View Full Version : Parts For Sale
- 1/4s
- ‘68 442 Fuel Tank with Sump
- 330 4 speed crank
- 1968 Olds Cutlass radiator cover
- 1968 Oldsmobile Cutlass Cooling fan
- Steering wheels
- NOS 1973 Olds 88 & 98 Front Bumper absorbers
- 70 to 72 Cutlass/442 Power Steering Gearbox
- 70 to 72 Cutlass/442 package tray Black FS
- 70 to 72 Hood hinges FS
- Quadrajet Carbs 7041251 7043250
- New W30 Emblems
- Some aftermarket parts for sale
- SSI OEM Center Cap
- Grant GT Steering Wheel
- 442 Rear Bumper
- 1975 Royale convertible sun visors
- NOS Horn Pad 1970 Olds Cutlass 442 Vista-Cruiser
- 57 olds rochester 4 bbl
- 1964-1970 Power Window Switches Olds Cutlass 442
- 68 Olds Cutlass Rear Bumper -Good Used GM
- 68 69 70 71 72 Set of Four 14" x 7" SS-2 Olds Rally Wheels
- G Body Hooker Headers Super Comp Engine Swap Headers 400-455 Big Block Oldsmobile
- Nice 1950 Oldsmobile Steering Wheel, Horn Cap & Horn Contact
- Washer Fluid Jar 391973 1966-1970 Olds 88 98 Toronado
- 68-72 Back of Hood molding
- 68/69 divorced choke assembly
- 1963-64 full size clocks
- 61 88 hood
- 61 starfire trunk lid
- 61 starfire hood
- Seat Belts, Not Front Rollers.
- 1970-72 455 thermostatic vacuum switch
- thermostat housing 409038 & 404632
- 68-72 Cutlass Orig.Firewall Trans Hump,Misc Section
- For Sale
- 68 Olds Cutlass 442 Bucket Seats--Recovered -Nice
- 1970 NOS f85 fender emblems
- 1966-1969 Hurst 4 speed lever & shifter assembly
- 1968-70 Hood script
- 70-72 Power trunk option
- 1968-1972 8 track deck
- 67 convertible chrome
- 67-69 console and shifter
- New 64 - 67 GM A-body 4 door & wagon weather strips and window sweeps
- 1966 442 Air Cleaner Distributor and Fender eyebrow moldings
- Mondello #7200 Roller Rocker Arm kit
- "6? - '68/9? Original Offset Thermostat Housing
- '70-'72 Cutlass/442 STEEL 4 speed shifter floor "hump"
- 1965 Cutlass Convertible body parts
- Power Window Motors L&R
- 1965 Cutlass Convertible frame
- Wheel trim
- 1967 Olds Cutlass 442 Vista-Cruiser Dash
- Ultradyne cam and lifters
- Weld pro star wheels
- NOS 1970-72 Olds 442 Hardtop Quarter Panel
- 1965 Cutlass Front bumper brackets
- SS1 cenetercaps nos door vents nos
- 1961 F85 4dr - w/ prices
- Enhance the look of your Oldsmobile with QMI fender trim pieces
- 74 Cutlass NOS nose in GM box
- 71 442 Grille
- 1970 442 W30 rear end 3:90
- 68 Cutlass hood latch/grill support?
- Parting 1966 Delta 88 2dr.
- Carpet guard 1968-72 442
- NOS 1970 442 headlight bezel RH
- 64 F-86/Cutlass Reverse Light Lens
- 63 Cutlass/F85 Backup Lens
- 70 w30 carb and rear
- Edelbrock 2711 Small Block Intake - Used
- Oldsmobile 403 Forged Pistons Old Stock
- 1968 NOS Hurst Olds 442 W30 Cutlass W31 8 track face plate 400536
- 6 volt Pertronix
- 1967/68 Hurst Shifter Rods and Tabs
- 1970/71 Passenger Side Repro Red Well
- 64-72 Cutlass Disc Brake Set Up $250.00
- W31 Balancer
- 68 cutlass console and shifter
- 68 Abody shifter cable new Gm
- 67 to 72 Automatic shifter knob
- 1965 400 short block
- 69 455 long block c heads
- NOS upper control arm bushings.
