PDA
View Full Version : Parts For Sale
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 [47] 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120
  1. 1971-72 power window switches
  2. 70-72 cruise control bezel
  3. 1968-69 lighter?
  4. Headlight switch
  5. 1971-72 power window switches
  6. 1970 cutlass fenders
  7. A-body clutch/brake pedals 65.00 plus shipping in USA
  8. 1970-72 Rallye Pac Parts Place
  9. 1968 Cutlass emblems
  10. 1968 parts lot
  11. 1968 cutlass post doors
  12. Olds 4 spoke sport steering wheel ---Blue---
  13. Edelbrock air cleaner
  14. nice shifter un restored dual gate
  15. Trans dust cover
  16. Hughes trans pan
  17. Toro pan
  18. 1968-69 400/455 water pump
  19. Clutch fan assembly 1967 442
  20. Woodgrain insert 1972
  21. 1968-69 delete plate
  22. console with dual gate shifter
  23. 68-69 automatic console & shifter
  24. 1972 cutlass parting out
  25. Dual gate mounting brackets
  26. proportioning valve
  27. console
  28. Wiring harness
  29. 1968-69 wiring harness
  30. 1970-72 cutlass supreme roof
  31. Posi 12 bolt
  32. Black standard 1971-72 442 steering wheel
  33. 442/Cutlass 4 speed parts lot
  34. 442/Cutlass no AC alternator brackets 1964-65
  35. 1971 4 spd parts
  36. 1953 super 88 Hardtop
  37. Neutral safety switch manual trans
  38. Steering column lockout assembly
  39. 1970 442/cutlass front bumper brackets/bars
  40. 1971-72 cutlass/442 clutch fan assembly
  41. 1968-77 original wiper motor
  42. 1969 cutlass/442 headlight bezels
  43. 1966-72 no ac alternator brackets
  44. Original 4 speed hurst shifter rods
  45. 1968 Cutlass 4 door parts car
  46. Low mileage th375
  47. 68 hood hinges
  48. 74, 75, 76 Delta 88 quarter panel
  49. New 358 build
  50. Parts pulled fro a 66 442.
  51. 66-67 Cutlass/442 dash pad.
  52. 73-74-75 Black swivel seats
  53. 1966-67 cutlass wing windows
  54. 1969 Cutlass 442 Chrome SS1 disc brake wheel - code LY
  55. For Sale alternator 1100693
  56. 70 350 W31 exhaust heat shroud
  57. 1970s.Tan 2 Spoke Steering Wheel
  58. GM pitman arm
  59. Big body posi unit #761
  60. Olds big body posi unit #250
  61. Big body posi #17-2
  62. Single spare 15 x 7 Superstock Rallye rim snap on cap
  63. T56 bellhousing sfi/blow proof fits olds
  64. 1983 - 1984 hurst olds parts
  65. 66 442 cowl.
  66. 70 Cutlass/442 hood hockey sticks.
  67. 69-70 fan shroud
  68. Shift cables 68-72
  69. 1969-72 442 hood hinges
  70. 14”x7” super stock II wheels for sale
  71. Suspension Techniques 68120 68702
  72. ISO 1968 olds 442 Passenger door assembly (or aftermarket shell)
  73. ORIGINAL W-25 442 HOOD - Excellent & Painted
  74. 68 Cutlass/442 M-20 4-speed complete
  75. 1970-72 Olds Cutlass W-31 442 W-30 Standard Hub Caps
  76. '71/2 "442" Grill Numerals and '69 Radio Fader Chrome Bezel, 67 Hood Hinge Springs
  77. W-31 Vintage Day 2 Parts
  78. turbo 425 transmission
  79. 68 442. Front & rear bumpers
  80. Holley Street Dominator Intake Manifold 350
  81. OEM rechromed 1969 cutlass rear bumper
  82. 1968 cutlass rear bumper
  83. 70 steering wheel horn pads.
  84. 4 speed parts lot
  85. 69 steering wheel.
  86. 1976 Delta 88 coupe part out
  87. H/O, 442, W30 Distributor Vacuum Advance
  88. Nice Bumper Jack
  89. NOS 1970 W31 trunk & fender scripts
  90. NOS Oldsmobile script
  91. NOS fender “S” emblem 1968-70
  92. NOS bucket seat back button
  93. 69-72 hood hinge.
