View Full Version : Parts For Sale
- 1956 88 take off parts for sale
- M-22 Rockcrusher, 1971 Oldsmobile 442
- 66 Cutlass 442 mirror parts.
- 1975 - 1982 G M 4 prong U.S.A. made H.E.I. Control Modules
- 1969 442 W30 parts forsale
- 66-67 Cutlass/442 Convertible 1/4 panels
- 394 dual quad stick shift motor
- 1970 Cutlass 2dr Frame, Rust Free, Fits 68-72
- N-93 complete set
- Boxed lower control arms
- 1963 Starfire dash and rear window
- 63/64 Starfire taillights 63 doors
- Rocket 350 - TH350 for sale
- 69 70 Cutlass 442 Parking Light-Turn Signal Light Housings --Nice GM
- SS II Bezels
- bucket seats and 71 455 engine
- 1955-1958 NOS resistor
- 1949 - 1956 O.E.M. G.M.in the boxes Valve Lifters Set
- 1957 - 1958 OLDSMOBILE -- Upper & LOWER Ball Joints DEAL!!!!
- 68-72 Cutlass 2dr Rust Free Windshield Repair Section
- 73-77 cutlass 442
- 68-72 Cutlass 2dr Sedan Lf Inner 1/4 Panel, Rust Free
- 66-67 Dashpad and bezel insert
- 1970-1972 Cutlass/442 Gauge Set
- NOS antennas
- F/S - Water Temp Sending Unit
- 1965 cutlass air cleaner assembly
- 1971 F85 Inner Lower Stop Lamp Lens
- 71, 72 Cutlass, Vista Cruiser hood for sale. Straight, no dents. Local pick up only.
- 1965 Oldsmobile excF85 RH back up light lens
- 69 70 71 72 Cutlass 442 Clutch /Brake Pedal Assembly- Nice GM
- 69 70 71 72 Cutlass 442 Floorshift Black Steering Column
- '68-'72 one piece driveshaft, 55", 27 spline
- 1968-1972 8 track door/faceplate and knobs
- SS II Bolt On Center Cap
- 1968 Olds Cutlass 442 Black Floorshift Steering Column --Nice GM
- 1970 Cutlass $1950 'runs great'
- 1971 W30 HD fan Clutch
- 65 66 NOS Horn Cap Insert
- 4.0 aurora engine, needs gaskets
- 1957 olds liscense plate frame nos fram filter
- switch pitch th400 short tail
- LZ 14x7 SSI Rally wheels
- 1963 Starfire glass
- NOS 68 cutlass 442
- '67 and '70 rearends
- 70 442 AC Unit
- 68 Rebuilt 400 lead
- 3 455 Cranks
- NOS 1969 rear side marker assemblies
- 1970-1977 Sport Steering Wheel Cutlass 442 Hurst Olds
- 68-72 parts road trip OK to MI
- 350 / Auto core for sale
- NOS Mickey Thompson Valve Covers
- 1970 Ram air OAI air cleaner
- 68-69 water pump core
- NOS 1970-77 Horn Contact
- 1973/74 455 Distributor
- 71.72 442 dual snorkel air cleaner
- 1960 NOS lenses Guide
- 70-2 OAI lid
- 69 OAI dual snorkel air cleaner
- Fabricated Tall Valve Covers Used with breathers
- 1971-72 Cutlass/442 NOS front bumper
- '75 Cutlass Front fenders & Radiator Support
- 1970 442 AC Unit for sale.
- 1970 442 Console and His & Her Shifter for Sale.
- tri carb intake
- 1968-69 Olds auto center console & shifter
- Misc olds parts for sale. Typically 1950's through 1970's Updated 3/29/2019
- Jomar Olds stud girdles 455
- 1964 F85 Drum brake/ body trim
- 1973 Cutlass Rally gauge, speedo, reg gauge
- 70 Ralley Distributor 1111975
- NOS Delta script
- 1968 NOS headlight knob
- 394 oil pan with reserve
- 76 cutlass trunk lid
- 1970 Cutlass Supreme Bumper
- Accelerator pedal assembly 442/Cutlass
- NOS 1970 hood extension
- NOS cruise control lever
- F/S - OEM 1964-66 Cutlass/442 Steering Wheel
- 1963 Holiday 88 4 door H.T.
