View Full Version : Parts For Sale
- '65? - '67 Cutlass/442 Brake Booster Hose Fittings-resto'd+Johnny Lightning '67 442
- BOP rearend
- License plate lights $30 shipped
- 1962 hubcaps
- 69 vista cruiser parts car
- Headlight bezels
- 1972 Oldsmobile cutlass exhaust
- Oldsmobile dash and 71 w30 intake
- Chrome valve covers for V8 330, 350, 400, 425, 455
- miscellaneous 66 88 parts,probably fit other years
- PARTS $30 and under
- 65 442 side chrome
- 1966 442 4 Speed Vintage Floor Shift Boot and the Retaing Ring
- Box lot - variety
- Carb and distributors
- NOS A/C Fuel pump # 41566
- 68-72 Cutlass 442 Convertible Rear Top Boot Retainer-
- 68-72 GM Delco Remy Wiper Motor--Cutlass 442--and Others
- 350 olds n crank
- 71-2 Cutlass/442 Front Turn-Park Lamp Lenses - 1 RH and 2 LH - Driver Quality
- O.G.Transmission
- '67 Cutlass/442 Radiator Overflow Hose CLIP - replated nice original
- '62 - '72 CONVERTIBLE rear armrest chrome courtesy lamp housings
- Rochester q-jet 7040253
- Passenger arm rest
- '69 Cutlass/442 hardtop vinyl top diecast chrome REAR "corner" moldings
- 1970 original door panels
- 1968 through 1972 rear quarter glass
- '70-2 Cutlass "S" and 442 hardtop vinyl top die cast chrome pieces
- OEM Outside Mirror
- 394 Hilborn Injection
- Car parts - A-body
- 1970 Date Coded Grooved Rotors - W-30 / W-31
- 68-72 Convertible Pillar Post Moldings Chrome
- One last box lot of various parts
- Nos oldsmobile tissue dispenser
- Pertronix 1181 with flame thrower coil
- NOS 1971 1972 L.H. Sport Mirror Olds Cutlass 442 H/O Buick Skylark GS
- Another box of parts
- NOS 71-72 cutlass fender tags
- Script Oldsmobile valve cover
- Offenhauser big block 2x4 intake
- Wilwood brakes
- 2 NOS Delco Ignition Resistors 1953-1961 Oldsmobile
- 65 - 67 Switch Pitch Auto Throttle linkage
- 70-72 Tach/Clock Gauge - Not OEM
- Sale 68 Cutlass Door
- NOS Delco Power Window Motor Made in U.S.A.
- 1974 455 block
- Miscellaneous Parts For Sale
- 1970-72 Oldsmobile AM/FM Radio w/Speakers
- Shift Linkage Rods from manual transmissions
- Complete Turn Key 500+ HP Exotic Nitrous Ready 403 Build For Sale
- A/C parts lot $75
- 1964 330 Distributor electronic converted
- FS: NOS Gold Fuzzy Hurst T-Handle Fine Thread
- FS | 72 Bucket Seats (pair) | Fully Restored SOLD
- For Sale: 70 - 72 Floor Shift Speedometer
- Original gm master cylinder cap
- NOS Wheel Opening Moldings Olds G body 1982-1988
- 1970 Oldsmobile Driveshaft 55.5"
- Super stock 1 wheels 14”x7”
- 1970 Door Panels and side panels
- Box of Misc Parts
- Box of Cruise Control Parts
- 2bbl air cleaner ( free)
- 71-72 cutlass front bumper-goodmark-new
- 14 Inch SSII SSIII Rally Wheel TWO Wheels with Trim
- Oldsmobile center console
- Parting out various parts
- Oldsmobile script valve covers chrome
- 68-72 trunk pan braces
- 69 olds trunk hinge panel
- 69 olds Tail Panel
- Q-Jet Carb
- KC - KF A/C Pulley Set OEM
- 7029251 Carb 69' 442 H/O
- Nos 70-72 vinyl top quarter panel belt line trim Rh Lh
- 70-72 350 exhaust manifolds
- 70-72 exhaust system
- parts for sale-various
- Various '57 Olds Parts For Sale
- 1970's Oldsmobile accessory outside thermometer
- 31 spline axles 3.91 ratio rear
- 4 barrel air cleaner (bottom part or whole part) 67 olds
- Oldsmobile Script Valve Covers
- 1970 Oldsmobile TH350
- Nos 1961 olds fenders and quarters
- 1969 Cutlass 442 driver side door jamb section cut from NOS quarter panel
- 1969 Cutlass 442 lower plastic dash - green
- 1970-72 Cutlass hardtop and conv power window regulators - no motors
- Sanderson 0351 headers
- Parting out 69 4 speed 442
- Odds and Ends...
