View Full Version : Parts For Sale
- 65 442 shifter adapter
- 1956 Oldsmobile factory ac dash vents
- NOS front lower control arm bushing 1969-70 f85
- NOS upper A arm bolts
- NOS Wiper switch Cutlass 73-75
- NOS Valve Springs 1937-1950 Oldsmobile
- GEAR SET vintage GM 12 bolt 331 Ratio
- 1970 W water pump axles vista tail lights
- NOS speedometer cables 1982-88 Cutlass
- 7169 manual transmission with console bent and wiggly handle
- Delta 88 R/S 4dr Quarter
- T3 bulbs
- 70 Cutlass W29 hood
- NOS 1966 cornering lens
- NOS 1968-69 Toronado frt fender rubber
- NOS rear 1/4 mldg 1968-69 Cutlass Supreme
- NOS rear side marker 1976-77 Cutlass
- NOS fade radio knob 1978-81 Cutlass
- 1970 442 parts for sale
- Anyone want my AC System/drum brakes/2bbl350/th350?
- Power steering gear
- AU intake manifold
- NOS 1976-77 Cutlass cast tail lamp
- NOS battery hold down bolts
- 1982 NOS Cutlass grille RH
- 67 Cutlass Supreme hood
- NOS 1978-80 cornering lamp lh Cutlass
- NOS turn signal/ cruise control stalk 1969-78
- NOS 1985-88 Cutlass parking lamp LH
- NOS Clock 1966 1967 Olds Cutlass 442 Vista-Cruiser
- NOS 1990-97 Cutlass Supreme rh lamp
- NOS 1987-88 G rh front fender decal
- NOS 1984-85 88 tailite assembly
- More NOS wire hubcaps 15”
- NOS wite hubcaps
- NOS rim
- 1982-1985 NOS Cutlass taillite bezel
- 1964 Cutlass F85 Parts For Sale Updated
- 68-72 AC firewall cutout
- A/C - HEAT Control panels
- 70 Cutlass hood
- 12 bolt 3.73 ring and pinion
- FS: repro 70-72 console door
- 4 Way Power Seat track with Switch For 442 Cutlass
- WV Series 58 wheels
- 1972 W-30 'vert Diecast-RARE!
- 1962 olds 394. Ultra high compression
- 1970 OEM main dash wiring harness
- 70 71 & 72 Discharge muffler support - AC cars
- 1968 olds 98 four door parts for sale
- Vista cruiser glass
- 64-65 ad 69 parts
- 1968-69 NOS Cutlass/442 rear 1/4 side marker assembly
- 1970-72 NOS Vista script
- 1972 NOS "S" emblem front fender
- 1967 NOS front fender Cutlass script
- 1976-77 Cutlass NOS Salon script
- 1968-70 NOS "S" front fender emblem Cutlass
- 1967 f85 NOS front fender moulding LH
- 4 SSII Wheels
- 1969 Cutlass rear bumper exc chrome driver quality
- Single C head
- Pair of C heads with RPM air gap BB intake
- 4-15X7 SS3 wheels
- 70-72 Cutlass/442 concours restored hood latches
- 1970 442 rear bumper
- 1961-64 NOS HT oil pump assy
- Th425 FWD Transmission FRESH REBUILD w/ shift kit
- Toronado NOS front rubber mat
- 1970-72 NOS? Cutlass decklid moulding
- 1986-1988 NOS Cutlass Supreme door pull
- 68-72 Cutlass/442 Convertible Sun Visor, Visor Brackets, Latch Receptacles, A Pillars
- 70 HLBs
- Brake Drums Bell type
- Misc olds parts
- 1970 442 W-30 4 Speed carburetor 7040256
- Hooker super comp headers BBO
- 1100733 66/67 Restored Heavy Duty Cooling Alternator
- 1967 98 trunk molding
- 1967 Olds 88/98 Speaker Cover
- 1967 vacuum canist
- Nos 66/67 o.a.i.