  94. Clips for body side molding - 70-71 Cut Supreme
  95. 15x7 Trim Rings
  96. NOS 1966 to 1972 SS1 Center Caps
  97. 68 cutlass 442 taillight
  98. NOS Engine Temperature Sender 1953 1954 1955 Oldsmobile Cadillac
  99. 1957 Oldsmobile Front Bumper Top Half
  100. 69-72 floor shift steering column.
  101. 1972 wheel covers 15"
  102. 1964-67 wiper arms and horns
  103. 1967 Olds 98 88 Front Disc Brake Rotors
  104. Shameless plug for my craigslist parts
  105. 1966 Olds Starfire Wheel Opening Moldings
  106. 1964-66 442/cutlass manual pedals
  107. 72 am/fm 75.00 + shipping
  108. 442 numbers/conv. courtesy housings, new
  109. Parts for Sale Buckets, Bumper
  110. Sport wheel hub
  111. 1970-72 Cutlass/442 New Parts
  112. 1968 442 parts
  113. SSII bolt on center caps, new
  114. Big body Olds posi units
  115. 1967-69 4 speed shifter/handle #3759
  116. NOS Delco voltage regulator 1964-1972 Olds Cutlass 442
  117. 1970 oem conv/CS green door panel set
  118. 1968 tailpanel
  119. 1965 Cutlass 442 front blinkers
  120. New 68 cutlass interior
  121. 73 HO carb 7043251
  122. 70-72 black 4 sp console
  123. 1970-1971 W30 red fenderwells
  124. 71 442 w30 H heads
  125. 70 442 w30 F heads
  126. 71 442 W30 H heads
  127. 1970 W30 TO 3.91 rear
  128. 70 442 w30 distributor 1111979
  129. 70-71 red wells
  130. 70 442 W30 4 speed carb 7040256
  131. 1970 442 W-30 Distributor 1111977
  132. 1972 dated AM original radio
  133. 'Big Car' convertible top latch
  134. '68-'72 convertible top latches
  135. NOS Cutlass 442 and Vista Cruiser parts
  136. 1968 to 1972 NOS Vista Cruiser parts
  137. 1964 Cutlass hood Spear molding
  138. FS: 1967 Vista Cruiser/Wagon Roof Rack
  139. 1968-72 conv pump/cylinders/hoses assembly
  140. 68/69 cutlass 442 post doors
  141. 70-72 cutlass/442 door
  142. CSR electric water pump
  143. Moroso fab aluminum valve covers
  144. OPP 8qt Tig Welded oil pan & blue printed oil pump
  145. 71-72 turnsignal housings
  146. New shocks for 57-64 big car
  147. 65-69 4 speed console
  148. Powermaster mini starter 9510
  149. New Racket racing front plate
  150. 1970 F3 455 block
  151. 71-72 W30 intake
  152. OZ 200-4r transmission
  153. NOS Delco UHV distributor 1111180
  154. FS: 1970 455 W-30 Engine. $5700 (USD). All numbers correct. Panama City, FL
  155. Edelbrock intake & carb
  156. 1969 400 G Block - Burton, MI
  157. 1970 442 Distributor 1111982
  158. DX Diesel Crank
  159. Late 70s Batwing 2 Spoke Sport Steering Wheel
  160. 1971 Cutlass Bench Seat with arm rest, near Tulsa OK
  161. Olds 12 bolt used 4.33 gear set
  162. More Olds parts for sale
  163. 1968 Cutlass 442 Hurst Olds AM-FM radio
  164. NOS Oldsmobile Rallye wheel centre caps one set with Rockets, one set with 442
  165. Factory Dual Snorkel Air Cleaner Chev Olds chrome lid
  166. GI: 307 complete for sale $500
  167. Original 442/cutlass sport steering wheel
  168. 1970 NOS Cutlass / 442 Power Trunk Release Button
  169. 1968-1969 HD Water Pump 400269
  170. SF code 12 bolt with 3.90 Richmond and Mini Spool
  171. BOP TH350 with 10" torque converter
  172. 1970 unrestored original green console
  173. For Sale 425" Block-Crank-Rods
  174. Olds 260 motor parts or whole