- 68-69 Cutlass 442 radio bezel.
- PEA SOUP IV Parting out 75 Delta 88 4dr hardtop
- 1971 Supreme Grills
- 14" hubcaps 80's- early 90's?
- 70-77 OEM Sport Wheel Horn Button (Black)
- Several 1978-79 Cutlass NOS parts
- 455 Fuel Pump to Carb Line
- NOS 73 to 77 Cutlass emblems
- LD Crank and Water Pump Pulleys
- '69 Cutlass/442 AM Radio - NICE original
- 1970-1972 remote mirror good/excellent
- 68 Cutlass 2 barrel Carburetor
- 68 Cutlass Parking Light RH
- F/S - Assorted Locks & Lock Parts
- 68-72 Cutlass Good used Door Hinges
- 68 Cutlass Jack Hold Down Bolt
- 64-72 Cutlass Original Heater Box W/Motor, AZ Rust Free
- 68-72 Cutlass, Original Trico Wiper Arms, Nice Shape
- Free Delta 88 Interior Parts
- 1968 Olds Cutlass Trunk Lid
- Rear axle 12 bolt cover 12 bolt ring gear Ratio 331
- Black carpet for '68 - '72 auto, brand new in box
- 68 Olds Cutlass Complete Tail Lights
- Carb 7040252
- 70-72 Cutlass Coupe Driver Door
- Carb 17058253
- Cutlass Front Bumper Impact Strip
- T-3 high beam bulb
- 68 Oldsmobile Cutlass Rear Bumper
- 68 Cutlass reverse lights with housing and hardware
- Set of 5 rims and tires $500
- 350 , 403, and two 425 motors . 4a heads B heads C heads E heads
- 1968 Olds Cutlass Throttle Bracket/Spring Air Cleaner Stud
- 1968 Olds Cutlass Original Thermostat Housing
- 1968 Olds Cutlass Front Bumper Braces
- Cruise control servo rod etc
- 72 rocket 350
- Oldsmobile vanity mirror
- 60s NOS antenna
- Olds 455 engine drag parts part 2
- 67 442 Front Springs
- 68 Olds Cutlass Alternator Bracket and Support Brace
- Milage Minder Cluster
- Floor shift Neautral saftey switch
- Dash Applique's
- Rear Defroster and Antenna SWITCH
- Rear Defroster units
- WINDSHIELD pillar COVERS
- NOS 1972 442 grilles
- 1966 cutlass 442 power steering pump/bracket
- 1972 Cutlass Grilles (excellent - nearly NOS)
- NOS Shift Knob 1967-1972 Olds Cutlass 442
- 1966, 67 400e complete engine for sale
- 68 Cutlass Rear Side Marker Lights
- 1969/70 gas filler door
- '68 455 F2 block std bore
- OEM 2-Barrel Intake System from clean-running '71 CS w/ 350
- NOS 1966 Toronado Dealership Sign For Sale
- 1962 Starfire seats
- ~69-72 Cutlass Hood and Trunk Hinges, AZ Rust Free
- Nos super stock i's center caps
- 71-72 Cutlass S Hood
- 1965 Cutlass/442 Rear Tail Panel (rechromed)
- Olds 455 engine drag parts for sale.
- 1970 1971 1972 Clock
- 1970 442 rear bumper - core
- Olds 455 block
- 1970 442 OAI air cleaner setup
- 1970 442 Gold Dashboard
- 1970 442 Muncie M21
- 1970 442 3:42 posi rear - SH code
- Hurst Super Shifter
- Upgraded Rear Suspension Items
- Day 2 Goodies
- Restored Hurst Shifter
- Restored OEM Booster
- 68-72 Gas Tank Mounting Bolts/Tabs
- 1968 442/CUTLASS WINDSHEILD PILKINGTON- NEW- SEE DETAILS Pick Up Long Island ONLY
- NOS 455 push rods, rockers & pedestals
- 1970 442 4 speed carb - 7040253
- 1968 Olds Cutlass Hood Latch Assembly
- 1968 8 track tape player housing Oldsmobile 88 98
- 1968 Cutlass License Plate Bracket/Gas Door
- 1968 Tail Light Wiring Harness
- 1968 Cutlass Original License Plate Light
- W31 carburetor intake and air cleaner fs 5000 OBO
- 1970 front seat belt set
- '63 Olds 88, slim jim
- 1970 Factory OAI hood
- 1970 W31 aluminum Intake
- 1968 FAN SHROUD p/n 398248
- 68-72 Under dash insulation pad
- Hurst T-handles
- "Oldsmobile Cutlass Saddle - Tan Complete Steering Wheel" - FOR SALE...