- D HEADS (not mine)
- 57 olds rochester 4 bbl
- 69 350 manual crank 5 heads long block
- Gmfuel tank gm37g, igm37g wi 53590 fs
- Small Block Olds - Serpentine Adapter Kit $300
- 1971-1972 GM NOS Fenders in box
- 66- 67 Door Shell, interior door parts, Trunk Lid
- 1971 455 Olds Cutlass quadrajet $350
- AM/FM stereo radio
- NOS Power Seat Harness 1961 1962 1963 1964 Olds 88 98 Starfire
- 1969-1972 Oldsmobile #407895 Fan Shroud
- (1) Olds SSI wheel 14 x 6
- Big Block Hooker Super Comp 3201-1
- NOS 1970 Seat Belt Buckle Retainer Pkg.
- 1970 Cutlass F85 W31 Carburetor
- Turnpike cruiser
- '73 455 Quadrajet Carburetor 7043251
- 1978-81 Cutlass N78 aluminum rims
- Professional Products Crosswind intake for BB
- Rear Hood Molding, 1968-72 Cutlass, 442
- 1968-1969 W-30 Hurst/Olds “D” heads
- NOS Grill Moldings 1973 Olds Cutlass
- Rally-Pac Gauge Circuit Board 1968-1973 Cutlass 442 Hurst Olds
- 1970 Olds Cutlass 442 V-C Dash Gauge Housing
- 1956 passenger fender and front bumpers.
- 70 442 auto carb / 4 speed
- 72 black seat belts
- Front disc brake calipers Delco moraine
- Parts for Sale
- LF9 Diesel 350 engine and trans
- PICK-UP ONLY: TanksInc gen 1 tank, for ?-72 Cutlass
- 72 W30 carbs
- W-27 3.91 Aluminum Rear End
- 71 cutlass th 350 yoke and 350 frame to motor mounts
- 4 Trim Rings
- Misc Parts
- Used Sport Steering Wheel Center Caps
- NOS 1970 NOS W-27 cover
- 1970 442 W-30 7040256 Carburetor
- 66/67 OEM 442 Open Element Air Cleaner
- 1966 tri carb set up-this is mine,$3000,located in mass
- 64-67 Rear Axle Snubber Mounts
- 70 NOS Cutlass 442 Rear Ash Trays
- NOS Thermometer 1972 1973 1974 Cutlass 442 Hurst Olds
- NOS Outside Thermometer 1970's Oldsmobile type Cutlass 442
- 70-72 Cutlass AC Brackets - For Sale
- 72 Cutlass Power Steering Brace GM#398669
- 1978 1979 Blue Sport Steering Wheel Olds Cutlass 442 Delta 88
- '72 Supreme Convertible Door Panels
- '75 radiator support
- 73-75 Fenders
- 1970 Cutlass wheel wells
- FS cheap upper door panels rails
- .8000 gear reduction for speed cable speedometer
- 65 dash speaker grill and emblem
- 1954 Olds 88 4 door odds and ends
- 1967 Olds 425 cid block
- Bench Seat Console
- 1971 1972 Olds Cutlass 442 Front Fender Trim and Filler
- Lower A/C vents for 8 track 1970-1972 Cutlass 442 Hurst Olds
- Olds 455 1971 short block
- 200R4 transmission
- water neck - cast iron
- NOS 88 98 toro side mirror
- 1970 455 from Lansing
- 1970 TO Posi Rear
- Column Shift
- 69’ Cutlass Convertible Trunk Lid
- OPTi clean bottle
- 63 through 66 lower steering column bearing
- 65 cutlass 442 hood hinges
- 66 cutlass 442 hood spear
- 1970 Olds Cutlass 442 RH Sport Mirror Housing
- 1970 Olds Cutlass 442 Sport Mirror
- 64-66 Black Deluxe Steering Wheel
- 3.31 Ratio ring and pinion 1968 date code GM
- 1968 Canadian 12 bolt posi
- Oldsmobile V8 Oil Pan with Girdle, Pump and Stud Kit - $1200
- P Door Armrest - Red - EXCELLENT Condition
- 71 dated seat belts pair for rears
- 1965 Cutlass Convertible Dash
- Axle
- 1970 Cutlass Supreme Bumpers
- 1975 Royale dash pad Ebay
- Hog Ring Pliers and Rings
- 1969 cutlass reverse lights $100
- NOS Oil Pressure Gauge 1954 1955 Oldsmobile 88 98 Starfire
- Edelbrock heads & intake
- misc olds items
- Small Block Intake
- timing cover
- 70-72 CUtlass 2dr Door Glass Stops, Full Set
- Newly restored 1100879 alternator
- 1966-67 Toro air cleaner
- UHV Ignition
- disc brake spindles and caliper mounting brackets
- '70+ Windshield Washer Bottle - Big Car - transparent plastic
- '68-'72 Abody Nice Driver Quality Wiper Arms+blade holders
- Oldsmobile 425 engine - $1250 Byron, GA
- Type O axle drum to drum $200
- 69 Cutlass Rear Taillight Harness
- 70-72 455 parts
- 1964 to 1972 rear sway and arms used factory OEM
- Flywheel 1968 and up 350 and 455
- Pair of rochester q jet 4bbl both for 455 olds !!
