
  25. 1951 oldsmobile 88 deluxe
  26. Check out the 56 Olds 88 Hood Rocket
  27. Ready to scream!
  28. Help restoring my 74 Olds 88 Convertible
  29. 50-56 manual trans
  30. 75 delta 88 conv(floors)
  31. Any Hudson Hornet / Olds 88 Racing Pic's
  32. 394 fuel pump
  33. ebay car for sale
  34. Newbie lookin for info
  35. Info on a '79 Holiday 88
  36. 1985 delta 88 front license bracket?
  37. Carburetor Replacement
  38. Any pictures of a 2 door 1977 Delta 88????
  39. #8 Heads Are Done Take a Look
  40. New garage ideas...
  41. 57 /58 371
  42. 1985 Delta 88 LS for sale
  43. 1964 Jetstar 88 Holiday
  44. 1961 88 what fits
  45. New guy, old car....
  46. 1965 Delta 88, second owner
  47. a sad end to a 73 delta 88 two door hardtop
  48. Delmont 88 Interior
  49. Help! 1960 Olds 98 Hood Hinges
  50. 1966 Delta/Dynamic/Starfire
  51. 1968 Delmont 88 convertible
  52. newb-69 Delta 88 Convertible
  53. 1972 olds delta 88
  54. 60
  55. 74 Olds Delta 88 trunk pan
  56. New member - My intro
  57. parts
  58. Pictures of a Canadian Delta 88
  59. What am I doing wrong?
  60. Camshaft Specs/grinds etc.
  61. Need 1955 "88" help
  62. 77 Delta Indy @ Barrett Jackson
  63. from alfa to olds
  64. 83 delta 88 diesel hood.
  65. 68 Delmont convertible value?
  66. New to the Olds, new to the site...
  67. power
  68. My 56 Olds 88 pictures
  69. brake booster?????
  70. Disc Brake Kit ?
  71. Frozen heat rizer?
  72. My '63 Dymainic
  73. 1963 Dynamic 88 Fiesta Wagon
  74. 1962 Oldsmobile Starfire
  75. Just Joined here
  76. 85 Delta engine swap
  77. Shocks on a '54 Olds
  78. Wheels for a 66 Dynamic ?
  79. 394 rocket drive train Q?
  80. 1962 Super 88
  81. another new guy
  82. 1967 Delta 88 question
  83. 1966 Delta 88 Convertible
  84. 80 holiday 88
  85. 1974 Oldsmobile Delta 88 Royal 4-Door Sedan Looking for parts.
  86. Newcomer here
  87. 55 rear wheel bearing No. wanted.
  88. 88olds lss
  89. Hi
  90. Oil on the Air Filter...
  91. '49 88 Floor Pans
  92. My 88 Project Update
  93. 1970 delta 88 455 convertable 0-60
  94. 1970 delta 88 top lift hydraulics
  95. what to look for while buying 1970 delta 88 convet.
  96. BRAKE BOOSTER FOR 64 SUPER 88
  97. 324-371 motor mounts and 54-56 trans mounts
  98. 1983 Oldsmobile Delta 88 Royale and the 442
  99. 1968 Delmont 455 Vacuum Lines
  100. 1955 olds on the road.
  101. Rear End Interchange 1971 to 1969
  102. wheels and tires sizes 71-76
  103. rear strut mounts, monroes
  104. New olds owner
  105. MY 1965 Delta 88 Hardtop
  106. Hi all, from Atlanta....
  107. '58 EightyEight paint...
  108. '58 EightyEight Trans Question
  109. 66 dynamic 88
  110. 70 delta 88
  111. Just bought a show condition 64 starfire
  112. 1977 Delta 88 pace car Everyone with one please look
  113. 1982-85 Delta 88 Rear Coil Springs
  114. parts wanted
  115. '64 Jetstar suspension/brakes/cooling??
  116. 70 delta 88
  117. replacing the heater core...
  118. First post....
  119. Differential swap
  120. Structural integrity
  121. Joe, Newbie really needs your help with Starfire
  122. original wheels
  123. 1974 Delta 88 Convert
  124. That kid from Mich w/ the 77 pacecar
  125. New member: D88 (the lowrider)
  126. '66 Olds Delta 88 Interior Available?
