View Full Version : Parts For Sale
- 1966 442 Center Link - Manual Steering
- 66-72 GM A B Body Bucket Seat Headrest Insert Backer
- f/S - Door Panel Watershields
- F/S - X & W Exhaust Manifolds - 66 442
- F/S - 2 Groove Alternator Pulley
- F/S - Starter Brace
- AC Alt brackets
- 70-72 Cutlass Uncut dash portion.
- 69-70 Cutlass floor shift column.
- Black sport steering wheel
- 69-70 Cutlass power trunk release.
- 1970 sx fender braces
- Trunk light
- 66 A-Body Bucket Seats for Restoring
- 1970 SX 70 Cutlass 2dr Supreme CS
- Radio trim 66 cutlass
- Very nice set of hood grills, 69-70.
- Console Insert Hurst Dual/Gate 1978-1987 Olds Cutlass 442
- 1969 442 400
- Armrests
- Barter...70-72 Vista and 4 dr patch panels BARTER
- NOS Cruise Switch + Lever 1971-1972-1973 Big Olds Cars
- 1966 seat belt set
- R12 refrigerant - 14 cans
- Posting guidelines reminder
- 1972 7a SBO heads modified street/strip
- aluminum motors?
- 1970-74 14x7 Argent Grey SSII Wheels
- Black Powder Coated SSIII's
- Bumper cores 68,69,70 442
- 70-72 cutlass/442 console
- Another set of 70-72 cutlass/442 bumper guards
- 1966 Toronado Parts
- Hood hinges 1969 to 1972 442 and Cutlass
- Conv black original sun visors 1970-72
- 442 Supreme deck lid with a wing ... LoL... wing not included
- 5 1972 442 Cutlass S grilles used and new
- Lockin hood latch with cables
- Rochester Carb 7043251
- TH400 kick down switch with bracket
- “Oldsmobile” printed valve covers
- 1970 442 fender fillers (pair)
- Original 1970-72 washer bottle
- Vista PW complete setup
- Vista tailgate PW setup
- 71-72 turn signal assy
- Throttle position switch for 66-67 jet away switch pitch transmission
- 71-72 front tirn signal lenses
- 1970-72 dash plastic housing
- Edelbrock Performer 455 Intake
- 81- 86 Cutlass Front Fascia Oldsmobile Emblem - NOS
- Boxed Convertible Frame 442 Cutlass A Body
- 1963 Oldsmobile 42A Alternator
- A body coil over conversion qa1
- 69 hardtop rear tail piece.
- 64-65-66 rear Cutlass 442 console lens (auto)
- PW PL switches & PL actuators
- 1968 only 8-Track Case & Pad Cutlass 442 Hurst Olds
- Ready to go E Heads
- this is cool, 50's see through hood....... too bad '70 didnt have one
- T44 hood lock
- SS II stock rim and BF Goodrich Hirt 225 70 14
- $50 Gauges bezel and automatic center console trim 70-72 (71/72 pattern)
- 1968 Olds Cutlass Front Bumper
- 1970-1972 Olds W-31 442 W-30 Sport Steering Wheel Near NOS condition.
- 70-72 cruise control parts
- TH350 with Torque Converter-recently rebuilt
- 1970-72 442 auto floor shifter
- NOS Door Weatherstrip Set 1968 1969 Buick Oldsmobile Cadillac Pontiac (Steele)
- 1969 bucket seat headrest
- Gauge bezel 1970
- 1970-72 black dash ashtray door
- 68/69 Cutlass/442 RR inner qrt panel.
- 1968-1969 cutlass 442 remote drivers side mirror
- 66-67 Cutlass/ 442 defrost duct.
- 66-67 Cutlass/442 lower cowl.
