View Full Version : Parts For Sale
- 1968 - 1972 Cutlass TH350/TH400 Stainless steel transmission to radiator lines
- NOS 1966-7 Odometer
- NOS 1950's Odometer
- NOS 1965-70 Starter Field Coils
- Polished Holley valve cover
- Tilt steering column 69-73
- 1969 Black Sport Steering Wheel Cutlass 442 Hurst Olds
- SSI wheels & tires
- Oldsmobile Radio Knobs
- 1967 442 4 speed pedals
- Hurst Dual Gate 2 Shifter 4 speed Auto/ O.D
- NOS Front Floor Mats 1960's Olds Cutlass 442 88 98 Starfire
- 455 partial short block
- 1972 Supreme headlight bezels F/S
- 405233 69 hurst olds intake
- NOS Cruise Control Servo NEW GM
- Rebuilt 1965 442 400 engine for sale
- Oldsmobile Maar Clock STEERING WHEEL 1949 1950 1951 1952
- Reproduction price increases due to inflation
- 1970 Olds Cutlass 442 VAPOR CANISTER NA9 California
- 1968 / 1970 Olds Cutlass 442 Sport Steering Wheel HORN BUTTON
- Steering Wheel HUB 1968 Olds Wood Grain Wheel
- 1968 Wood Grain Steering Wheel Cutlass 442 Hurst Olds
- 7042953 carburetor
- Edelbrock Performer 2151
- Cooling System Parts
- 350 455 OLDS Starter Water Pump Alternator Caliper Cores
- 8.5" Corporate GM 10-bolt Posi Rear End and TH400 Driveshaft
- GM shift cable
- 1968 442 walnut wood steering wheel
- 1970-72 dash pad with vents - no AC, dyed black
- 15x7 Rally Wheels w/Bolt on Centers
- NOS Outside Thermometer 1970's Oldsmobile Style Cutlass 442 Hurst 88 98 Toronado
- RobbMC 550HP Fuel Pump (old style)
- Mini Starter BBO
- Longtube Headers BBO
- OEM Hose Clamp Kit
- Seatbelt Set
- MISC. BBO gaskets
- 1965 98 88 Starfire Jetfire R/F NOS Bumper Bracket
- 72-76 350 #8 Heads TH350
- Hedman shorty headers - Summit McDonough scratch and dent shelves
- 1971 72 Dual Snorkel Air Cleaner
- For Sale: NOS '69 '70 442 Hood Extension Emblems
- NOS gm waterpump 6 inch shaft olds V8
- G heads for 403 rebuilt
- NOS Olds Back-Up Lamp Pkg. 982124 1963 F-85 Cutlass
- Mondello Pulleys/Brackets
- 1969 LY Code Wheels Cutlass W-31 442 W-30 W-32
- NOS 78-79 Cutlass Grill Plate Emblem "Oldsmobile"
- NOS EES Vapor Cannister 1970 Olds 442 W-30 NA9
- N.O.S.COURTESY LIGHT LENS 74-76 DELTA 88 $30 + the ride
- 65 cutlass F-85 parts car
- 1966 1967 Olds Cutlass 442 Dash Switch Bezels
- 1970 olds cutlass rear speaker 7300614
- Accessory Rear Speaker 1968 1969 1970 1971 1972 Olds Vista-Cruiser
- NOS 74-76 BB Dipstick Tubes
- 1966 Oldsmobile 88 and 98 manual antenna parts
- 1972 Cutlass hood trim F/S
- 1969 Cutlass seat belt retractors
- 1964-69 4 sp. console top plate
- 1960 Olds reverse lights
- 2 587793 LH manifolds Olds dual exhaust
- Rebuilt 404847 water pump
- 1970 oldsmobile script
- 1970 -72 cutlass floor shifter
- 65 Cutlass/442/F85 Tail Panel Nice Shape
- Omega header panel emblems
- 14 x 6 SSIII Rims, Trim Rings, Snap-On Caps - Set of 4
- 1970 N30 Steering Wheel Olds 442 W-30 Show Quality
- 1972 Floor shift tilt column - Cutlass 442 69-70-71 72-73 also
- 1969 Cutlass 442 V-C dash wood grain 3 pcs
- 1970 Oldsmobile Night Watch components..
