View Full Version : Parts For Sale
- 70-72 Grills some see pics $85 plus shipping
- 70- 72 Cutlass Radiator top plate, 5 blade fan blade w/fan clutch, and fan shroud
- NOS power trunk buttons, the yellow one.
- 70 Cutlass rear bumper guards
- NOS 1969-77 Horn relays
- '71 W-30 heads
- 1968 442 sport steering wheel (wood)
- NOS Oldsmobile Goodyear Polyglas G78-14 Rallye Wheel Spare Tire Assembly
- '66 "B" Body Tail Light Bezels
- 1968 "B" Body Bumper
- Oldsmobile 403
- 1970-72 Ram Air Cleaner
- 1970 -72 left fender
- 1970 Ram Air ( OAI ) Hood
- FS 1969 Oldsmobile 98 Power Seat Switch and Door Filler
- 70 Up Choke Pipe
- 1966 442 rear end assembly 3:55 posi sj code
- Chrome trim for Cutlass Supreme Various Pieces
- 71-72 Gauge cluster and AM Radio
- 2 barrel and 4 barrel cast iron intakes $100 each both $150
- 70 Cutlass Black Rear Panels and and armrests $120 plus shipping
- Voltage Regulator Delco Remy
- 70 fenders and hood
- Restored under hood lights
- 1965 442 Original 400 Engine
- 1972 4bbl intake manifold - 410446
- Early 70's breather for HEI.
- '70 Air cleaners
- Toro Oil Pan
- Pr. Oldsmobile Rally I wheels w/ln P235/60R14 tires
- G Body double hump crossmember
- 468 Oldsmobile For Sale
- 1968 Olds 442 Cutlass Rally Pac Setup—Complete Real GM Nice
- 3 EARLY 50s DOG DISH hubcaps
- Tornado 455 CI Oil Pan, Windage Trays, Main Cap Bolts w/Standoff Studs
- Edelbrock Performer Intake Manifold 2151 Big Block
- F.S / Free take one - Suspension, A/C, various small parts
- 1977 Cutlass Hurst T-Tops
- 1970 Cutlass 442 front bumper
- Th400 switch pitch parts
- 7042953 carb
- For Sale: 1967 Cutlass Kick Panel Vent Grilles
- For Sale: 1967 Cutlass Cowl panel
- For Sale: 1967 Cutlass Convertible top cylinders
- 1967 Front Bumper filler
- 1967 442 Convertible RH door
- 1967 442 Convertible door glass-clear-both sides
- 1974-75 delta 88 coupe & conv parts Poconos Pennsylvania
- 71 cutlass hood and bench seat.
- A pair of Original w30 H heads
- 68 Cutlass Complete Engine and Trans
- 70 cutlass/ 442 wire harness
- NOS GM OE 1973-1977 Console Shift Automatic Shifter Gear Selector Bracket
- '67 442 Hood
- 1970-72 cutlass olds parts
- 1977 Cutlass Parting Out
- 78/79 cutlass parts free
- For Sale: 403 block-557265 4b Olds bare block w/main caps?
- 1970-72 Cutlass Dash Pad
- 1970 442 hard top for parts
- Olds "Youngmobile Thinking 1969" Sales Brochures - Free to Good Homes
- NOS OE 1968-1972 Cutlass Driver Side Kick Panel (Black)
- 71/72 cutlass/442 front fender eyebrow mldgs
- Fan shrouds. 69/70 72
- 67 cutlass/442 decklid
- NOS Delco distributor vacuum advance unit #1973418
- Assorted NOS parts
- 67' Wire Wheels
- 1971cutlass part out
- 1 pair upper '71 Cutlass/442 tailight lenses + 1 diffuser
- '72 Cutlass/442 Tailight Lens Set - Original nice restored
- NOS die cast 49 Olds
- 70-72 Cutlass dash map light
- Original 4 speed shifter knob from a 68 442
- Black 70-72 ash tray door
- Various Olds AM radios
- 1967 Parts
- 67 cutlass/442 L front fend section
- 1968 Cutlass Dash Headlight Switch Control Knob
- 1968 Cutlass Column Shift Automatic Steering Column
- Transmission
- NOS Thermometer 1970's Cutlass 442 Hurst Olds 88 98 Toronado
- 4-Speed Hurst Shifter
- Doing a little fall cleaning
- Cruise control parts.
