- 1959 olds 98 headliner parts
- WTB - '85 442 Grille
- Radio Knobs
- need some more parts
- interior pieces
- '39 Steering Knuckle Support
- 1955 speedo wanted.
- performer 350 intake wanted
- ignition switch bezel for 66 cutlass
- '68 Delmont Ragtop frame
- 70 delta 88
- 303/324 Intake & ditributor needed
- Hood crossmember and hinges 4 '50 88
- interior
- New guy needs 1967 442 RT rear quarter molding.
- 350 Block
- choke for 67 Qjet
- 1970 OAI hood
- Still looking for 324 or 303 manifold...
- parts wanted for 1970 delta 88
- '71 442 Bumper Jack Base
- 1971 Olds 88/98, 60/40 seat
- 66 Toronado Hub Assembly
- Fan shround '73 Cutlass.
- STONE SHIELDS
- Fuel pump eccentric
- WTB Delta Royale factory floor mats
- need 7040250 carb
- 70 442 waterpump and carb
- parts needed for 69 & 70 '88 convertibles
- Source for 303/324 mounts? Motor/trans
- Anyone parting out a '49-'51?
- Alternator 1100855 1969 Olds "Needed"
- 1965 Oldsmobile Rear Bumper
- Need Flywheel Dust Cover
- 1995 98 part needed
- looking for m20 or m22 tranny
- GLASS
- WTB-15x7" Steel Rims!
- rear sway bar 72'
- 1964 Super 88 script
- Another newbie 56 a-c condenser anyone ?
- 1969 Cutlass Jack
- 1957-1960 371 / 394 flywheel wanted
- Convertible top parts needed
- 71 Fender
- '65 cutlass power steering parts wanted
- Deluxe belt/Retractor--69
- 15 X 7 SS II
- if parts needed for delta (convertable parts) craigslist detroit michigan
- Wanted
- Wanted
- 1972 TH 400 Trans or comprable MI/Ind/Ohio
- WTB....68 hood release lever and brake part
- TH 400 Trans
- wanted: 3 groove water pump pulley for 65 425
- need a rear jetstar 88 bumper
- 1954 Olds trim
- REVEAL MOULDINGS
- Need a driveshaft for my '57 Super 88 sd
- all brkts and pullies
- 67 conv. rear view mirror bracket
- WTB-Aftermarket Intake Manifold
- 65-76 455 Oil Pan
- Good Place to buy hood for 68 cutlass
- original air cleaner body for '65 442
- WTB 1970 Cutlass front hood molding
- 1970 Cutlass Supreme Conv rear side glass
- rear tail panel
- 62 A/C compressor vibration isolators
- Need 350 Rocket Dipstick and tube
- Inner Fender Splash Shields - 62 Starfire
- 1969 or 70 delta 88 parts
- Need Rear Bumper for 1964 Starfire
- Air cleaner for 69
- 87 Toro need front end parts
- need drive shaft for my '57 sdn
- Still need front RH inner fender well
- TRUNK FLOOR
- weatherstripping for 85 delta 88 4 dor
- Fan shroud 73 CS
- Wanted: Non-A/C Pullies
- Alternator bracket needed for my 350 rocket.
- Need mouldings but from where?
- WTB: 67 Cutlass parts,hubcaps,trunkstrip,mirror
- 1964 B-Body fuel sending unit
- '64 Vista Cruiser wish list
- 1966 Cutlass Intermediate Harness
- need Qjet for 68 455
- '66 Delta differential yoke
- Distributor Wanted
- 1965 cutlass front turn signal assemblies
- NOS 67 Cutlass Headlight Assy
- WTB: '68 442 alternator bracket--AC car
- Wanted: 1963 Starfire Power Brake Booster
- looking for a nice turbo 400
- WANTED: UPPER CONTROL ARMS 67 Cutlass
- WANTED: Frt Brake Line brackets 67
- lookin for some 1973 olds 98 headlight bezels
- 4GC CARB FOR 65 442 WITH A/C
- newbie from ny
- Need 1973 olds 98 parts
- 64 65 Starfire front fender top trim
- Help in need of a roof
- AM/FM RADIO FOR 1971 CUTLASS S
- Looking for Steering Wheel
- 1972 442 BLACK DOOR PULL STRAPS
- Sport Steering wheel mounting pieces
- 403 Power Steering Pump with brackets
- 67 442 Gas Tank Release Vent
- 61 F85 Interior Door Panel
- 67 delmont 88 parts needed
- '67 Rally Pac clock adjust knob.
- wanted: 67 rear defogger switch
- 75 door panels
- WTB....68 400 motor or 455
- 73 delta 88 parts
- Newbie: Recently got 1972 ninety eight
- eng wanted '70 455 ...
