View Full Version : Parts For Sale
- 7040256 Service replacement carb
- .921 hydraulic lifters
- 1955 Ninety-Eight front fender moldings
- 1976-78 NOS OEM OLDS Battery Tray GM# 419962
- 1973-77 NOS OEM Oldsmobile dual gate his/hers shifter top console part
- 1970s Olds NOS Delco GM Brake Master Cylinder 5470409
- 1967 Toronado Rear Axle or Hubs. 1970 Toronado Hubs/brakes
- 1972 OEM T3 headlights F/S
- Quarter Panel Skin 1970-72 Supreme Coupe/Convertible 2-Door
- KYB KG4515 gas front shocks
- 2 barrel air cleaners
- 64 cutlass wheel well moldings
- 1964 1965 Cutlass Bucket Seats
- 7040253 70 442 4speed carb
- 2 barrel carberator
- 1965 Cutlass/442 side mirrors
- Floor shift tilt column, 1964 through 1966 Cutlass, and all 66 A body GM cars. cars
- 1982-88 NOS OEM Olds Cutlass Calais (4) Wheel Hub Cap SET Gm 552293
- 1969 power window regulators
- 1 31 spline axel for 1968 442
- 1969 Quadrajet for 350 #7029250
- NOS 1960 Deluxe Wheel Cover
- 1974-75 NOS OEM Oldsmobile Cutlass LH tail light quarter extension Gm 5945711
- 1970 console shifter bracket for neutral safety
- 1985-87 Olds NOS OEM Cutlass/442/ III CAP WITH 442 INSERTGM 22528777
- 1978-1979 nos oem oldsmobile w-30 y78 headlight lh rh bezel set gm 557380 557381
- 1971/72 AM FM Mono Radio
- 1970 Cutlass power seat back release and door locks
- New! Harland Sharp S5001 rockers
- 1965 Rochester 4GC Carb.
- 1964 Cutlass sheet metal
- 1973-1977 cutlass dash bezel trim
- 1970 Cutlass Shroud
- NOS GM Wheel Studs 1937 1964 Oldsmobile
- 1977 nos oem olds cutlass-s supreme 442 rh lh park lamp set gm# 912985 912986
- 70 olds SS1 wheels (correct LZ stamps) and tires with Stainless rings $650 + ship
- NOS power window 4 way switch
- 1968-72 442 H/O SX Exhaust Trumpets
- Two Groove Crank Pulley KJ Non Air 2 Grooves 350 455
- 67-69 Type O rear end
- Assorted Oldsmobile parts
- NOS 4 Way Hazard Flasher Signal-Stat 1958-1966 Olds 88 98 Cutlass 442
- Hood parts lot $75
- Jack assembly for 70-72 Olds Cutlass $160
- Interior hood release latch assembly for 1970-72 Cutlass
- 1966 Toronado rear window trim
- 1955 Olds 98 back seat ash tray assembly
- 1980 Cutlass Supreme LH RH HEADLIGHT BEZEL SET GM 22502376 22502377
- 1971-1975 NOS OEM Olds Radiator Fan 6 Blade GM 413977 19 inch
- 1970 Cutlass S trunk torsion springs $200
- Optional Dash Clock 1966 1967 Olds Cutlass 442 Vista-Cruiser
- NOS OEM Olds WaterPump GM 556283 FREE SHIPPING
- 64-67 control arms with spindles and drum brakes
- Oldsmobile starter
- Front Pad 1969-1972 8 track tape player Cutlass 442 Hurst Olds
- Original 1969-1972 tape player case Cutlass 442 Hurst Olds
- 1968 8 track tape player Cutlass 442 Hurst Olds
- 1964 OEM frame side motor mounts
- NOS 1971 headlight bezels
- NOS 1968 remote control mirror Cutlass 442 Hurst Olds
- NOS 1969 1970 8 track faceplate Cutlass 442 Hurst Olds
- 1968-1972 8 track tape player Cutlass 442 Hurst Olds
- 1976-77NOS Olds Cutlass Rear Bumper Bar SET LH RH GM 550580 550581 FREE Shipping
- 1970-77 OEM OLDS CUTLASS 442 Sports Steering Wheel Gm 9751836
- 350 cores
- Octania/ Rocket Science/Chris Witt 4 Sale
- 1970 Cutlass 442 Blue bucket seat headrest - pr
- 1964-1972 Cutlass/442 parts
- FS | Dual 12 inch electric fan shroud setup | cold case
- NOS 1956 1957 Oldsmobile Power Antenna Mast
- '69-'70 full size front door hinges
- 88 & 98 nos gm parts