- 67-69 Auto Shifter and Console
- will trade running 350 for big block short block
- 1968 Cutlass S Hood
- 1968 Hood Hinges
- 1968 Cutlass (parting out)
- 67 Cutlass F85 Steering Wheel
- 69 442 Glove Box Door
- NOS RH Grill 1984 Olds Delta 88 Custom Cruiser
- New felpro turkey tray, valve cover gaskets, rope seal, valve seals and timing cover
- 425 Olds Ultra High Compression Engine in N.Cal
- Parts from 1973 442....
- 1971 cutlass supreme "Ducky"
- 1966 Cutlass Restored Instrument Panel
- 65 330 engine core/parts
- 1970 Cutlass Supreme Hardtop. Black rear panels and armrests
- Assorted stuff
- (7) 12 oz cans of Plasti-Kote Trunk Paint New
- Assorted Leftovers
- 1955 Oldsmobile
- Floor shift ball(similated wood)
- Parting out 1965 F-85 4 door
- New Forward Lamp Wiring Harness 1970 V-8, Cutlass, 442, F-85, W-30, W-31
- 1966/67 Cutlass/442 Restored Chassis
- 1975 Delta hood
- 3.23 open rear end from 1966 Starfire
- Center horn buttons
- Dash pots
- 70 cutlass 350 detent switch
- 69 cutlass/442
- 70 71 72 Cutlass 442 Optional Sport Steering Wheel -Real GM--#9751836 –Nice
- Free - olds 260 - carb to pan
- 1966-1972 Oldsmobile parts book Cutlass 442 88 98 Toronado
- 1957 Olds Full Std & Deluxe Spinner Hubcaps
- 7 blade fan
- Parting 84 Delta 88 4 Door
- Hurst Dual Gate Shifter 1970-1971-1972 Cutlass W-31 442 W-30
- Rear window defogger
- Power steering boxes
- Flywheels & flexplates
- 68-72 bumper brkts
- 70-72 cutlass/442 rear body panel
- Outside mirror screws
- 72 out side rear view
- 1970 442 Glove Box Light Package #406609
- 1967 cutlass convertable frame and body tub
- Literature
- 1966 Cutlass Grill, Emblem & one headlight bucket
- NOS GM DOOR SKIN 68 69 Olds Delta (not mine craig's MD)
- 70 OW.Turbo 400
- 1969 Hurst Olds/Cutlass/442 and 1970 Cutlass and some other miscellaneous.
- distributors, points, hei and accel dual point
- 71 H heads
- air conditioning compressors
- 1971 cutlass parts
- 68 442 Cutlass 2 door hardtop headliner side trim sash mouldings
- Speed Pro ring set brand new 455 (4.125 + .035)
- 68 69 convertible trunk lid hinges
- Goodyear reproduction tires
- 68-72 rear view w/map light.
