View Full Version : Parts For Sale
- 70-72 automatic floor shifter w/cable
- 70-77 Cutlass and Omega Sport Steering Wheel with Hub
- NOS 1973 Cutlass, Cutlass S, Hurst, 442 & Vista Cruiser parts
- 15" Tornado wheels
- 15 x 7 original SSIII chrome wheels
- Olds 455 big block for sale
- original 67 442 automatic driveshaft
- For Sale:1963 Cutlass, F85, Jetfire trim some NOS
- 75 hurst olds emblem NOS
- small block olds aluminum intake
- Antique dish/ashtray? Olds Runabout...
- 1969 Master cyl CORE
- Big block and small block exhaust manifolds
- Pulleys
- Hei distributor
- 65 Alternator & bracket
- 15X7 trim rings Oldsmobile Rally Wheels
- 455 olds engine and transmission for sale
- Center caps/wheels/valve covers
- 1967 Mirrors Near NOS LH + RH Olds Cutlass 442 Vista-Cruiser
- Headliner Saddle New 70-72
- olds 455 adjustable push rods
- 72 cutlass floor retractor seatbelts plus more
- NOS R.H. Mirror 1967 Olds Cutlass 442 Vista-Cruiser
- Free 55 parts
- Ram Air OAI Lid
- 1969 Eighty Eight/Ninety Eight Brake lines
- 1965 442 alternator bracket
- NOS Quality 1970 Cutlass Supreme Decklid
- NOS Quality 1970 Cutlass Supreme Hood
- Floor Pan, Complete, 1970-72 A-Body, w/O Rocker Panels
- 1971 1972 Console wiring harness Olds Cutlass 442
- JM 28-29 hyd cam used
- Olds SSIII 14 x 6 chrome wheel
- 68 ramrod/W30/Hurst air cleaner
- 70-72 dash pads
- Comp cams roller tip rockers
- 79 olds full size nos pass mirror
- 1970 cutlass/442 ignition lock & trunk
- 68 cutlass/442 headlamp panel mldg nos
- 71 fullsize grille open mldg nos
- NOS 1969 Olds dealership items Cutlass 442 All models
- more 74-76 delta stuff
- 74-76 miscellaneous delta 88 parts
- AC Brackets and compressor '68 442
- 1972 Olds 98, and 1973 Olds 88
- 1970 Cutlass Supreme Coupe Blue Bench Seats
- 1968-1969 AM-FM Radio Olds Cutlass 442 H/O
- 455 rods
- 68-72 8 track face plate
- 73/77 Console an shifter complete
- SSIII wheels
- 70 black automatic console 442 Cutlass
- 63 Cutlass A/T radiator Tacoma Wa.
- Console, 1970 1971 1972 Olds Cutlass 442
- NOS '72 Cutlass, etc Tailight Lens
- 68-69 398662 D-1 S intake
- Dual Gate Mounting Brackets
- A body kick panels for a 67 black
- Hood Hinges
- 1100566 Alternator for a 1971 Cutlass W/O AC
- 71 442 Trunk Lid
- 1976 olds delta 88 royale parts
- Shift linkage for 65-70 88/98 dual exhaust
- 350-4 bbl Olds engine from '72 Supreme
- 68 and 69 TH400 long tails from delta 88s
- 68 and 69 Delta 88 / 98 HVAC boxes and temp controllers.
- 1957 HVAC & Brake parts
- 67 Cutlass Frame...Last Call
- Sun Mini Tach mounted in '70-2 Cutlass, etc factory clock blank
- 1970-72 Cutlass/442 Interior Rear Quarter Light Bezels & Lenses
- 76-77 cutlass pass door
- 1967 Toronado tailpipes ends
- Interior Door Handles
- 1971-72 Wiper Switch/Escutcheon
- 1967 330 4 barrel motor
- Center Console (1971) - For Sale
- 394 parts
- Original W-30 Emblems
- 64-67 v8 crane cam
- 1971 oai
- 1971 oai
- 394 for sale
- 1972 455 motor
- 1966 AirCleaner 330-4V
- 1965 AirCleaner 425-4V
- letter c heads
- 1970 dual gate 442 shifty
- AZ tri carb intake and carbs
- 1970 date coded OAI cleaner top
- 1970 date coded OAI air cleaner base and inner filter lid
- Cometic mls head gaskets
- 1978-80 Cutlass 442 W-30 Cruise signal
- Complete 455 built to 1972 W30 Specs GA heads
- New Edelbrock Performer 3711 Intake 330-403
- M/T Valve Covers - Cheap!!