- New Thornton Shorty Headers & Copper Gaskets
- 1964 PS Pump with pulley/bracket
- 70 442 OAI hood - Mint
- Misc 70 cutlass parts
- 1966-1969 Oldsmobile Super Stock 1 Wheels
- 1968 1969 Hurst 3 4 speed handle with 3 speed shifter base and rods
- NOS R.H. Mirror 1967 Olds Cutlass 442 Vista-Cruiser
- New Car Take-off Mirror 1970 1971 1972 Cutlass 442 Vista-Cruiser
- 1970 442 W-30 Intake 406115 "Oldsmobile 455"
- 72 442 Grills
- Pay it forward
- 1970 442 W-30 Intake 405115 "Olds 455"
- 1970 - 1972 442 W30 455 W/Z Exhaust Manifolds
- 1970 442 W30 "F" Heads
- 1970 442 W-30 Original Open Face Alternator 1100880
- 1969 -1972 455 Notched valve covers
- New 455 Comp Cam Roller Tip Rockers 1442KIT
- 1971/1972 442 W-30 W-37 Clutch
- NOS 1970 442 Cylinder Heads
- J2 NOS chrome dimple covers
- 1964 cutlass bench seat
- 1970 Cutlass front bumper brackets $50
- 70 flat ridge fenders for sale
- 64 dynamic 88 parts
- 1965 Cutlass headlight mounts
- NOS Antenna Repair Kit 1985 1986 1987 1988 Olds 88 98 modela
- Crossmember 71 Cutlass $100
- 1971 Cutlass Front coil Springs $50
- Mallory Comp Fuel Pump & Fuel Filter
- 1970 Cutlass Front upper and lower control arms $200
- 1970 442 hood tooth emblems NOS
- 1970 cutlass 442 AC oil cap NOS
- 72 455 GA Heads
- 70 Supreme Grills NOS
- more w30 parts for sale
- Various parts for sale
- Front sway bar with end links $140
- V6 heads
- E-Z-Resto Steering Wheel 1964 1965 1966 Olds Cutlass 442 Vista Cruiser
- 1948 Rocket v8 air cleaner
- 1949 olds steering column and gearbox
- olds hydramatic trans
- 1971 Cutlass S Car Front Bumper (needs re-Chroming
- Aftermarket Radiators Spectre and Summit Racing 100/140
- 625 Quikfuel Max Air carburetor $200
- 1971 Cutlass BROKEN Evaporator box with POA and new expansion valve for parts $100
- Fuel gauge and Speedometer $125 each
- 1971 Cutlass Dash gauge bezel (with H&H overlay) $40
- Steering shaft assembly x2 $100 each
- 1970 Cutlass Rear control arms upper and lower $250
- 1970 Cutlass Trunklid $500
- 1971 Cutlass Under dash A/C Heat box $150
- Parting out '65 F-85 4 door
- 69 HO carb, 71 w30 auto, 70 4 speed
- Wheels Rally
- Working Power Antenna 1967 1968 Oldsmobile 98
- 69-72 Cutlass Black Bench Seat Headrests
- FS '63 Olds stick shift bellhousing
- Bumper guards 1970-72 Cutlass and 442
- ONE 15x7 SSII SSIII
- Bolt on center caps SSII SSIII for 14 and 15 inch wheels
- Oldsmobile SSII Wheels
- '68-'72 8-track case - for cutting up, stereo, gauges, etc. Freebie
- Oldsmobile Rallye Wheels & Tires 150.00
- 1971-1972 Sport Mirror Controller Cutlass 442 Hurst Olds
- Sport mirrors 1971-72 Cutlass/442
- Tran Yoke
- 1969 455 short block
- 66 Distributor - 1111042 6G5
- Lower A/C 8 Track vents 1970 1971 1972 Cutlass 442 Hurst Olds
- 1970 AM-FM Stereo Radio Olds Cutlass 442 Vista-Cruiser
- Supercars Unlimited Beaverton Oregon
- 1965 Cutlass speaker grill
- 1962 Jetfire engine
- 17 inch, 7 blade fan for sale
- 55 amp open face alternator
- 1953 Olds starter
- Olds OLDSMOBILE embossed and then CHROMED Valve Covers
- 66 dynamic 88 posi rear
- Freedom battery caps
- 403 Cruise control kit
- Vintage Lee oil filters L-124 and P-124
- 1963-64 AM/FM radio
- '56 Olds 98
- 1955 324 Crackshaft pulley 2 grooves
- metal air dam used on 71-72 W-30 and 72 V code
- '56 Olds 98 Bendix tredle vac system
- 72 442 Carb 7042953. $1250.00
- Nos 1/4