- Olds 350 and 455 for sale
- Throttle cable brackets
- Melling High volume pump and pickup
- Quadrajet TV cable arm conversion for 200-4R, 700r4
- OE 455 olds starter
- 3.73 3.42 and 3.08 10 bolt 8.5 gears NOT 'O' TYPE
- 14x5 A Coded Rim
- '57 Olds parts
- 1969 400 G Engine
- NOS Bumper Guards 1971 1972 Cutlass 442 W-30 Hurst Olds
- 69 Cutlass Grilles-- Real GM Parts
- 330 block
- 70 cutlas/442 front bumper
- 70 ramair hood
- 1970 cutlass/442 fender mldgs nos/new
- O-axle positraction rear ends
- 69-72 Olds pre-heat pipe filter screen
- NOS 68 442 valve cover grommet for breather pipe
- NOS Olds Delco Eaton fan clutch 403983
- The last of the parts!! All has to go
- 1972 olds 350 2 barrel intake and disassembled 2 barrel carb
- A/C Comperssor with custom Olds bracket
- Pertronix Flame Thrower Dist for sale
- 1970-1972 Cutlass 442 Hood latch assembly with handle $35
- 6459863 Gas Fuel Gauge 1968 1969 A Body Cutlass $35
- New airtex water pump
- 1970 Olds 442 - 455 NOS Dipstick's
- 1952 Olds 88 4dr rear tinted glass
- 71 & 72 turbo 350 trans
- NOS Remote Control Mirror 1968-1969-1970 Oldsmobile 88 98
- For Sale: 1962/63 Olds Cutlass Complete 4 Speed Setup
- Edelbrock 2151 Olds intake
- 1971 442 W30 Open face alternator
- Single Chrome Repro 15x7 SSII
- 1970 Olds 8 track tape Cutlass W-31 442 W-30
- NOS 1968 8 track tape Olds Cutlass 442 W-30 Hurst
- Set of 8 olds 455 rods. 70k miles
- Rochester quadrajet 7043250
- Another 425 for sale 386525A with A heads and auto trans
- NOS 1967 W-30 air filter
- NOS Oil Pressure Sender Olds Rallye Pac 1968-1974
- 365 horse power 455 circa 1972
- 1970 Cutlass
- Roof Rail and Door seal
- KA heads
- 1978 Cutlass Calais Parts
- 67 Cutlass 330 engine and trans - Denton TX
- Super stock II Ceter caps
- 62,63? F 85 parts
- Edelbrock performer 350 olds intake
- G body big sway bars
- Double hump crossmember
- Toronado oil pan
- 14 inch western rims
- 350 Big valve W-31 heads, W-31 intake
- 2 Diamondback Classic Redline Tires 215/55R17
- 68-9 W car water pump 400269
- Vinyl Top + for sale
- Nos emergency brk cables 68-72 cutlass/442
- 71 72 Cutlass 442 Hardtop and Convertible Rear Door Panel Windlace—Nice GM
- 402926 (1) Rally Hub SSII w/bolts
- 1968 Oldsmobile 442 3 core Radiator Top Plate
- 66 olds 425 389244D for sale in wi
- 1954 1955 1956 Buick Olds factory GM POWER ANTENNA
- 70-72 442 N.O.S. RR Wheel Opening Molding
- #6 and #7a heads
- 68 442/ Cutlass S Fender mouldings
- Air cleaners 69-72
- Alt & ac brkts
- 70-72 cutlass/ 442 cruise control switch & wireing
- 70-72 Wiper Arms
- 68 Cutlass - Rear Glass
- TH400 - Full Size GM - 1976 - longtail
- Pleasur-Lift gauge assembly
- W-31 Aluminum Intake Manifold
- A/C parts off of 71 Cutlass - 48040 Michigan
- 14x7 Rims
- 66 442 tail light assemblies.
- Vista floorpan sheetmetal
- 1971 vista frame
- 1971 vista interior items still available plus glass and rear gate
- 1971-72 vista cruiser rear doors
- Misc. pulleys.
- Misc. brackets.
- Water pumps.
- 67 Cutlass/442 core support latch assembly.
- 72 350/th350 edelbrock intake, carb, valve covers, and headers
- 1969 Cutlass S (2 door) Bench Seat
- DX short blocks
- 69 Cutlass 442 tail section.
- 70-72 console shifter with nice ball.
- 7042250 carb core.
- 1973 1974 Oldsmobile Script Valve Covers
- Non a/c alternator brackets.
- NOS 70 to 72 Cutlass/ 442 Trunk LiD Moldings
- NOS 1970 442 W30 Jets 58
- New and NOS 70 to 72 Cutlass 442 parts
- NOS Rochester Vacuum break
- 64-68? ignition switches.
- Nice OEM 66 headlight switch.
- New Wiper face plate 70-72 Cutlass 442
- 68 Cutlass S/442 parts lot.
- NOS 68/69 442 throttle body
- NOS Rochester base Gasket
- 1969 98/88 NEVER INSTALLED NOS Fenders