- Used 2711 edelbrock
- Sun Super Tach II
- VDO Tachometer
- 66 67 Cutlass 442 Glove Box Door
- 1969-1970 AMFM Multiplex Radio
- Free
- 1968 Cutlass Hood Hinges
- "Oldsmobile SSII Complete Wheel & Tire Package" - FOR SALE...
- 64-72 Cutlass/442 Moog upper ball joints.
- 1974 Olds Ninety-Eight NOS Backup Lens
- 66 cutlass /442 power steering brackets a/c
- 64 cutlass a/c brackets
- Rear body trim NOS year?
- 71 Hood Hinges NOS & Ropros
- NOS 74 Cutlass parts for sale
- 68 400
- Saginaw 3-speed Shifter
- Cutlass Bellhousing
- 1974 98 speed minder speedometer
- Crankshaft windage tray w/mtg studs
- Parts Included with this 1955 Oldsmobile Super 88
- 70-72 Cutlass Supreme Rear Deck Lid
- 215 turbo set/omahacraigslist
- 4 15x7 Olds 1970s Wheels
- Rebuilt shifter and Re chrome handle 70 71 72 Cutlass 442 with console
- NOS Dual Gate Shifter knob
- Accel gen7 ecu
- ~70-72 442 Left Full Original Quarter W/Extras
- 1949 - 1962 Oldsmobile ++ NEW ++ U.S.A. ++ Water Pumps
- 1959 - 1960 Oldsmobile ++ N.O.S. ++ DELCO Tin Can ++ Headlight Switch
- 68 Faux Wood Steering Wheel
- NOS Oldsmobile 1969 1970 Cruise Control Lever
- Olds 455 motor for $500
- 1970 442 notched valve covers
- 1957 Olds J-2 Air Cleaner J2 Oldsmobile
- 1970 442 OAI Hood.. original paint - NICE
- 1968-1972 Power Bucket Seat Track Cutlass 442 Hurst Olds
- 70 OAI Hood
- 70-72 NOS fenders / rear 1/4 / arms
- Red Inner plastic wheel wells
- 69 Cutlass/442 backup light housings.
- 68 Cutlass eyebrow chrome trim
- NOS Olds Accessory Lamp Package 1948 1949 1950 1951 1952
- 1968 Cutlass spare tire and jack assembly
- 1968 Cutlass original trunk mat
- 1968 Cutlass poverty caps and beauty rings
- SSII Wheels & Tires
- 68 Cutlass Rocket hood ornament
- 68 Cutlass front passenger turn signal
- 68 Cutlass headlight bezels
- 68 Cutlass front hood trim
- 68 Cutlass 350 air cleaner lid w/cup and wing nut
- 1971 350 KO and KB Pulleys
- 66/67 VFN fiberglass fenders and doors
- 1968 Wood Grain Steering Wheel Cutlass 442 Hurst Olds
- Cutlass 71-72 Dash, BLUE
- 1972, 71 Cutlass 442 Complete Dash
- Slowly selling off my parts
- Oldsmobile Cutlass 442 Speaker switch, years ?
- Cutlass/442 Pair rear side marker lights
- 71-72 w30 hood
- 1949-51 Olds Fenderskirts
- 1970 9K30 Dated 442 Cutlass F/85 F85 W30 W-30 Toronado Temperature Sender Switch
- NOS cutlass 442 68 to 72 right side exhaust manifold
- 70 to 72 dual gate bezel
- 70-72 NOS Trunklid
- 15" hubcaps wheel covers 70's??