- OLDs STUFF
- 4 barrel air clean housing
- 1993 Achieva Chassis Service Manual
- NOS 68-70 Thermal Vacuum Switch
- 70-71 W30 red fenderwell
- Turn signal switches (repaired) $30
- 1970 442/cutlass black bucket seats
- 71-72 Cruise Servo Bracket
- Another 71-72 Cruise Control Regulator
- 1971-72 Cruise Control Regulator
- 14x7 SSII/SSIII Wheels with BFGoodrich P215/70R14 Tires
- 1968-69 Dash Pad (Non A/C car)
- 588 POSI carrier 12 Bolt Type O OLDS
- 71 -72 rear bumper core $70 pickup in Dallas
- 1971-1974 Cutlass 442 Hurst Cruise Control Lever NOS
- Parting out 1995 Olds 98 3.8 FWD
- 68 69 dash pad
- 70-72 Cutlass small parts lot
- Looking for Automatic shifter knob 65 Dynamic88
- 1970 oldsmobile sport mirrors doors spolier wing
- TYPE O 12 bolt
- Door panels 71 Oldsmobile cutlass
- Hydraulic top cylinders x3
- 73-77 floor shift tilt column.
- 68-72 8 track $120
- 1971-1972 hood w/ Hurst scoop and a set of 4 14x6 SSIII wheels with trim and caps
- 394 parts
- 14x7 SSIII with bolt on caps
- rechromed 67 cutlass front bumper, other
- Small block head bolts.
- Free black cracked headrests from my 442.
- 70 OAI air cleaner top, flapper, and base
- 68-70 NOS Quadrajet Dashpot
- 68-72 Toronado/Cutlass 8-Track
- Oldsmobile dealership license plates circa 1970
- 66 Vent Window Frame - Left Side
- 400 / 425 A Heads
- 71 442 air cleaner, dual snorkel
- 73 - 77 Weatherstripping Cutlass
- NOS upper section 1973 1974 Olds mini-console
- NOS underhood light 1969 Cutlass 442 Hurst Olds
- NOS trunk light 1970 1971 1972 Cutlass 442 Hurst Olds
- Exhaust pipes from manifolds to mufflers
- Floor-shift tilt parts column.
- Rare 13" Starwires for '61-'63 Cutlass, F-85, Jetfire
- 64 F-85 & Cutlass Headlight Bezels
- 1968 1969 1970 1971 1972 Oldsmobile Cutlass Parts
- NOS Remote Mirror 1973-1977 Olds Cutlass 442 Vista-Cruiser
- W & Z exhaust manifolds for sale
- 64-72 A-Body Manual Steering Box
- 1970-77 4 spoke steering wheel
- 1964 (1963 too?) brake parts
- a piller covers
- 350 trans
- NOS luggage lamp
- 1950 Oldsmobile Rocket Hood Ornament
- 1970 350 block and parts
- Parting out 72 cutlass
- 14 X 6 JJ wheels and tires for sale
- 1970 Cutlass Supreme - Parts for sale
- Free - free - free - local pickup only - lebanon, tn 37090
- 1965 Cutlass am radio for sale
- 64-72 A-Body Rear Boxed Control Arms & Sway Bar
- 71-72 8.5 3.23 Posi Rear Axle
- 68-72 Cutlass Parts
- 1969 Oldsmobile, 442, Cutlass, Hurst Olds, N34 Black Sport Steering wheel Rare..
- Wow. I wish this radio was for a 1972.