- Oldsmobile camshaft 400-425-455 engle JM18-20
- 2-nice 1968 deluxe black seat belt retractors
- Used T-3 Headlights
- Flywheel
- Nos oldsmobile gold and cloisonne promotional ring pristine #g313
- 68-69 trunk lite Cutlass 442 others
- 1955 Oldsmobile complete power steering set-up
- NOS 69-72 Cutlass 442 BB Battery Trays
- NOS 66-67 Cutlass 442 V8 Breather Caps
- 1973 -77 ? power trunk releases
- NOS w31 grills
- 1966 L69 tri carb parts lots ( 3 )
- 1963 Starfire tachometer $85 plus shipping
- cutlass emblems
- 1973-4 Embossed 350/455 valve covers for sale/trade
- NOS Delco Thermal Limiter fuses 6551258
- NEW GM Cruise control brackets 1970's 1980's
- Trunk light
- Seat belt console side anchor bolt covers
- Deluxe small buckle green females
- Hamill green deluxe rear seat belts exc set of 3
- Deluxe Green rear seat 3 belts
- 5 painted black 15x7 Wheels 5 NOS BOLT ON Center Caps 5 NOS TRIM Rings
- 1978 Cutlass Supreme rockers
- 1978 Cutlass rear trunk filler
- 1978 Cutlass Supreme column
- NOS Turn Signal Lever for Cruise Control Cars
- 1978 Cutlass t top glass
- 1978 Cutlass cable
- 1978 trim rings
- New in GM box door locks with used key to match fits both
- 1978 Cutlass Supreme window glass
- 1970? through 1972? Power trunk release
- 1964 starfire vacuum trunk release
- PYPES 2.5" cut outs
- 1970-1972 Heater Control Panel
- 1970-1972 Cutlass/442 Guage Set
- Rochester 750cfm $300
- 1970 442 Cutlass Black Seat Covers Full Set
- NOS 68-72 Cutlass 442 Blower Motor Switch
- NOS Convertible Rear Speaker Pkg. 1971 1972 Cutlass 442 Hurst Olds
- NOS 72 Cutlass Supreme R.H. Grill
- 12 Bolt Olds 2 series posi #673
- 1972 Cutlass Supreme OEM hood trim F/S
- Tachometer 1964, 65, 66 GM 6411793
- 1965 Cutlass/442 Side Moldings New Chrome
- Carbs
- NOS 78-88 Cutlass 442 Shifter handle rebuild kit
- 1920' 1930's Headlight Bulbs Cars Trucks Harleys
- BB Oil Dipsticks Early style part # 400714
- 72 Cutlass 442 H/O OEM Deluxe Seatbelt Shoulder Harness
- NOS 1970's AC Radiator Caps GM cars.
- 70 442 carburetor 7040257 UJ 3169
- Complete running drivetrain for sale
- 1965 442 Cooling Fan
- Rally gauges 68 - 69
- Rally-Pac Gauge 1975 1976 1977 Cutlass 442 Hurst Olds
- 72 Olds 350 4 barrel intake manifold.
- 1955 Olds 98 dash support
- 68 sport wheel hub
- Pf30 oil filter and gm air cleaner wing nut
- 1970 gm parts division license plate frame nos
- NOS AC 45S Spark Plugs Oldsmobile Buick Pontiac Chevy
- NOS Olds Remote Control Mirror 1970 1971 1972 Cutlass 442 Vista-Cruiser
- olds meziere electric water pump
- SBO Holley street dominator intake manifold
- NOS 67-69 Cutlass 442 GM Fuel Pump
- 1966 Olds F-85 Post Coupe TRUNK SCRIPT 442 W-30
- NOS 90-92 Tornado Trofeo Wheel Well Moldings
- Top of a 1073 OLDS $455 J heads Rockers and All
- night watch complete
- Cruise control parts lot 1970's and 1980's stuff NOS NEW GM
- OEM J2 valve covers, never used
- 1968-1972 Glove Box Light
- NOS 68-72 Radiator Hose To Shroud Clamp
- 1960 Hood Ornament Emblem Part Nbr 579742
- Show Car Quality 1968 Woodgrain Steering Wheel Cutlass 442 Hurst Olds
- 1968 1969 Cutlass 442 Hardtop Black Sunvisor Set--Excellent Original GM
- 1968 Cutlass Glovebox Door
- Parking brake pedal assembly
- 66-69 non console shift boot and ring
- New Lakewood SFI Bellhousing Part 15100 for 64-77 Olds 330 to 455
- NOS 1966 1967 "Cutlass" trunk lid emblem Oldsmobile
- NOS C-S Roof Emblems 1970 1971 1972 Olds Cutlass Supreme
- Remote Control Mirror 1966 Olds Cutlass 442 Vista-Cruiser
- Sale-68-72- Smaller Parts
- NOS 1960 Parking Light Lenses LH/RH
- Turbo 400 Dip Stick and Tube
- 71/72 air cleaner
- Some 1972 Cutlass Supreme parts Mirror/lens/window cranks
- Miscellaneous Parts
- 1970 (71) flat ridge PS fender
- 1952 0lds instrument cluster.