- 1102380 Delco Alternator
- 404847 water pump
- 7029251 Carb
- F/S 68-72 battery tray
- 1969 Oldsmobile Cutlass S convertible frame
- GM PART No. 8732500 Clip Headlining Spring NOS Headliner Clips
- 1970 Cutlass/442 Rear Bumper Mounting Brackets
- 1970 to 1972 Rear Bumper Rubber Fillers Cutlass 442
- Wheel trim rings for a 14x7
- 64-67 trunk light assembly
- 17 x 8 SSII wheels and tires
- Lunati Voodoo had roller cam
- '69 442 Antenna.
- Bop th350
- Console/Glove 1968
- Sport mirrors
- AM Radio with Knobs Has Front and Rear Speakers Control also has mounting bracket
- 1964 cutlass parts for sale
- NOS 1972 Oldsmobile + 442 Header Rocket Emblem
- Rearend 70 cutlass
- Interior Door Arm Rest and Pad + Pull Strap and Shiny Ends Hardware BROWN Coat Hooks
- BIG N Nodular Crankshaft for 455 This has a bushing installed for manual transmission
- 68-70 2 groove water pump pulley 399401 KE
- Thermostat housing’s
- NOS L.H. Grill 557331 1978 Oldsmobile Cutlass Supreme 2 door
- NOS Battery Tray 1971-1973 Olds 88 98 1973 Cutlass 442 Hurst H/O
- 2 Cruise Control Servos with Mounting Brackets 1 has the Rod
- 1970-72 NOS RH eyebrow trim
- 1966 Cutlass Hood Spear
- 70 Speedo/Fuel/Clock Cluster
- GM A Body Door Hinges
- 71-72 hood grills
- 7040253 carb
- NOS Oldsmobile GM Tie Rod 1965-68 #386303
- 66-67 442 manual trans throttle linkage 3x 2 barrel style
- Pair of Door Cards Assembled Used Door Panels
- NOS Delco Distributor Cap D308R 1971244
- G-BODY G BODY TRANSMISSION Crossmember Heavy Duty Aftermarket High Performance
- 68-69 Water Pump 398681
- Factory Installed 1115216 Coil 1966 Olds Cutlass 442
- 70-72 Cutlass Console Shifter
- 70-72 master cylinder lids
- Nos gm 70-72 master cylinder gasket
- 70-72 rubber bump stops
- NOS 1970 TCS Solenoid 1114428 Olds Cutlass W-31 442 W-30
- NOS 1966 Steering Wheel Center Cap Olds 98 Toronado Tilt Telescopic
- YOKE for 12 BOLT Cover TYPE O axle 1967 to 1970
- 1970-72 W & Z 455 Exhaust Manifolds
- 1965 Cutlass Convertible Frame $2000.00
- 7043250 Quadrajet carburetor
- Water Pump 384786 Rebuilt
- 1960 Olds 98 Chrome Dash Trim NOS
- '68 Vista parts Waxahachie Tx.
- Fuel Pumps For Oldsmobile
- 1970-72 Cutlass/442 Side Marker Lights
- 350 Oil Pan
- 8.5 3.42 posi 1971 cutlass/422
- Points distributor
- Clean 1970 Cutlass am radio works great
- 1973 HURST 442 Cutlass rally-pac “nice”
- 1973 Cutlass fuel gauge
- Selling 2 black SSIII rims w/ trim rings and caps
- NOS AC R44S Green Stripe Plugs 442
- NOS 1969 OLDSMOBILE Rear Speaker kit parts
- 1938 Olds Steering Wheel Rat Street Hot Rod Custom
- Bumper Jack Parts
- NOS Sunvisor Supports 1961 1962 1963 Olds F-85 Cutlass Jetfire
- NOS Gas Cap 1941-1956 Oldsmobile
- G Body 2dr Power Locks, Handles, Misc Door Guts
- NOS Gas Cap 1971 1972 Cutlass 442 W-30 Hurst Olds H/O
- 1969 Blue Sport Wheel
- Choke stove,tube, cap assembly.
