View Full Version : Parts For Sale
- NOS Olds Accessory Lamp Package 1948 1949 1950 1951 1952
- 1968 Cutlass spare tire and jack assembly
- 1968 Cutlass original trunk mat
- 1968 Cutlass poverty caps and beauty rings
- SSII Wheels & Tires
- 68 Cutlass Rocket hood ornament
- 68 Cutlass front passenger turn signal
- 68 Cutlass headlight bezels
- 68 Cutlass front hood trim
- 68 Cutlass 350 air cleaner lid w/cup and wing nut
- 1971 350 KO and KB Pulleys
- 66/67 VFN fiberglass fenders and doors
- 1968 Wood Grain Steering Wheel Cutlass 442 Hurst Olds
- Cutlass 71-72 Dash, BLUE
- 1972, 71 Cutlass 442 Complete Dash
- Slowly selling off my parts
- Oldsmobile Cutlass 442 Speaker switch, years ?
- Cutlass/442 Pair rear side marker lights
- 71-72 w30 hood
- 1949-51 Olds Fenderskirts
- 1970 9K30 Dated 442 Cutlass F/85 F85 W30 W-30 Toronado Temperature Sender Switch
- NOS cutlass 442 68 to 72 right side exhaust manifold
- 70 to 72 dual gate bezel
- 70-72 NOS Trunklid
- 15" hubcaps wheel covers 70's??
- Knowlton/ Mondell aluminum heads.
- 15" olds wheel covers hubcaps spoke
- 67 Rear coil springs
- 1968-1972 AM Radio
- 1970 442 w30 auto carb 7040258
- 1969 Delta 88 front bench seat
- SS I Center Cap and Retainer
- 1970 RH Park Lens
- 68-69 quarter panel
- 70 W30 rear "TO' 3.90 or 69 TO rear
- 70-72 Cutlass Goodmark RF fender NEW
- 1970 cutlass/442 seat belts
- 1971 Cutlass supreme grills
- NOS cutlass 442 rally pack tach and gauge
- '65 Coupe Front Fenders
- Cutlass 442 3.23 posi
- Cutlass 442 axle shafts
- M21 w/ NOS case, 69 W31 rear and carb
- Nos 1969 w-30 w-31 air cleaner and 4.33 1968 factory rearend
- 1970 442 W-30 Parts
- NOS dual gate bezel and wood grain
- 1971- 1972 Cutlass/442 AMFM Radio
- 1965-66 exhaust 442 tips
- 1968-1972 Interior door handles
- Narrow track disc brake conversion kit
- 70-72 Hurst console shifter
- 442 Parts 1970 - may fit other years **with pics**
- One yr Only 15 x 7 SSII BOLT-ON center wheels
- 66 67 Cutlass/442 Doors
- 67 442 Exhaust
- 1968-72 conv ss pillar moldings
- 72 w30 x carbs
- 71-2 used rear bumper
- Rochester Quadrajet
- Orig. Shift Knob Hurst Dual-Gate 1970-1972 Olds 442
- 68 seat belts.
- 69 seat belts.