  175. 15 x 7 SSIII Wheels - Set of (4)
  176. 68 Cutlass Trunk OLDSMOBILE molding
  177. FREE Turbo 350 Trans core
  178. 1 pair '71-2 grill mount brackets - nice and phosphate plated
  179. '71 - 2 TCS Switch/Vacuum Tree/Dist Vacuum Control Switch - Restored and nice
  180. 71-72 Cutlass fender script
  181. 1967 TH 3:90 complete rear axle
  182. 1965 442 Spinner Hubcaps and Jetstar center caps
  183. TCI Street Fighter TH350 Transmission BPO
  184. NEW IN BOX GM 10 bolt 8.5'' 3.08 RICHMOND RING & PINION GEAR SET
  185. Olds 455 forged steel crank
  186. Parted 1970 cutlass 2 dr coupe
  187. XT code 14x7" Steel Wheels / Rims
  188. 1959 Oldsmobile Maintenance Manual
  189. 70-72 cutlass supreme deck lid
  190. NOS Grill 1984 Olds Delta 88 and Custom Cruiser
  191. 66-67 Throttle Linkage
  192. Misc. Package of Parts - 71/2 Cutlass/442
  193. 1974-1976 delta 88, 98 hoods
  194. 1971-1976 Oldsmobile delta 88 4 door scuff plates / door jam trim plates
  195. 68 Big Car 8 Track Player
  196. For Sale: NOS 1974 Ninety-Eight Side Marker Lenses
  197. NOS glove box light assembly
  198. 1970 1971 1972 Trunk Light Cutlass 442 Hurst Olds
  199. 68 tail light assemblies
  200. 69 hood tongue
  201. '70 442 Tail Lamp Lenses - refinished driver quality
  202. '70 Supreme SINGLE tail light lens
  203. Door Glass Stops/72 Cutlass Original Dash Wood
  204. 55 Olds Parts
  205. 70-72 Cutlass Body Side Moldings
  206. 70-72 Cutlass B85 Door Moldings
  207. 1968-72 interior pillar covers
  208. 1970 OAI OEM hood NICE, no rust!
  209. 70 442 parts
  210. 1966 vista cruiser parts car
  211. 1970 Disc Brake Master and Distribution Valve code EB
  212. Valve covers from a 1961 394
  213. Oversized oil pan, 330,350,400,403,425,455
  214. 68 Olds Cutlass Type O Rear End
  215. Well Seasoned 350 DX
  216. NOS 69-72 GM Convert A-pillar Weatherstrip - R Side (Pass. side)
  217. 1955 and 1956 Oldsmobile parts
  218. 66 cutlass sun visors
  219. 70 Cutlass Bench Seat for Sale
  220. Bucket, Bench & Rear seat padding, repair & install kits
  221. For Sale: NOS 66 67 Glove Box Lamp Kit
  222. For Sale: NOS 66 67 442 Trunk Emblem
  223. For Sale: NOS 1963 Courtesy Lamp Kit
  224. 1985 (and other?) restored Maple steering wheel
  225. 68 Cutlass/442 parts lot.
  226. Olds 455 Crank
  227. 68-72 trans crossmember not convt or wagon
  228. 1973 Hurst Olds stripe kit - new from Fusick
  229. 1970 Cutlass 442 jack stick and ratchet
  230. 1968 Hurst/W30 & 69 W30 Red Inners
  231. Nice Am Fm radio is great working condition.
  232. For Sale not mine 68 Cutlass front bumper
  233. Misc. fender moldings.
  234. Hilborn injection 394 Olds
  235. O4B 455 intake Q/Bore
  236. Original 70 Red inner fenders
  237. A/C Brackets $50 plus shipping from Dallas, TX
  238. 1968 Vacuum Trunk Assembly (w/NOS actuator) $325
  239. NOS power trunk opener 1973-1977 Cutlass 442 Hurst Olds
  240. '69 - '70? Pwr Bucket base 4 sale
  241. Vista cruiser trim
  242. 1973 Toronado
  243. Federal mugel L2323F
  244. 1970 455 Quadrajet 7040251
  245. NOS GM valve cover gasket for newer v-6
  246. 1970 Disc Brake Calipers
  247. 1967 Olds 88/98 Speaker Cover
  248. NOS Cutlass Front Fascia Oldsmobile Emblem 81-86
  249. 1963 Oldsmobile seats
  250. 70 442