- 1977 Rochester Quadrajet Core
- 65 F-85 parts
- For Sale Personalized MA H/O License Plate
- 68-70 Oldsmobile 455 complete take out engine
- 70 - 72 Cutlass Radio Knob Set
- 15" SS Rims - snap-on centers
- ‘70-‘72 Cutlass/442 4-bbl air cleaner lid
- '70-'72 (?) air cleaner base - 350 4-bbl??
- 69-72 vista cruiser dual action tailgate and bumper. Rust free.
- 1967 Culass/F85 Steering Wheel
- 1967 442 Headlight Bezels
- 394 camshaft
- 350 valve covers and exhaust maniflods
- 7040202 QJet
- 70-72 A/C dash vents with hoses.
- NOS Delco Starter Solenoid 1957-1974 Oldsmobile
- NOS Delco Coil 1115202 1953-1963 Oldsmobile
- NOS Delco Coil 1115238 1964-1974 Cutlass 442
- NOS Delco-Remy 6 Volt Coil 1115400
- Oldsmobile Valve covers
- Brand new Victor Big Block Olds Edelbrock 2810 intake manifold
- dual snorkel air cleaner and manifold
- 68-72 AC compressor,lines and brackets
- 70-72 Cutlass Convertible Trunk Lid
- A/C System off ‘68 442
- 1983 GM Delco AM/FM Radio Cassette
- 1978-1980 Sport Steering Wheel tan color Cutlass 442 Hurst Olds
- W-31 balancer
- f/S - 1966 Cutlass Manual Steering Box & Pitman Arm
- 1970 Cutlass "S" 14" hub caps
- 1968/1969 Rallye Pac Gauge Cluster
- X & Y manifolds
- 68-72 Cutlass 442 Convertible Rear 1/4 Glass and Regulators-Tracks
- Magnecor Spark Plug wires for Olds 307-455 with HEI terminals - Best wires made-
- 66 Hurst 442 SHifter 3751 Square Shoulder
- 70-72 Console for
- 1968 cutlass rear bumper core
- Two 1969 Tail light bezels
- Spring sale 10% off
- Oldsmobile hub caps and auto column shifter linkage
- Stainless steel trim,windshield,cowl,etc
- "Oldsmobile 4-Spoke Tan Sport Steering Wheel Complete Kit" - FOR SALE...
- SS1 Rim 14 x 7
- 4 Spoke Olds 442 Steering Wheel
- 4 Spoke Olds Steering Wheel Complete
- Garage sale
- 70-72 Cutlass NOS Front Fenders
- 1964 NOS Dynamic 88 scripts
- 1964 NOS full size parts
- 71 72 442 Bumper
- 70 , 71 , 72 Wheel Opening Moldings
- 1971 Cutlass S Nos Grilles
- 455 block, DFW
- 1970-72 Cruise Control Switch/Bezel
- 1970-72 Dash Components
- 70-72 T44 hood latches
- 64-72 rear lower boxed control arms
- 68 442 rear bumper brkts
- 68 442 grille
- 70-72 tach & floor shift speedo
- 68/69 non ac dash pad
- 69-72 442 emblems
- 1968-71 and 1972 T-3 Headlights
- Tires and rims, ‘67 RH trim for sale
- 442 boxed control arms
- Edelbrock O4B aluminum intake manifold
- Aluminum intake manifold, Edelbrock?
- Edelbrock Performer 350 Olds
- Edelbrock Performer pn 3711
- Edelbrock Torker intake manifold
- 455 aluminum intake manifold, NEW
- 70-72 Center Console
- 31 spline 9.3 inch posi pumpkin NE Ohio
- Nos lenses
- 1964-69 4-speed Console Top Plate
- 1970 Passenger Sport Mirror Shell and Pedestal
- 1968 T 3 code 3:91 posi rear end $1500
- Hurst dual gate shifter f/s
- 455 flex plate
- Lifters
- Wire Wheel Covers '64 '65 '66 '67
- Sport steering wheel
- Olds Cam For Sale, Engle 292/300 New
- 68 odo-speedo.