- 68 Cutlass 442 Under Dash Heater Box A/C
- 1968 Cutlass Glove Box Door
- 1968-1972 Cutlass Glove Box Light
- NOS GM Upper Radiator Hose Retaining Clip NOS 1968-1977
- DRCE - 2 block $300
- 1980 TRW Tie Rods (4)
- NOS 64/5 Vista Cruiser Tail Gate Molding
- 1965 F85 Tail Panel
- New/Unused Package Tray
- Nos Hurst Dual Gate Shifter Knob
- QJet spacers
- 1969-1973 Column Shift Neutral Safety Switch
- 1963-1965 NOS cv639 PCV Valve
- 1968 Green Right Seat Belt Retractor
- 1991 -1993 b-body air filters acdleco a1135c
- 1967 442/Cutlass Clutch & Brake Pedal Assy
- 1968-1972 Gold Arm Rest Bases
- SSII Bolt On Center Cap
- 70-72 bucket seats
- 3 H/O lic. plates
- 68 A-Body 4 speed Firewall Plate
- Olds SSII wheels and tires
- 68-72 AC firewall box
- 71/72 442 Louvered Hood $350
- 1964-1969 Console plate Rocket Emblem
- 1970-1972 Heater Control
- 67 442 blower switch needed AC
- NOS 72 Convertible deck lid
- 1970-1971 Cutlass/442 Steering
- 2 Jet Rochester Center for L69 "replacement" carbs
- Jack and Misc Parts for Carb, etc from 1971 Cutlass Supreme
- Misc. parts from '71 Cutlass Supreme (Carb parts, jack, etc)
- 69-70 Cutlass pin-on fiberglass 4" COWL HOOD
- Cutlass parts
- 70-72 NOS fenders
- A-body SwayBar , Lower control arms , Bushings
- 425
- Type O posi unit 588 casting
- Split Timing Cover
- Rebuilt Muncie M20, Shifter & Links
- 1968 Cutlass tail light lenses
- 1968 Cutlass/442 front bumper braces
- 70-72 right cutlass door
- 71-72 w30 hood
- 1968-72 442 w-30 w-31 water pump belt pulley 2 groove non a/c 350 - 455 kn
- 1970-1972 B85 Moldings
- 1976 Delta 88 & 98 Regency NOS Guards
- '71 W30 block ? MI.
- 71-72 front bumper
- Lic. plates H/O and Oldsmobile
- 66 Steelies with caps
- 1968 Cutlass Front Trim
- 1968 Cutlass Sedan
- 1971-72 Cutlass,442- Back Seat Divider Panel, Rust Free Original
- 1966 Cutlass 442 Pair of Door Trim
- 69-72 Cutlass/442 hood hinge.
- 64-70 rear bell drums.
- KH Power Steering Pulley - for sale
- 70 cutlass parts NOS . MOOG , McQuay
- NOS Olds Carb Choke Housing 1970 1971 1972 1973 1974
- GM NOS 68 Olas 98 parts
- 1968-1969 Side Maker Lights
- Original Hurst Dual Gate for early model 64-67 A body
- “RARE” W30 set up - H heads, W30 intake, W30 carburetor (7041257)
- 1969 Cutlass Supreme trunk lid
- 1969 Cutlass supreme tail light lenses
- 442 4-speed shifter
- 67 442 AIR / W-30 Heads C heads
- Mint 66 - 67 Post Coupe Drivers Door
- Complete set of five n-93 wheels
- 67 Parts
- Eng brackets AC Hoses
- Torker
- B85 door trim
- Pre 69 small block LH exhaust manifold.
- nos carb body no stamping
- 85-88 front and rear seats
- 1970 (72?) Olds Cutlass S - 442 - Hood - No Louvers
- 74-76 courtesy lights
- 69-72 Cutlass Preheater tube
- 10 bolt 8.5 cutlass 1971 1972 rear end true trac 3.42 posi
- Vista Roof Glass: OCA Wichita - Several sets including a mirror set, doors/gate
- 71 Cutlass radiator core: OCA Wichita - Very good condition $450
- 1968 Cutlass Parts: OCA Wichita - Radiator core, hood trim, bezels
- 1967 Olds 8 Track: OCA Wichita - Excellent condition,case great, unknown if works
- 71-72 Cutlass Front Bumper: OCA Wichita - No front plate holes, excellent condition
- 70-72 Cutlass green dash pad: OCA Wichita - Excellent condition
- 455 'N' 4 speed crankshaft
- Olds Cutlass Tail-Lights 1964
- 65 442 interior red Conv't
- Olds 98? Hub caps for sale
- 1967 Turnpike parts
- Used Camshaft
- 569 Camshaft
- Cutlass Misc. from Missouri
- Mondello Motor Mounts
- Rally 350 restored carb 7040250
- 68-77 SBO Headers
- 1970 Hurst Duel Gate
- Five, point style distributors.