- 1965 Rochester 4GC parts
- 1964-66 GM tilt steering directional cancel pin and horn contact.
- 71-72 442 air cleaner
- 1100777 Alternator
- Rebuilt 400269 water pump
- NOS Medium Gold rear floor mats
- 1971 original 4 core ZK code Radiator
- 1972 ZN rad tag code 4 core radiator
- 1972 original OC rad code Radiator
- 1971 original SS rad code Radiator
- 70' Water Pumps 404847 "X"
- 1966-67 FS rad code Radiator
- Radio from 72 Cutlass
- 1972 Cutlass 442 Cruise Control Servo and Bracket
- 69 442/cutlass core support
- 1968 Olds full sized radiator shroud $100
- 70' Oldsmobile 14" hubcaps
- 1954-55 Speedometer head assembly $135
- NOS Chrome Sport Mirrors Cutlass 442 Hurst Olds 1973 1974 1975 1976 1977
- 1967 Front Bumper Brackets
- 1968 1969 Olds Cutlass 442 Vista-Cruiser Remote Mirror
- 68 69 442/Cutlass manual antenna base & lead
- 1971 442 black legendary seat covers new never installed
- 70-72 442/Cutlass heater floor duct for cars w/ console #406731
- NOS 66-67 Oil Breather Non-PCV FB-55
- 1981 to 1986 Cutlass Calais 442 Center Dash Vent Panel 557237 81 to 86
- NOS 68-72 Cutlass other GM A-body Rocker panels
- NOS 68-72 A-body door hinges - 3 NOS
- Oldsmobile vanity mirror...
- 83 H/O Computer....
- New Emergency Lamp Kits
- 70 71 72 C utlass 442 Glove Box Lock Cylinder, Latch and Key-- Real GM
- 1969 70 GM Cutlass 442 Delta 88 etc. Real GM Ignition lock and Key
- Freeze Plugs Core Expansion Plug Assortment
- REMFG 1112085 DATE 1 K 7 REBUILT with NEW and NOS GM PARTS
- 1111982 Points Distributor has MS 408 24 Vacuum Advance DATE Code 1 J 10
- 66-67 radio bezel...
- 1970 1971 1972 Dash Ash Tray Door and Springs
- 1968 Vista Cruiser for parts
- 1968 455 engine
- Olds main bearings
- 68 hood hinges....
- 1971 1972 Cutlass Hood Latch assembly with rod and pivot + spring for front o' hood
- NOS 3 Groove Pulley 72 Cutlass 442 A/C
- 1964 Oldsmobile Dynamic 88 Hood
- 1971 1972 A-Body Rear Black Seatbelts
- Custom 66-67 Cutlass Gauge Bezels
- 12 bolt Chevy 3 series posi.
- original GM parts...
- Hurst 4 Speed Shifter Mechanism
- 66-69 Factory 4 Speed Shifter Bracket
- Starter
- 1962 Olds Full Sized Tail Lights
- 455 OLDS 1970 Distributor with broken aluminum housing has MS 427 16 advance
- Misc hardware, fasteners, Free for the shipping
- T400 deep aluminum pan.
- 70-77 Ralley Steering wheel....SOLD
- 1970-72 wheel well trim
- 68-72 hood hinges
- 1969 455 intake - 398662
- M/T 455 valve covers
- 1970 auto floor shifter
- 1969 H/O 455 alternator - 1100852 55A
- 1970-72 tilt column
- 68-69 C heads
- 70-72 Cutlass Supreme rear quarter ext.
- 1970 442 tailights - original patina
- 70 455 Delco Coil + Bracket w/ Resistor and Original Battery Cable Tube 1970
- 1970 442 rear bumper
- Cutlass/442 head pipes
- 1970 Cutlass 442 Talight Lens--New and Nice
- 70-76 Cutlass 442 AC Delco NOS Fuel Pump #40712
- NOS Walker 35614 Trumpet Tip
- 1970 455 Preheat Pipe
- 1965 Cutlass 442 Convertible Window Weatherstrip Kit.
- 69 Lansing bare block for sale
- NOS Oil Pressure Sender for real gauges
- Vapor Canister 1970 1971 1972 Olds Cutlass 442
- Emblems Cutlass 442 f-85
- 68-69 Water Pump 400269
- 68-72 Cutlass 442 OEM Clutch and Brake Pedal set
- OEM Tail Light Lens 1971 and 1972 Taillight Lenses