- Offy Big Block OLDS Aluminum intake manifold
- Pair of C HEADS Oldsmobile Big Block
- BOP TH350 TH400 automatic transmissions and 2 manual 3 and 4 speeds
- Pertonix kit and electronic distributor
- 389269 X exhaust manifold
- Erson Valve Covers - for sale
- 68 A - body oem HLPs
- 62 f-85 convertible in Indianapolis $350
- Parting 1964 Cutlass 2 door
- 68-72 Cutlass-Left Front Frame Section
- NOS Delco Ignition Coil 1115238 1964-1974 Cutlass 442 Hurst Olds
- Chrome 15x7 SSIII’s
- GM NOS LH and RH wheel studs Olds 1940-1964
- NOS Delco Packard TVRS Spark Plug Wire
- NOS Delco Packard Transparent Spark Plug Wire
- NOS Delco Packard 440 Spark Plug Wire
- Radio custom auto sound not working Am/FM USB CD control
- 74 SBO with trans $250
- NOS 15x7 SSIII Chrome wheels
- Mickey Thompson Valve Covers
- 71 72 442 nos
- 71 72 nos front bumper
- 70 72 fenders
- '68?-69 Big Car black w/shield washer bottle -nice condition
- 425 rotating assembly
- 71 Cutlass DVCS Thermal Vacuum Switch
- 404847 HD Water Pump - Original and Rebuilt
- '70 Cutlass/Rallye 350 w/AC or HD Generator - restored alternator
- '70 Cutlass/442 Console 4 speed woodgrain insert kit
- 1967 Olds "442" Emblems NOS trunk Repop fenders
- 455 air cleaner
- 70 Supreme Hood + Spear
- NOS 1971/72 Headlight Housings
- 70 - 72 Cutlass 442 Map Light
- 1970-72 Side Marker Lights
- Complete USED 68-72 442 exhaust system
- 70/72 fenders
- 70 - 72 Cutlass 442 convertible trunk rain gutter
- 1965 442 rear taillight cast close out panel
- W30 engine
- 1970 NOS parts
- 72 hood trim
- 65 throttle linkage
- 68-69 Fender Patches & Deck Floor Brace
- NOS Turbo 400 Transmission pan
- '71/72 Thermal Vacuum Switch - TCS "Tree"
- '70-72 (maybe '69 as well) Cutlass/442 power steering brace
- '71/'72 442 Grill Numerals - nice driver set
- 425 rocket motor ***CHEAP***
- 70/ 71 442 W30 Parts
- 71-72 Cutlass sun visors
- 71-72 Cutlass Headlight Bezels
- Driver-side alternator brackets
- 70-72 Cutlass Wood Grain Kit, Unopened
- Hurst Indy Shifter Stick + Handle
- Hurst Shifter Stick
- Muncie tail shaft
- Mickey Thompson valve covers
- 70-72 Cutlass Coupe Driver Door Skin
- '67 Toronado Complete Power Train
- 70-72 ashtray door
- 73-76 455 bare block
- 65 442 air cleaner
