View Full Version : Parts For Sale
- 70-72 Cutlass 2dr Orig.A Pillar Covers
- 433 gear set for Type O 12 bolt cover axle
- 1965 Olds Cutlass 442 Dog Dish Hub Caps New Car take-offs
- 1968-72 nos gm battery clamps 6270159
- Rally wheel inserts
- QA1 double adjustable shocks
- 70 442 carbs. auto and 4 speed
- NOS Oil Filler Tube
- Hurst Dual Gate Shifter
- Sport Steering Wheel 1970-1977 Cutlass 442 Hurst Olds
- 1971 1972 Cutlass 8.5 axle
- Pertronix
- Year one exhaust trumpets for sale
- 70-72 Front Sidemarker Light Brackets
- NOS 1969 1970 Olds 442 W-30 Spark Plugs
- 1967 olds 442 engine
- Nos parts in original boxes & sealed gm packages
- Nos gm parts for 88 /98
- NOS Front End Panel Ornament
- Manual flywheel 1968-72 cutlass/442
- NOS 1977-1981 Wiper Switch
- Charcoal canister bracket 1971-72 cutlass/442
- Throttle cable bracket 4BBL 1968-73
- 1970 455 HD water pump 404847
- NOS Antenna Emergency Flasher 1961 1962 Oldsmobile Cutlass
- NOS 1969 1970 Olds F-85 Cutlass W-31 Spark Plugs
- 70 Power Trunk complete with Button another one
- 1971 Cutlass S Front Bench Seat black
- NOS 1968 Remote Control Mirror Cutlass 442 Hurst Olds
- 1970 Power Trunk with 70 only button with cable
- Rally Gauge 1973 Cutlass 442 Hurst Olds
- Power trunk switch 1971 1972 Cutlass 442 Hurst Olds
- NOS Power Trunk Switch 1971 1972 Cutlass 442 Hurst Olds
- NOS Power Trunk 1970-1972 Olds 442 Pontuac GTO
- Power Trunk Solenoid 1970-1971-1972 Olds Cutlass 442
- 1967-69 cutlass automatic console and shifter
- 3.23 ratio 12 BOLT Type O Axle
- 68-72 convert top parts
- 1967 Olds Cutlass 442 Fuse Box and wiring
- 69 olds delta 88 convertible
- Heater/Defroster Delete Plates 1965 1966 Olds Delta 88
- NOS speaker grill
- NOS halogen headlight
- NOS 70-72 rear def fan blower switch?
- TCS Solenoid Delco 1114428 1970 1971 1972
- NOS GM Assembly Line 1959-1967 Oldsmobile V8 AC Air Filter 6422327 A90CW
- 1970 442 mirrior
- Misc. Olds engine parts for sale
- 1971-1972-1973 Remote Mirror Olds 88 98 Toronado Near NOS condition
- GM TH-350 BOP Short Tail Transmission -Rebuilt
- 1927 1928 1929 Flying Cloud Radiator Emblem
- Not Mine - '68-'72 Cutlass Convertible Moldings, etc.
- 1957 Olds Dash Trim FOR SALE
- Vintage NOS Spare Tire Lock 1950's 1960's GM cars
- NOS Delco Voltage Regulator 1119515
- NOS Thermometer 1970's Oldsmobile Cutlass 442 Hurst type
- 70-72 Cutlass 442 Original GM Black Dash Pad Nice
- 67 Vista Cruiser emblems
- Beautiful 70 cutlass hood
- 70 cutlass convert power window parts
- 68 w-34 parts car..Defiance Ohio $300
- 1964-1967 Rear Floorpan Crossmember
- Manual telescopic antenni
- 1964 Cutlass F85 Passenger Side Quarter Panel
- Lead: Hurst Digital Tachometer? And other pars
- Heat stove pipe W30 ram air 455
- Power Window Switches 1954 1955 1956 Olds 98 Starfire
- B/C body 3:23 posi rear end
- GM 1970 442 Assembly Line Gas Cap #2
- 1964 Cutlass F85 Clean Sheet Metal
- FREE 1969 Convertible deck lid
- 1966 Cutlass/442/Vista Body Side Molding
- Vista Cruiser Roof glass
- Lots of Black Seat Belts,Shoulder Belts,Cheap
- NOS 68 RamRod decals
- NOS Rally Wheels Center Caps 1975-1987 Olds Cutlass
- 1968 to 1972 442 Cutlass FE-2 front sway bar
- 72 Cutlass Supreme Grilles NOS & Rocket 455 Ram Air Cleaner
- New Small Block Olds 350 Pistons
- New 455 Pistons .030
- 1972 Muncie M20 Transmission
- NOS L&R 68-72 cutlass/442 door handles
- 1967 Olds Cutlass 442 Dash w/ Speedwarning + Clock
- 1970 442 W-30 4-Speed Engine complete
- 1970 to 1972 442 Cutlass Dash housing
- 1970 - 1972 F85 Dash
- 1971 Delta 88 NOS Tail Lamp Lenses