- Brand new ARP 1/2 Head stud kit 184-4004 for sale
- NEW 71-76 Door Weatherstrip Set
- NOS vent pipe #405087
- 1967 442 parts
- Nos key ring
- Parting out another green Delta 88 , 1975 convertible
- 1964 Jetstar 1 powertrain
- Rear bumper and lights
- Yukon YDGGM8.5-3-28-1 posi units
- Olds 350-455 gear drive
- 71 72 Cutlass Column shift steering column $75 pick up in Dallas ,TX
- 70 4 speed car 7040253
- LZ 14x7 SSI "spare"
- NICE oem OAI TOP
- 8 track unit OLDSMOBILE
- 1966 cutlass 442 upper seat springs and seat back
- super T-10, 12 bolt diff
- 70 W27 cover
- 70-72 tach
- 66 frame, 66-7 doors, etc
- Valve Cover Y-Wing Bolt - Oldsmobile Set of 20
- 70 442/cutlass right fender
- Brand new old stock USA made Perfect Circle hydraulic Flat tappet lifter set
- 1970 Olds 442 Hurst W25 Factory Ram Air Hood NICE!
- 68 W30 400/ Whats it worth?
- Hurst shifter mechanism
- 1966 NO. 3 heads for sale
- Cruise control lever/tilt lever
- 1970 442/cutlass am fm stereo radio.
- 70/72 console
- 1968-69 Console door hinge
- 66 442 washer reservoir
- 65 442 grill
- 71-72 Cutlass NOS rear bumper
- 68 A body trunk drops
- 70-72 lower fender patch panels
- Sport Steering Wheel-$120 shipped
- Seat belts from 70's big cars
- 1968-1969 Rebuilt Water Pump 398681
- 1968-1972 Rebuilt Drum Master code CT
- 1969 Hurst Olds, 442, Cutlass EA code Master
- NOS 442 Emblems - Complete Set
- 63 Cutlass red interior, driver quality
- Door hinges,Tailights etc
- Dash Bezel 70-72 and parts
- After market tachs
- ’65 330 CI Engine For Sale
- Edelbrock Aluminum Small Block Intake & Valve Covers
- Reupholstered front split bench seat from my 71 olds cutlass convertible
- 3.42 true trac posi 10 bolt 8.5 a-body rear
- Floor shift speedometer 1970-72
- 1968-72 rear reinforcement braces
- 66 442 auto console
- 1966 442 sidewinder tach dash
- 66 442 sidewinder tach
- 70-72 deck lids conv&coupe
- 1950’s Olds NOS Rocker Arm Assemblies
- Trailer hitch 70-72 Cutlass-(maybe 68-69)
- 1972 350 original iron 4bbl intake manifold
- 2 throttle body units
- 62 and 63 Jetfire engines
- 63 Cutlass and Jetfire parts
- 15 inch SS II wheels for sale
- 72 Cutlass Supreme grill emblem.
- Conv top switch harness
- 68 O type 12 bolt posi 2.78 for sale complete
- 1983 Hurst Olds Sand Gray Sport Steering wheel
- Cutting up 65 Cutlass for parts
- Timing chain cover 350/455
- Window cranks, original set of 4
- Hurst Super Shifter $300 fits '66 442 Muncie w/console
- Upper fender peak molding
- Isky valve springs and cro-moly retainers for shallow valve spring seat heads
- starters , alternators points distributors
- 71 72 door panels
- 68 intake, carb, and air cleaner
- Vista Cruiser air deflector 1968-72
- 425 Flywheel $150
- NOS snap on center caps - $50
- Oldsmobile Tall Moroso Valve Covers - $150
- Oldsmobile Tall Cast Valve Covers GMPP - $250
- Oldsmobile M/T Valve Covers with breathers $225
- Oldsmobile M/T Valve Cover unpunched logo $250
- Oldsmobile Offenhauser Valve Covers
- '71 98 Trunk Lid
- Complete 455 engine
- Sport 4 spoke steering wheel
- Oldsmobile misc new parts - dura bond cam bearings, oil restrictors, cam thrust plate
- ARP Stainless head bolt kit - Arp 480-3600 - used, great price!
