View Full Version : Parts For Sale
- 1960's Merry Olds san jose CA license frames restored
- 1979 Hurst Olds - 1980 442 Steering Wheel Centerr
- 1968 -69 4 door chrome pieces
- Cleaning the garage!!
- 73 442 grills..$600
- OEM water pump
- Heater control valve
- GM Tire hold down
- Air Dam 70-71
- 1965 Misc. Cutlass parts
- NOS 66-67 Right Taillamp
- AM Radio
- 1971-72 cutlass headlight bezels
- 1970 Power Trunk Set up complete
- SS1 caps 66-67-68-69-70-71-72
- Pertronix Distributer and Coil
- Pre-Owned Gas Tank with Welder Fuel Sump for a Chevy A Body Cutlass/Chevelle (68-72)
- 70-72 Parts
- Core Support Bushing Kit
- clutch fan
- Distributor
- glove box door
- 1970-72 gauge bezel
- Pushrods
- trunk light
- 1970 head light bezels
- 1968 1969 glove box door
- 1975 gas guage with bezel
- 1967 Cutlass Supreme trim
- 1969 Cutlass tail light assembly
- Air Cleaner TOP
- M/T Valve Covers - 2 + 1 for possible garage art
- 14" Trim Rings and Bolt on Center Caps
- 1968-70 overhauled power steering pump
- Free free Hedman headers SBO, NE Ohio
- 1965 442 rear sway bar and trailing arms
- 1968 442 shifter with rods
- '69 H/O and 442 1100852 55 amp OPEN FACE alternator - rebuilt/restored
- '69-72 GM Abody Convert Stnlss Apillar W/Strip Channels - RESTORED - NICE
- FS: Various Parts from 69 442
- Relays removed from Oldsmobiles
- 1969 valve cover breather and tube
- 1970 Olds Cutlass 442 Cruise Control parts
- Make Your Muncie Cool with M22 Gears
- 1115862 Horn Relay 862 1968 Cutlass 442
- Holley Quick Fuel SS-850
- 66 door & trunk miscellaneous
- 66 hood front edge trim
- 66 radiator top plate & brackets
- Thermometer 70-72 Oldsmobile
- 1970 Cutlass / 442 / SX center console
- T400 Transmission 600.00
- 69 police or Toronado high performance distributor trade or sell
- 1970 Rear Quarter Trim 1971 Supreme Cutlass SX
- Horn button 70-72 standard wheel
- 1979 H/O 1980 442 Steering Wheel Horn Center
- 1968 Wheel opening trim 1969 Cutlass 442
- **new** be cool dual electric fans
- 76 77 cutlass seats
- NEW Champion Aluminum Radiator for G-body
- Be Cool Radiator and Spal Fan
- Custom BBO girdle and dry sump system
- Trim Moldings from the 1970 SX and a grille
- 442 Carb #7027157 1967 400,425
- Door sill plates with riveted tag 1970 2 door cutlass 442
- Cutlass Dash Pad 70 71 72
- $1,000 1970 W-30 Intake
- 1970 SX Cutlass Hood Spear
- 68-72 parts for sale
- Tilt Steering Column For Floor Shift Car, 64-65-66
- Front disk brakes from a 1970 Cutlass 442
- 1970 Cutlass 442 Bumpers and Brackets
- lug nuts
- 23AFP1 AM/FM radio
- OLDS 12bolt cover axle with Hi Way gears
- $850 1968 442 Ralley Pack
- Upper Hose clamp
- '72 cutlass supreme back seat
- '69-Up to ... Tilt Column Upper Steering Shaft
- '68-'72 Cutlass Front Drum Hub Assemblies (Complete)
- '70-'72 Cutlass Rear Marker Lights & Brackets
- '68-'72 Cutlass Parts (Updated 8/21/20)
- Flowtech 400/425/455 Ceramic Coated Long Tube Headers
- TH 400-425 trans ID tag restoration decals
- 1970 455 4 Speed carb
- Exhaust manifolds
- Holley efi sniper stealth kit 1000.00
- 1964 - 1967 GM A-body wagon roof wing.