  127. True duals on an '84 Delta 88? Believe it!
  128. Fit question 50 Olds Beltline molding
  129. '65 Dynamic 88 holiday hardtop protecto plate
  130. Is this your '65 Olds missing Protecto Plates??
  131. is it possible to add a turbo or supercharger to a 307 small block
  132. my 84 delta 88 needs a new transimission need help
  133. roof splitting!!!!
  134. Pics of my 67 Delta 88
  135. 75 Delta 88
  136. order sheet pace car
  137. 73 Delta radiator
  138. Eighty Eight LSS
  139. Dexcool
  140. Good evening Olds lovers
  141. Parts for 1978 Olds Delta 88 Royale
  142. new n needs help
  143. Hi from Chicago!
  144. I,m Back Again :-)
  145. NEED PARTS FOR 1970 DELTA 88 and info
  146. Build Sheet located!
  147. headers for my 60 wagon
  148. workshop manual
  149. Cowl Vent Drains
  150. Ignition question on 78 Delta (350R)
  151. New guy with Super 88
  152. 1978 Delta 88 Royal
  153. i need parts
  154. Newbie with a 64 Jetstar 88 in CT
  155. Chugging uphill
  156. WTB Floor mats
  157. 64 Jetfire Exhaust options
  158. WTB pass. side steering knuckle- '78 88
  159. 54 Super 88 Convertible
  160. 54 Olds convertible
  161. need help
  162. lousdelta88royale pics
  163. New guy with a 67 delta 88 convertable
  164. Newbie needs some help!!!
  165. bosch or ACdelco oxygen sensors for a 84 delta 88 need help
  166. Question about 54 super 88
  167. 1973 Delta 88 a chance..
  168. disc brakes update
  169. 1955 88 IS ALIVE WHA HOOO!
  170. 1968 Olds Delta 88 4 Door $600
  171. new pics of 70 delta 88 "Charlotte"
  172. 55 Olds Super 88 Matching Numbers on Body Parts???
  173. another german
  174. 67 delmont 88
  175. Correct Oil Filter for Original Set Up?
  176. 1967 Delta 88 convertible
  177. A/C Questions
  178. decode body and trim plate
  179. Transmission Pan Gasket 1955 88
  180. 1871 detla 88
  181. 1966 Oldsmobile Delta 88 (Target Red)
  182. '63 Dynamic 4door
  183. I love chrome, but...
  184. '66 Dynamic, should I?
  185. how do I take this apart
  186. '64 88 2door
  187. 1983 Olds Delta 88 Royale Brougham Tranny
  188. 1970 delta 88 wheel size
  189. My 1980 Olds Delta 88 Royale
  190. Holy gas tank, Batman!
  191. boot parts? for replacmenttop
  192. headlight switch removal
  193. 51 88 deluxe
  194. front shock absorber removal -- how?
  195. 307
  196. 600 CFM Four Barrel for a 307
  197. A few questions about converting 2bll to 4bll
  198. 1955 diff locating pin size required and U bolt diameter.
  199. Delta 88 emblems
  200. 1965 Delta 88, Jetstar 1, and Starfire found in yard
  201. 1962 Super 88 4 Door
  202. 73 Delta 88 frame interchange?
  203. PLEASE HELP/73 DELTA 88 ROYALE PARTS
  204. my front spring are broken
  205. DELTA 88 Details
  206. novice again needs help - gas tank
  207. Directional Switch
  208. What wheels would you put on?
  209. LH Muffler Hanger
  210. PICS 71 DELTA 88 ROYALE
  211. new member with a 65 delta 88
  212. 1960 88 2 door hardtop
  213. 1969 Olds 88 what other makes spindles fit?
  214. Headers ?
  215. ONE LONELY PART
  216. Gen Light coming on...
  217. ... transmission question
  218. Turn signal actuator
  219. 1964 DYNAMIC 88 ****CARB QUESTION****
  220. 84 olds parts question
  221. Introduction & pics of my 64 Jetstar 88
  222. Template O L D S M O B I L E Letters
  223. Roller rocker questions
  224. '66 Delta 88 Weight?
  225. part # location on fuel pump
  226. '57 88 roof rail?
  227. '71 88 power brake booster
  228. 57 Olds fiesta rear bumper
  229. Difference: 88 - Super 88 1957
  230. 55 Olds parts wanted
  231. THAR SHE BLOWS!
  232. Deloris(82 Delta 88)