- 71 455 Complete Pullout - Houston
- NOS Rear Bumper Insert Strip 1978-1980 Cutlass
- 1975 Cutlass Fuel Tank
- 1969-70? AM/FM Stereo Radio
- NOS Fuel Tank Straps
- NOS Royal Blue Steering Wheel 1983-85
- NOS Delta 88 scripts
- 1966 442 Radiator Core Support
- After market 4 spoke steering wheel for sale
- 1968 Delmont, misc. parts. For Sale, Central NJ
- 2 OEM 70-72 A body dash clocks for sale
- 1969-70? 442 Cutlass Stereo Radio Adaptor
- 79 H/O original engine parts
- Olds 4.3 diesel V6
- 1970 cutlass/442 front and rear bumper brackets
- 1972 442 7042251 carb
- 1968/69 floor shift speedo and gauge pod
- NOS Blue floor mats REARS - 71-72 Dark Blue
- 1967-1968-1969 Cutlass 442 used auto console
- NOS U-Joint Seal Kits 1957 1958 1959 Oldsmobile
- NOS 1966 Olds Cutlass 442 Convertible Top Switch
- 70-72 dual gate
- Power steering brackets
- 10 bolt posi BOP differential SOLD
- 1969 to 3.91
- Oldsmobile SS1 Rims
- 1968 Toronado A pillar moldings
- Carpet
- Ga W30 heads
- notched valve covers
- 71 Supreme A/C center vent
- Sway bar and lower control arms for 73-77 A-body not mine
- Contact Info for Scott Winn
- SS1 14 x 7 Wheels
- Will a 64-66 Lemans/skylark convertible frame fit under a 65 cutlass convertible
- 1970 DVCS for a 442/SX/CS (distributor vacuum control switch)
- 350 long block core
- 398662 Letter J 1968 1969 400 455 Intake manifold
- 1965-1970 fullsize NOS speedo drive grease cap
- 1962-1967 NOS Cutlass interior lens's
- 404521 1970 442 4 speed intake
- 69 NOS 442 Grilles
- 1968 Olds A body trim/wx stripping
- Olds 7028252 Carb $100
- Hi torque 455 stock starter
- Th400 long tail free
- 1969 Olds Cutlass 442 Blue Sport Steering Wheel
- '68 AM/FM with reverb
- 69 Cutlass/442 Convertible Deck Lid
- NOS 69 442 Cutlass hardtop rear quarter panels
- 68 442 NOS grille
- 68 willow gold seat covers
- 3.55 Ring Pinion for 8.2 10 Bolt BOP
- 70-72 supreme convertables rear 1/4 extensions
- 455 AND 200r4 for sale
- 69-72 bucket seats
- 71 TH400 with Manual valve body 1971 OG 442 Transmission that was modified
- Hotchkis rear coil spings 1967 - 1988 A and G body
- 72 Cutlass Rear Retractable Seat Belts, Nice
- 66-72 Cutlass Bucket Seat Original Side Skirts
- 64-72 Motor Stands, W/Orig Factory Hardware
- Free C heads
- AC Fuel Pump 40711 removed from a 1970 455
- 1971 W30 H Heads
- 1970 W30 "F" heads
- SSIII center caps
- 1970 Sport Mirrors
- NOS Fenders '72 & No Rust Driver Side Door
- TM Code 12 Bolt 1970 3.42 Axle from 442
- 12 Bolt Type O removed from 1967 FIRE BIRD set up 4 leaf srings POSI 588 Gears 433
- 1970 W31 carb W30 carbs + Wanted
- 69 Cutlass NOS(?) Grills - Not MIne
- 1968-72 alternator brackets
- 8 track tape player case 1969-72 Cutlass 442 Hurst Olds
- NOS GM 1970 442 Assembly Line Correct Gas Cap
- 68-72 Cutlass 442 Plastic Air Dash Ducts
- Parting Out 70-72 Dash/Engine Harnesses, Courtesy Harness Complete. Relays, Switches
- FS: Ignition Switch, Lock Cylinder, and key for 1959 and 1961
- swivel bucket seats,black,exc. condition.$600
- Climate Combustion Control
- 1965 F85, Cutlass, 442 NOS Hood Lip
- 62,66,and 70 parts
- NOS Oldsmobile Scripts 1976-1981
- NOS 1977 Steering Wheel Blue
- 1971 cutlass convertible window sweeps
- Sun Tach Super Tach II--8000 RPM
- 455 Olds Big Block in South Florida
- NOS Blue Floor Mats 1968-1972 Olds Cutlass 442
- NOS Cutlass W31 442 W30 588 Posi, Gears, Axle
- 1970 NOS W31 intake
- 1970 NOS? W30 intake
- 1970 NOS 442 Grilles
- Low mile 350 In N.E.PA 18360
- Value & suseqient sale of a 12 bolt B+ body posi differential
- Chrome Holley and Mr. Gasket mechanical fuel pumps.