- GM nos Windshield Moulding Clips
- AC PF 30 Oil Filters
- 68-72 2dr Sedan Only Jamb/Striker Brace and Reinforcement Brace
- 1965 442 4 speed Shifter Handle w/ Hurst Shifter
- 68-71 Cutlass 442 Black Seatbelt Set - Real GM
- 70 71 72 Cutlass 442 Black Dashpad-- Excellent Original GM
- NOS 72 Cutlass 442 H/O Stone Shield Emblem
- NOS 72 Cutlass 442 H/O Aluminum Grill Moldings
- 1964-65 Cutlass/F85 Delco AM Radio
- 71-72 OEM 442 Rear Bumper
- OEM 72 Cutlass 442 headlight bezels
- NOS Spark Plugs 1964-1968 Olds Cutlass 442 W-30 H/O
- Nos oil fill cap
- 455 Olds motor Nor Cal
- Ss
- NOS GM Oldsmobile Accessory Electric Windshield
- New 1970 442 / Cutlass S Black Front Bucket Seat Covers PUI
- Water Pump 413307
- NOS Cutlass 442 H/O Convertible Courtesy Light Lenses
- Z exhaust manifold from a 1970 442 dual exhaust
- Rear Bumper 1971 1972 Cutlass Re Chromed by NORTH STAR PLATING
- Old Radiator
- 1970 71 72 Dash Gauges
- 70-72 442 Rear Glass Tacking Strips, 68-69
- NOS NEW OFFY Offenhauser dual quad Total of THREE Carbuetor mounting pattern BIG OLDS
- 1970 Cutlass 442 Hardtop Black Sunvisor Set--Beautiful GM
- 1966 Oldsmobile Steering Wheel F-85 442 W-30
- 1971 Y72 HD 4 core radiator
- FREE water pump housing and mirror parts
- 1970-1971-1972 Olds Cutlass 442 dog dish hub caps
- 1970 Cutlass 442 CENTER RADIATOR GRILL HOOD SUPPORT
- 12-Bolt Cover
- Taylor Wires
- Backing Plates
- Axles
- 1965-1967 Door Handles
- reproduction 1969 Hurst Olds Mirrors
- NOS 68/69 442/Cutlass fender antenna assembly
- 1972 Cutlass 442 Black Seatbelt Set --Excellent Complete GM
- Power Steering GearBox 5691676
- 69-72 Original Intermediate Steering Shaft
- 68-72 Front Control Arms
- 68-72 Door Hinges
- 70-72 Window Regulators
- W31 and 350 distributor
- 67 to 69 automatic trans inspection covers
- 68 to 70 442 boxed conrtol arms
- Ash trays
- YEAR ONE 4 Piece Gas Tank Pad Kit 1968 to 1972 A BODY
- Headliner Head Liner
- NOS 68-72 upper Rad Hose to Shroud/T-Plate Clamp
- Restored 1953 Olds 303 Rochester 4GC Carburetor
- 1938 Oldsmobile Trunk Handle and License Light Housing F38 and L38
- NOS 69-72 GM "2" Trunk Lid Emblem
- USED OEM optional under hood lights and one jumper wire
- G-body 1987 - 1988 side marker lights - nos
- G-body overflow tanks 1984-1988
- 1968 4 BBL air cleaner and stove pipe
- 1967 Speed Minder Parts Olds Cutlass 442 W-30
- NOS Locking Gas Cap 1975-1980 Cutlass 442 Hurst Olds
- 1972 Cutlass Supreme trunk trim piece F/S
- 3 out of 4 1970 Vista Cruiser door panels and arm rests
- Factory A/C Brackets
- FS: 1965 442 side scoops and badges
- 66-up radiator top plate
- 1972 Cutlass Supreme 1/4 panel extension trim F/S
- NOS 71-72 Cutlass 442 Stone Shield
- 81-88 Cutlass 4dr Doors, Glass.
- Full size parts
- Open Carrier
- Ring/Pinion
- fuel guage
- Nos 69-72 gm "442" emblems
- Cutlass parts and other gm parts
- Lots of 68-72 Cutlass 1/4 Glass Tracks,70-72 Door Guts
- #5 Heads
- 2 barrel air cleaners '68 & '69
- Low mile 455 Dallas TX
- 1973 - 1977 Cutlass NOS T-Top
- 1970 Cutlass 3:08 posi rearend
- 71-72 OEM OAI Hood (Ram Air Hood) - GM
- 68-72 Cutlass, Full Firewall W/Sides,More
- 71-72 Cutlass 2dr Orig. Backseat Divider Panel 125.00
- 68-72 Cutlass 2dr Rear Inner 1/4 Panel