- 1979 oldsmobile cutlass calais parts
- 1970 nos Cutlass S/F85/Rallye 350 grills
- Rear Frame Reinforcement Bars
- NOS Steering wheel
- F85 emblem
- Dallas parts trip
- 65 Cutlass Conv't interior red $500 + Shipihg
- Th350 bop
- 70 to 72 AC kick panels
- 69 olds 400 engine and transmission
- Olds Tri Carb Choke
- Quartz Clock Conversion Kit - S-3015
- 194 Bulbs - New & Used
- 73 Deluxe stainless buckle, dark blue web seat belts.
- Oldsmobile side mirror's
- Oldsmobile mirror's
- 1967-1972 Olds Cutlass 442 Consoles and Shifters
- 1971 455 for rebuild
- '83-'88 H/O 442 Cutlass Chrome Wheel
- 1971 1972 Olds 455 Intake 407567
- 1979 88/98 Tilt Steering Column
- Strato Bucket Strato Bench Seat Skirts - Plastic Pair
- 1966 1967 Metal Bucket Seat Backs
- 1966 Bucket Seat Backs - Pair, Set 2 of 2
- 1966 Bucket Seat Backs - Pair, Set 1 of 2
- No AC interior heater box 1968-72 442
- Misc $5 each
- 1969 442 4 speed console
- 65 442 4 speed shift lever
- 1970 442 E Heads for sale
- A Body - Cutlass BUCKET SEAT frames
- 66 olds heater control with factory air plus two dash vents
- original oldsmobile valve covers
- Chrome ashtrays, seat back buttons, PS pulley
- 1963/4 GM NOS tail pipes 88/98
- 1957/8 J2 Tri Power, complete.
- 1970-72 vista L&R rear wheelwell moldings
- 1971 Cutlass Moldings BODY side and Wheel
- Cutlass/442 69-72 parts
- Walker exhaust pipes 1968-72 cutlass 50. Per new
- Trailer hitch 1972 cutlass
- 65 F-85 FRONT WIRE harness
- 67 Cutlass Hood & 442 hood lovers
- 65 - F-85 COMPLETE dash with insturments
- Olds , REAR DEFROSTER , Heat /AC control , Switch's
- Olda - Parking , Tail , Side LIGHTS
- Oldsmobile Type O posi 3.42
- G body sport mirror
- 68-72 cutlass 442 mirror
- Ash tray clip ....
- 4 speed pedals
- Radios
- NOS 77-88 cutlass 442 G body
- BIG BLOCK "C" heads $10
- 342 Posi Rear P Type for B body
- 12 bolt posi NOT MINE $400
- 7-blade fan
- HEI distributors
- 71-72 W30 Factory Aluminum Intake
- 1946-1948 leftovers from convertible project
- 72 Engine Harness - Factory Style (Brand New)
- C heads
- Starter strip
- 66 fan spacer
- Oldsmobile + GM CONVERTIBLE visor BRACKET's
- Oldsmobile plate , interior , and trunk light's
- 66 88 2 door,rolling body,FREE
- Door seals
- ISO '70 Cutlass Window trim
- 1969 Tail Lights
- 7040251 QJet
- Beautifully restored 7042251 Rochester.
- Restored 7041251 Rochester.
- 1971/1972 Oldsmobile Cutlass passenger sport mirror
- 68-72 Cutlass 442 Convertible Inner-Outer Windshield Trim
- 68-71 GM Delux Seatbelt Set for Convertible Cutlass 442
- 69 to 72 power steering Pitman arm
- 65 cutlass taillights
- 1965 vintage Olds full size horn button
- Olds 350 4bbl air cleaner
- Carbs for sale