- 10 bolt 8.5 71 72 cutlass true trac posi 3.73 complete rebuilt rear
- 68-70 350 block bored 30 over
- 12 bolt olds Moser 31 spline axles 3.91 drag street strip FUN!
- Stainless trim, L/front pieces.
- Partial core 7029251.
- Pair of lower door stainless moldings.
- Rear coil springs, 66 442.
- 67 and 68 Cutlass odds and ends
- 1966 B heads
- Used 1972 set of tail light lenses.
- nos 2-1971 lower tail light lens
- 1972 Am Fm radio. 23AFP1.
- 71 Cutlass bumpers
- Oldsmobile emboised valve cover
- 69 cutlass/442 left hood molding & fender eyebrow
- 68/69 black inner fender wells
- 68/69 dash parts
- Newly Rebuilt 1972 Cutlass 350 rocket motor and transmission
- NOS 1962 Olds Cutlass & Jetfire wheelcovers
- 68-72 Cutlass/442 lightweight hood hinge SPRINGS
- Original 4-4-2 Hurst 4-Speed Shifter
- 3.8 V6 cylinder heads
- 1952 88 2 door seats
- 1968-1969 Rally Pack Gage
- Rear brake parts.
- A/C R46S NOS Spark Plugs
- 1970 cruise control parts
- Vista Cruiser gas tank '71
- 67 442 rear boxed lower control arms
- Upper control arms for 67 442
- SSI Rims with tires
- 1970 Cutlass emblem 3 piece $25+shipping
- 1965 45 degree angle cam Iskenderian
- 68 Oldsmobile 88 and 98 8 Track player
- 65-70 olds parts
- 70-2 blue under dash lenses
- 67 CCC/Turnpike Cruiser Air Cleaner
- 65/66 1107330 442 High Torque Starter
- 67-69 1108348 Starter
- Factory manifolds, 2 barrel intake, some rods.
- Heads,intakes, etc Road trip save shipping
- Bop 8.2 rear axle gear sets
- Engle Hydraulic Cam
- 67 Cutlass Frame For Sale
- 1967 425 block
- 1964 Olds service manuals
- 1960's Olds air cleaner tins
- 1971-1972 Louvered Hood
- 68-72 AM Radio and 8 track need rebuild $150 +plus shipping
- 1967 Cutlass Kick Panels
- 1967 Cutlass Wheel Well Trim
- 1970 442/Cutlass Cruise Control lever
- 1970-1977 olds large diameter 442 4 spoke black sport wheel complete very nice!!!
- 1969 Cutlass Supreme Door Panels
- Free 68-72 parts. Must pay $10 handling fee and shipping
- 66 tri carb intake carb set up complete original 4 sale
- 67 400 390925-E block
- 1961 olds steering wheel starfire-98
- 1961 f-85
- M/T aluminum valve covers Olds V-8
- NOS 1968 Olds Toronado Hub Caps
- 66 cutlass auto console
- 1966 442 Tri Carb Set Up
- 71/72 Cutlass Stone shield
- Original Early Plain Steel Wheels for Disc brakes.
- 2 x Bendix PDR0059 Brake Drums - New
- 70-72 parts
- 1968-69 intake #398662 - J
- Complete '72 350 engine
- 71 cutlass front sway bar
- Brand new Cam, lifters and rocker arms
- 70 350 block and other motor parts
- 1971 cutlass parts
- New Sealed Power Balanced 455 L2323F-030 Pistons & Hastings Rings
- 1968 Cutlass Door
- 1968 Cutlass Tail panal
- 70 to 72 Cutlass 442 NOS Parts
- Sport lite aluminum wheels 15x4 & 15x10. W & Z manifolds and pipes
- 70-72 trumpets 2 inch inside diamter
- 64 cutlass cruise unit?
- 71/72 passenger fender
- Floor Shift Speedometer 1970-1972 Olds Cutlass 442
- Blue Ashtray Door 1970-1971-1972 Olds Cutlass 442
- Rally-Pac 1975 1976 1977 Olds Cutlass 442
- 1968 1972 Cutlass exhaust H-pipe