- 1972 Oldsmobile Hurst/Olds Sunroof Weatherstripping Rubber Seals
- 1967 330/320 and jetaway trans from cutlass supreme
- Lunati Flat Tappet Cam Kit $200.00
- NOS 1962 Cutlass mldg
- 68-7? Power steering pump brace
- 68-71 starter brace
- Non ac fan blade and spacer
- 70 cutlass rear window and more
- NOS T44 Hood Lock 1970 Olds Cutlass W-31 442 W-30
- 69-72 Cutlass 442 W30 NOS RH Headlight Assembly
- NOS 1970 442 Emblems
- NOS 1969 -1972 442 decklid emblems
- NOS 70-72 W30 emblems
- NOS 1970 Cutlass and W31 emblems
- 1971 Points Distributor/Coil/Plug Wires
- NOS 70-72 Cutlass/442 hardtop decklid moldings
- OLDSMOBILE parts
- Black Sport Steering Wheel 1970 1971 1972 with horn button and hub painted red
- B 85 belt trim for sale
- Slim Jim (Roto Hydramatic 10) soft parts kit
- Nos gm 1957-58 power brake switch
- NOS GM parts for 1977-88 Cutlass 442
- Carbs for sale
- Sheet Metal Aluminum Valve Covers new in box condition
- Hedman Hedders 58150
- Quarter Panel Extension Mouldings
- '66 original manual steering boxes and master cylinder
- NOS 1970 Sport Mirror Parts Olds 442 W-30 Cutlass W-31
- 1967 442 power steering box and pump
- bumper jacks TEN BUCKS EACH
- Horn relay 1966 and flaps too
- Bumper jack setup 1968-72 Cutlass/442
- 1968-1972 8 track knobs Cutlass 442 Hurst Olds
- Some Olds Ram Air Parts & Other Parts For Sale
- Posi
- 'E" heads. Rebuilt by machine shop
- Speed O Meter cable reduction AC DELCO
- 70 supreme 2dr parts
- Power Steering gear with pitman arm
- '48 Olds Engine, Driveline & Chassis Parts
- 1970 442 W30 3.91 TO rear 402227
- 1964-72 442 cutlass nos gm parts
- 88 + 98 nos gm parts
- 1961 cutlass nos gm back up lenses
- 1965 442 - cutlass n.o.s. Gm parts
- Black sport steering wheel
- NOS 1963-64 RH tie rod
- RobbMC Sending Unit 1/2"
- Turd
- NOS Fuel Tank
- 1970 Sport Wheel Horn Button and NEW GM Contact Kit 474102
- For Sale: NOS 68 69 70 TVS Switch
- N.O.S 1968 Cutlass Rocket emblem
- NOS SSII SSIII bolt on center caps
- 77 olds shifter
- 1970 distributor
- Power Trunk Solenoid + Switch 1970-1971-1972 Olds Cutlass 442
- 1966 dynamic/delta 88 brake parts,bumper cores,posi
- 1971 1972 Oldsmobile Cutlass Louvered Hood Original Oem 442
- SBO Girdle, Pan, Pump and Stud Kit
- 71-72 right side GM fender
- 1964-77 cutlass/442 new and used parts list
- 1971 350 quadrajet stamped 7041250
- Quadrajet carburetor. Stamped 7043251
- 69 Cutlass 442 Headlight Bezels
- For Sale: 68 69 Water Pump - 400269
- Lares 201 Power Steering Rag Joint Coupler
- 71 Olds AC Delco Power Steering Pressure and Return Hoses
- Looking for a trunk lid for a 1971 convertible 442
- 442 Trunk Lid w/lock
- 1972 OEM 442 Rear Bumper w/Lens Assy's
- OEM Horn Relay And Cap
- 1969 323 and 390 posi rear ends
- Oldsmobile nationals today
- New GM W 30 Emblem?
- Some Olds Parts For Sale
- 342 12 bo;t
- 323 posi 1970 12 bolt cover
- 1970 F85 Steering Wheel with Horn cap
- 1968 Oldsmobile Cutlass/442/F85 REAR SWAY BAR - 1"
- 1968 Cutlass 442 Rocket Trunk / Deck Lid Emblem Coupe ONLY
- 1968 Oldsmobile Cutlass / 442 Rubber Trunk Mat - Gray / Black Houndstooth
- set of 15x8 AR Torq Thrusts with Radial TA 245-60-R15 -tampa local only
- NOS Power Antenna Switch 1968-1969 Cutlass 442 Hurst Olds
- NOS Power Antenna 1973 1974 1975 1976 Oldsmobile 88 + 98
- NOS TCS solenoid
- Nos 1970
- new 1970 OP 442 air cleaner decal