- California blue plate
- NOS side marker light LH for 442 1970-72
- Night watch housing and button for 442RARE
- For Sale: new and used '57 and '58 Olds 88 and 98 parts
- G Body Nos Cruise Control Lever
- Power trunk release and wiring harness.
- 1967 Cutlass Console
- HEI Distributor - 1103322
- 64-77 A Body Trunk Weatherstrip
- 1966/67 A-Body Pillar Seals
- TH350 From 70 In CT - Ready To Drive
- 78 79 80 Cutlass Supreme Calais Front Fenders
- STARTERS for 442 & H/O..& most others
- 66-67 quarter glass and regulators
- 66-67 passenger door & parts
- Engine parts, 303, 324, 371, 394 & Transmissions
- 1970-1972 Black center console (complete)
- 1980s Quadrajet Carburetors
- 403 parts
- 71 olds cutlass 455 exhaust pipes
- Edelbrock Performer 455 Intake
- 1968 Cutlass Steering Wheel
- Mickey Thompson Valve Covers
- 70 TO code limited slip 402227 rear axle
- Jack hook 68-69 A body
- UHV Parts
- 79 Hurst W-30 Header Panel
- 1111980 distributor 1970 from 455 engine
- 455 stick flywheel
- 1979 Hurst Olds W30 Header Panel
- 1970-72 B85 Trim
- 1984 88 aluminium hood with hinges. Steel trunk lid
- Two Olds 455 Engines Both Standard bore
- B body Stick Changeover Parts RARE!
- 442 emblems
- FS:#8 heads 2&4 barrel intakes and exhaust manifolds
- 1964 Cutlass Tachometer $100 Zip 79364 Texas
- 1975 & later Delta 88 header badge
- 71-72 88 98 custom cruiser grille emblem
- And another used Rocket badge of unknown vintage
- Rocket badge used 60's early 70's?
- Here's another unidentified emblem ("Oldsmobile")
- DeBased Base 442 Drop for O A I clearance ram air hood
- Four blade fan with spacer and bolts
- Olds hood ornament not sure what year.
- N.o.s. 69-70 "delta" emblem
- N.O.S. O.E.M. 1975 Omega center bumper filler
- 69-72 Cutlass 442 Floorshift Steering Column-- Real GM -Redone
- Reared
- NOS 1952-53 Oldsmobile GM Rochester 4 Jet Carburetor 7004800 Dated K2
- Hi Rise Intake & Carbs
- Stainless Intake Valves
- Windage Tray
- Edelbrock Vara-jection
- 64 Cutlass Convertible Parts
- 1970 0AI 442 hood
- 4 66-442 shocks
- 1964 thru 66 Cutlass auto console
- 1114345 Solenoid 1969 Hurst OLDS DELCO
- 1971 1972 parking light housings
- 1968 A Body Vacuum Trunk Release 442/Cutlass
- 1970 442 / SX / Cutlass Supreme - parts car
- 1968-69 Power Antenna, Power Trunk
- New crosswind polished intake manifold
- NOS Headlight Housing 71/72 Cutlass
- NOS oldsmobile tissue dispenser
- Door panel rocket emblems
- Door pulls 71 Supreme
- Door jam vents 81 cutlass
- Bumperettes 71 cutlass
- Cutlass Front Bumper Impact Strip
- 40523 fuel pump with return line removed from 1969 455 engine
- 1970 B/C body A6 A/C compressor Bracket setup
- 1969 Oil Fill Tube
- '70-'72 442 Cutlass Dash Panel
- 1108333 Delco starter date code 8 M 12
- HEI distributor
- NEW OLDSMOBILE 455 Crosswind Intake Manifold
- 404847 Replacement Water Pump
- New Master Cylinder 70-72 Olds 442
- 1968/69 am fm stereo radio
- '68-'72 Spare Parts ... '71 Cutlass Convertible
- OAI Ram Air Flapper Top Assembly Inner Lid and a base that was modified
- 1971 442 Oil Fill Tube and Chrome cap 71
- New w30 emblems 70 71 72 442
- 1969 Olds 455 Long Block Intake to Pan 39M Lansing stamp on the pad
- 398681 1969 Olds water pump from a 455
- @ Groove 2 Grooves Pulley KM KJ and RING set of 3
- NEW Edelbrock 60519 Aluminum Cylinder HEADS
- 1969 455 Powersteering with brackets NON AIR Pulleys and Alt.. Brackets Pass Side
- Olds parts and paints guns
- Cutlass 442 console and shifter
- 4 speed battery tube and brackets
- 1975 Omega N.O.S. center buper filler.