- 455 block and crank
- 55” driveshaft, two piece, good u-joints
- Two pertronics equipped distributors.
- Original 384786 water pump.
- Original X exhaust manifold.
- Original W exhaust manifold.
- Class I trailer hitch 68-72 Cutlass
- Edelbrock O4B
- T-400 deep aluminum pan/gasket/filter/hardware....
- LF Repro W-30 RED inner fender
- Original 1977 4-spoke sport steering wheel....
- 64-65 Cutlass Convertible top latches
- 1966 - 69 442 4 speed shifter
- 64-65 Cutlass A/C Bezels and Brackets
- Flywheel
- 69 455
- '72 Olds 455 Block
- Big block torker
- 1970 hockey sticks OEM
- '77 Cutlass Supreme Hood
- Ka big block heads
- Nos 1972 supreme grilles
- Alltanator bracket for ac equipped for sale or trade
- 1967 442
- Homecoming Parts
- Holley Street Dominator Intake Manifold SBO
- 1965 Olds 98 parts need gone by end of summer
- 1970 442 engine
- Spoiler for 70-72 Cutlass 442 Aftermarket
- 1965 Cutlass Backup Lights/Lenses/Gaskets
- 1966 l-69 tri carb long oil fill tube
- Toronado air cleaner
- 1968 442 4 speed HURST shifter
- 67 cutlass convertible parts
- Crank Pulley 2 Groove
- pistons. not mine
- 1967 442 with 1966 chevelle 12 bolt posi 331
- 70-77 sport steering wheel
- 1968 -1969 Dash Ash Trays
- th400 short tail shaft and housing
- 53 - 58 Oldsmobile Radios
- 61 Olds F85 chrome accents and original manual for sale
- SALE: NOS, W30, 455, 350 parts
- Brake lines 68-69
- 1970 Cutlass Convertible Black Sail Panels
- 1971 - 72 O.A.I aircleaner
- 14x6 chrome SS1 wheels
- N.O.S #5 cylinder head
- 1966 - 69 3 speed 4 speed console top plate
- 1966 - 69 442, W-30, W-31, cutlass 4 speed console
- 1966 Cutlass hood spear
- 1970 - 72 Cutlass Supreme trunk lid
- 1963 cutlass grilles
- 1111975 Distributor 0E19
- 71/72 442 hood
- 1970-72 442 W30 Parts +
- 1970 OEM Console Shift NSS Mt Bracket
- 1971-72 A-body Speedometer
- 1967-70 New Floor Shifter Neutral Safety Switch
- hood hinges
- 1971 442 M-22 Transmission, MUNCIE
- 68 C heads and intake,GA and B heads too
- CCH code 12 bolt axle was 2.73 12 bolt posi originally
- 1965 Cutlass Convertible parts
- ‘61-‘64 air cleaner
- 66-67 Toronado air cleaner
- For sale: 69 442 Grilles
- 74-76 delta 88 parts
- New Olds Cutlass/ 442 Chrome EGR block off plate
- 68/69 Cutlass/ 442 Fuel gauge Mint
- 71/72 Cutlass/ 442 NOS Dual gate plate and NOS front console insert
- NOS 442 W30 Decal
- For sale: 69-72 rear view mirror with map light parts
- Dual gate top plate 70 to 72 Cutlass 442
- 68-69 Remote Mirror
- 70-72 Remote mirror
- 49 dealer display hood
- Parting out 1962 Oldsmobile Dynamic 88 4 door
- 71-72 Fuel Sending Unit with Return Line
- NOS 69-72 A-Body Convertible R Side Pillar Post Weatherstrip
- 68/69/70 Post ----- Arm Rests Set (front/rear)
- 1971 1972 8.5 posi axle
- 68-71 Cutlass 442 Delux Seatbelt Set—Restored GM (2-Door Hardtop)
- Rotary Asymmetrical 9,000lbs 2 post lift
- 1977-78 Toro XS glass