- 7028251 ‘68 Quadrajet
- 1972 Cutlass dash bezel
- 400 Trans on CL Tampa
- N.O.S 1970-72 Outer window sweeps
- BIG DISCOUNT! New Fusick '57 and '58 Olds fuel pump to carb
- SUPER DEAL: New in Box '71 to '84 Olds 88 and 98 rear Shocks!
- GREAT DEAL: '65-84 88 & 98 front Shocks!
- 1970 Cutlass 442 LH Inner and Outer Headlight Bezel assembly-- Real GM
- New OER RH Sport Mirror
- ‘71-‘72 Cutlass Grill Parts
- 70-72 rear window trim
- 1965 cutlass 442 quarter window
- '68 (maybe other years as well) Big Car Dash Knobs - nice condition
- Fuel & Brake Line Correct Fastening Bolts
- few parts for sale
- 1965 fender filler
- '72 GM Abody Nice Engine Side Evap Case Half - Original Grey Fiberglass
- Rebuilt 65 floor shift steering column
- 4 u darksiders
- 96-99 aurora parts,central mass.FREE,FREE,FREE
- NOS Olds Remote Control Mirror 403966
- Parting out 46684 mile 75' D88 coupe
- 1968 A Body Vacuum Trunk Release 442/Cutlass
- 70 Cutlass 442 CENTER RADIATOR GRILL HOOD SUPPORT
- 65 carburetors
- 65 cutlass 442 side chrome
- MOROSO Tall Chrome Valve Covers
- 1971 350 Rocket 2bbl Carb and Intake Forsale
- 70 W30 F heads +
- 64-5 , 68-9 & 75 convertible top switches
- White gm window cranks 68 442
- Gm factory parts manual
- FS: NOS 3066259 late A/G body rear window molding clips
- 65 armrest
- 65/65 glove box
- Offenhauser port o sonic 455 intake manifold
- MSD CD Ignition (5520)
- 1964 F85 Dash
- Holley 870
- Napa AC fittings 90/ straight
- Hood to cowl seal New unused
- 1964 - 1965 Oldsmobile F85 NON CONSOLE SHIFTER BOOT (384431)
- "OLDSMOBILE" stamped steel original valve covers
- Original Thermo Housing - '64 through ?
- 64-70 power window 3 single switches
- 67-72 Olds seat belt anchor bolts 1 1/4
- 68-72 A Body new hood to cowl seal
- 1972 Supreme hood F/S
- 1964-66 auto. Console
- '72 Cutlass/442, etc Top-of-Dash Pad Seatbelt Warning Light
- Regulator Covers/ GM Alternator
- Sharp Valve Covers
- 67 cutlass 442 convertible parts
- Power window OEM setup 1970-72 442
- Manuals
- 69 442 diecast
- 65 sunvisor mirrors
- 1970 water pump
- 71-72 cutlass 442 remote trunk setup
- 68 Cutlass Convertible Trunk Trim
- 70-71 black rear Door panels
- Clearing the Shelf
- 66 core support
- 67 Oldsmobile Cutlass Vaccum trunk release complete