- door lock motors
- 72 cutlass supreme parts
- '68 400 bent oil fill tube-URGENT
- 1971 delta 88 seat parts
- Good place in MD to find 425 or 455 Engine
- 1956 oldsmobile parts wanted
- 1973 olds 98 parts wanted
- 1973 cutty
- Vinyl Top Stainless steel trim for a 72 supreme needed
- 1962 Jetfire badges,side stainless+turbo unit
- roof for 1973 cutlass supreme
- 56 Olds windshield
- need parts 71 cutlass convertible
- 1970 442 Jack, spare tie down
- Late 1964 or 1965 330 heads needed....
- Alternator brackets for 330 V-8
- Looking for 394 goodies..intake and exhaust manifolds.
- 72' 350 timing tab
- Early 64 330 rocker arm wanted
- 455 motor
- 69 Cutlass parking light holder
- 1978 olds delta 88 coupe chrom-trim rearwindow
- Harmonic balancer needed
- seat belts needed
- Need Distributor Hold-Down Clamp
- 72 cutlass fender wanted
- 73 Heater A/C Control Assembly
- wtb..snap on center caps for SSIII
- 73 Glove box switch
- '95 C/S Convert Parts!
- parts for 1970 442
- 71-72 Sport Mirrors needed
- Wanted: 4v air cleaner pan to fit my '71
- Wanted 69 Cutlass front clip
- wanted hurst shifter
- 1973 Dual snorkel air cleaner
- Wanted: 1967 Cutlass Convertible inside rearview mirror support
- Wanted,,trunk lock emblem for a 73 olds 98
- 70 442 carb
- Wanted polished 3711
- wanted 1968 cutlass am/fm
- 1973 CUTLASS SUPREME
- 400 E block, Flywheel- Crank ?
- does anyone have a good cheap 4 inch grider
- 69 Cutlass Mirrors
- Side Scoops 1965 442
- 54 olds 324 dual action fuel pump
- another guy needing 56 olds parts too...
- 67 Cutlass Conv parade boot clips
- 67 C/S Side veiw mirror and Trunk Strip
- 1975 cutlass supreme door
- 1966 4-4-2 Fender Wanted
- looking for a nice rear spoiler for 1974 cutlass 442
- Need trunk emblem see pic
- Need a couple parts for a 71
- 65 Cutlass door panels wanted, must be nice!
- Need trim pieces for '50 88
- 455 and auto
- WANT TO BUY - SEATS 1973 DELTA 88 CONVERTIBLE (1972-1975)
- Looking for 72 fan shroud
- 69 442 post coupe seatbelts
- Anyone from Wyoming or Utah? Need parts
- 68 400 oil filter housing
- 1973 cutlass supreme
- roller lifter retainer
- Wanted - OW transmission
- 65 442
- '77-80 Center Caps
- 67 Cutlass Bench Seat Needed NJ
- 62 Starfire, 88 or 98
- WANTED: Return line fitting/line on p/s
- WANTED: C heads #394548
- Need Gas tank
- WANTED: 67 Dipstick (400, 67)
- Still looking
- aluminum olds valve covers
- Looking for a 1968 400
- WANTED: Complete Backseat Frame for '64 Cutlass SC
- 68 Fender Molding & water pump
- MT front drag tires
- Vista Cruiser Parts Needed
- lowering springs kit
- looking for a 5 speed Hurst shifter
- Digital Clock or Florescent Clock
- 73 omega part needed
- wanted 12 bolt car possi & 373 gears
- 77 cutlass supreme scoop
- Pass-side mirror for 1971-76 88/98
- Moldings Wanted
- 10 bolt 3.08 ring and pinion
- 1970 12 bolt rear or housing wanted - clean
- Radio plate Dynamic 88
- 73 DELTA 88 ROYALE CONVERT.
- 1970 455 alternator brackets
- trim parts needed
- Rocker Mouldings
- convertible part
- Wanted: Distributor
- Lightning Rods trans bracket
- 67 olds delmont 88
- 67 del mont 88
- 1971 Cutlass Supreme Parts Needed
- Courtesy Light Cover
- 1964 starfire interior parts
- 1964 olds starfire parts wanted
- 71 442 Grills Wanted
- 1966 442 decklid moulding
- 425 or 455 and/or trans in or near ohio wanted
- Horn Button
- WTB 455 Pistons .030 over
- 1964 Dynamic 88 Mirror WANTED
- WANTED 67 A/C heater & A/C control Panel
- F-85 1961
- Cheap Stock Steering Box for rebuild
- 57 Rear Bumper
- Parting 1963 Dynamic 4 door..
- 67 delmont88
- wtb...68 400 motor choke coil
- 62 Cutlass F-85 Auto Transmission Needed
- Needed 68 left hand hood hinge
- WANTED: Rocker Stands 400 67
- 70 W31 Carb
- 67 442 Headlight Bezels
- 1962 Oldsmobile Radio???
- exhaust manifold
- Directional Switch
- WANTED DEAD OR ALIVE
- Non Air parts wanted
- WTB 1970 Fan blade (19") for 350ci