- 1969 distibutor
- 1965 cutlass 442 4 speed clutch return springs
- 65 cutlass 442 battery tray brackets
- 7029251 29251 Quadrajet carb 1969 455 CORE
- 2 69 carbs 7029253, 7029254
- California Blue Plates
- 1957 Oldsmobile Super 88 Fenders for Sale
- 3.42 gear set & Posi Carrier for sale
- 1111977 1970 W-30 4 speed distributor
- Transgo TH 250C and 350C 1 & 2 Kit
- 60's Oldsmobile Air Cleaner Adapter (curved)
- 65 442 exhaust
- Nos 1970 442 4 speed
- 14x7 Poverty Wheels
- 1971 350 Engine
- Free
- NOS radio solenoid & plunger
- Edelbrock Torker intake for 455
- 1966 1967 Toronado air cleaner
- Fel-Pro Head Gaskets Fits Oldsmobile V8
- Cometic Head Gaskets Fits Oldsmobile V8
- cutlass parts center caps trim bezels dash clock
- 70 442 parts
- Parting out 1970 SX car (cutlass/442 parts)
- 64 through 66 cutlass 4423 speed conversion shifter and Console
- NOS 1975 Cutlass tail lamp bezel
- NOS front panel 1973
- NOS connecting rod bearings
- NOS Harrison thermostat 49-50 V8
- NOS 1982-1987 Cutlass trunk release pkg
- NOS decals
- 68-70 power steering pump with brackets
- 68-72 A body A/C (A6) compressor bracket setup
- NOS 1973 Cutlass Supreme/ VC header emblem
- NOS remote sport mirror 1976 Cutlass LH
- 65 license plate light
- 65 steering column parts
- Caliper brackets/dust covers (backing plates)
- 65 442 shifter adapter
- 1956 Oldsmobile factory ac dash vents
- NOS front lower control arm bushing 1969-70 f85
- NOS upper A arm bolts
- NOS Wiper switch Cutlass 73-75
- NOS Valve Springs 1937-1950 Oldsmobile
- GEAR SET vintage GM 12 bolt 331 Ratio
- 1970 W water pump axles vista tail lights
- NOS speedometer cables 1982-88 Cutlass
- 7169 manual transmission with console bent and wiggly handle
- Delta 88 R/S 4dr Quarter
- T3 bulbs
- 70 Cutlass W29 hood
- NOS 1966 cornering lens
- NOS 1968-69 Toronado frt fender rubber
- NOS rear 1/4 mldg 1968-69 Cutlass Supreme
- NOS rear side marker 1976-77 Cutlass
- NOS fade radio knob 1978-81 Cutlass
- 1970 442 parts for sale
- Anyone want my AC System/drum brakes/2bbl350/th350?
- Power steering gear
- AU intake manifold
- NOS 1976-77 Cutlass cast tail lamp
- NOS battery hold down bolts
- 1982 NOS Cutlass grille RH
- 67 Cutlass Supreme hood
- NOS 1978-80 cornering lamp lh Cutlass
- NOS turn signal/ cruise control stalk 1969-78
- NOS 1985-88 Cutlass parking lamp LH
- NOS Clock 1966 1967 Olds Cutlass 442 Vista-Cruiser