- 1972 Cutlass/442 side stripe - Black
- 66-67 Factory Rubber Mat (instead of carpet)
- Tan/Saddle 4 Spoke Sport Steering Wheel With Hub
- thermostat housings , oil filter adapters , posi S spring
- 1972-73 rear lid rocket emblem NOS
- 1973-75 Vista script NOS
- 1973-75 Oldsmobile script NOS
- 1965 F85 NOS script
- 1971 Cutlass “S” emblem NOS
- 1969 442 LH NOS cowl molding
- Misc olds parts
- 355 olds hi perf runner
- M/T Mickey Thompson Valve Covers $215 shipped
- 68/69 Cutlass Center console bracket $50
- 71/72 Cutlass rear bumper NOS
- ForSale: Champion Aluminum Radiator $150
- 1973-77 Oldsmobile Gutless Speedometer & Gauges
- 66 cutlass front bumper
- 1970-72 cutlass /442 Doors
- 73 supreme pass grill . Cleaned 3 fins so will clean up good 100 plus shipping .
- 73 supreme lower center valence . NOS no box . 150
- 71 olds 88 drivers side headlight housing . NOS no box . 70 plus shipping .
- hurst shifter removed from 1970 w31
- New OPGI z-bar and clutch rod 66-67 olds
- Original GM 1964 Rochchester 2 jet 7024056 carburetor
- 8 quart pan, pump, pick up, shaft, fasteners
- 64 Cutlass F85 442 front fenders and trim
- 425 Motor with A heads
- console
- Sx sx sx
- Grille 442 numbers
- NOS NEW 442 Numbers
- OLD 442 numbers badges OEM
- Type "O" differential for Sale
- Idle up solenoid
- Olds rear window defogger 1964-1969 Cutlass 442
- Metal shield Olds 1966-1969 Cutlass 442 Power trunk hose Power antenna wires
- one oem shifter bracket
- 442 SSI wheels/ring and tires for sale
- 1968 Cutlass 442 W-30 Hurst Olds Wood Grain Steering Wheel NEAR NOS
- AC Alt brackets
- 1970-1972 Lower A/C vents w/8 track Cutlass 442 W-30 Hurst Olds
- T56 from my 66 f85
- NOS Power Trunk Button 1971 1972 Cutlass 442 Hurst Olds
- 66-67 dash insert.
- 7041251 for sale
- Offenhauser dual quad for 455
- 68 69 wheel well trim moulding full set
- 1964-72 Rear Boxed Control Arms Original Nice!
- Vintage 1960's NOS M/T Olds Rocket Valve Covers
- 1965 rochester 4 jet -for sale
- 70-72 bench set shifter 7305
- 71/72 W30 waterpump
- NEW- NEVER Used Harland Sharp S5001 Roller Rockers
- 70-72 WZ manifolds
- Opp tig welded 8qt oil pan/ hv pump
- Sheet metal
- Custom Cruiser header panel emblem
- 1980/81 Delta Header Emblem - NOS
- 70-72 ac lower dash valance
- 1968 cutlass/442 trunk drops
- 1968-72 Brake unit
- 83-84 Hurst shifter cable
- 64-72 A-Body trunk seal
- 1968 A-Body roof rail seal
- 6462137 80# sender 251 9 date
- 1970 1111975 distributor with 0B23 date code
- PUI '70 442 Convert Interior - Pearl White buckets, etc
- not broken 1972 grills
- Steering wheel, 1965 Olds 88 98 $35 plus shipping
- Pair of '68-'72 A body rear crossmember braces
- 1964 330 complete engine
- 68-70 Olds parts
- Tires and SS1's
- 1965 330 V8 and Jetaway Trans.; 15X7 SS III wheels.
- 69 F-85/Cutlass tire pressure decals
- 1970-72 ac faceplate
- W and Z exhaust manifolds
- D Heads
- Convertible top boot
- 1966/67 alternator brackets 3 piece set
- front and rear bumper brackets 1966 442/cutlass
- 4 speed tunnel flange factory original rare!
- 1966/67 dash speedo/instrument cover 4 speed
