View Full Version : Parts For Sale
- 69 Cutlass 442 reverse light housings only - no wiring
- 1970 dated ported vac switch
- Dallas TX parting out 403 and TH350 from a Firebird
- 2-68 442 rear bumper cores 1- 68 cutlass front bumper core
- 1968-69 Climate Control w/ac
- 1963 Starfire 1964 Dynamic 88 Parts
- 67 442 rear bumper
- NOS 1968-77 Rally Pac Oil Pressure Sender
- oil pans
- 215 hilborn intake
- Misc parts 70-72
- Valve cover bolts " E " stamped with valve cover brackets
- a / c bracket 350 400 455
- 68-72 Cutlass conv windshield stainless moldings
- 68, 69, 70-72 4 bbl air cleaner lid only - original cond
- 1968 Cutlass 442 curved oil fill tube for a/c cars
- 442 W30 Cutlass W31 Hurst Olds “TO” 3.91 Rear
- 66 425 Engine Complete, Running, Less Carb
- "1963 Oldsmobile F-85 NOS Door Edge Guards Set" - For Sale...
- Parting out 1975 Delta 88 conv.
- Custom Sport Steering Wheel 1969 Cutlass 442 Hurst Olds
- 70-72 Hood pins. 64-65 glove box doors
- New Reproduction W30 Emblems
- Used Chrome Exhaust Trumpets
- 1970-77 NOS Sport Steering Wheel Contact
- Fuel Filter NOS NEW no package... Metal Heavy Fuel Stone Filter
- New dual spring valve spring kit
- Later 70’s nos cruise control package
- 71 72 Cutlass 442 Headlight Buckets-Brackets Set
- T400 Hughes 2800 stall converter
- 1966 f85
- 1968 69 nos w30 w31 raim air nos gm clamps
- 1969 442 parts ,conv assembly,booster line,bresther,frame supports 69 bumper support
- NOS Delco Remy D1007/1876600 Point & Condensor Unisets
- New 11" Brake Booster / Master Cylinder (Disc)
- BeCool Cooling module - A-Body/Auto Trans
- 1964 - 1966 Auto Floor Console
- 66 88/98 front bumper ends,convertible top motor
- 1964 Cutlass Choke Stove
- 4 sets of nos Delco points/condenser
- WTS 1970-72 olds cutlass/442 deck lid
- #23 394 Starfire cylinder heads 583832
- Dark Blue Horn Button 1970-1977 Olds Cutlass 442 Sport Steering Wheel
- GM door and trunk locks NEW - "H" Code 69 73 77 81
- 68-72 Cutlass Conv ash well panels - lowers
- 455 Oldsmobile Edelbrock RPM Air Gap Intake
- Comp Cams solid roller camshaft
- 1968 Cutlass 442 Front Headlight Buckets with Mounting Brackets
- 1968 69 70 Cutlass 442 Waterpump and Crank 3-Groove Pulleys
- 1971/72 cutlass/442 power trunk option
- 1964-1965 Cutlass Convertible Frame $2000
- Olds 455 complete engine $800
- NOS Outside Mirror 1961 1962 Olds F-85 Cutlass Jetfire
- NOS Coolant Outlet Pkg. 1964-1970 Oldsmobile V-8
- 69 70 71 72 Cutlass 442 Radiator Top Plate--Real GM
- 68 69 70 71 72 Cutlass 442 Alternator Brackets--GM
- Nice console for sale (not mine)
- 1948-1951 NOS gauges for sale
- Chrome PS pump (brand new)
- olds 88 98 AM-FM MPLX
- 47 and earlier 8 cyl engine for sale
- 1965 Cutlass 442 Reverse Lights & Block off Plates
- Street/Strip Race V8 HEI Distributor
- 1971 98 parts lot
- Batten aluminun heads stage 2
- Olds parts
- oil pan 455
- "Oldsmobile Poverty / Dog Dish Hubcaps - Set of 5" - For Sale...
- 425 Crank for stoked diesel
- NOS Trunk Lid Rocket Emblem 1967 1968 F-85 W-31 Oldsmobile Post Coupe
- Restored red 1967 cutlass/442 steering wheel
- NEW Oldsmobile mud flaps snow splash guards NOS
- J&S 5 main gurdle (canada)
- 1970-72 Convertible/Supreme quarter panel
- NOS oil filters PF24 and PF 30
- GM horn contact gm 474102
- 1958 Oldsmobile Used Dash Brake Signal Indicator
- 1957-1958 Oldsmobile New Front Wheel Cylinders
- 1954-1956 Oldsmobile Manual Antenna Base & Bezel
- 1959-1962 Oldsmobile NOS Courtesy Lamp Pair
- 1957 Oldsmobile Lower Tail Light Trim
- 1955-1964 Oldsmobile Dual Exhaust S.S. Block Off
- 1956 Oldsmobile NOS Power Brake Check Valve
- NOS 1968 Oil Filter Cutlass 442 Hurst Olds
- Rare oldsmobile batten nascar parts
- 1968-72 cutlass/442 inside heater box unit
- 1967 Cutlass seat belts
- 67/68 4 piston disc brakes
- 12 bolt type O 3:08 gears..excellent shape
- TH350 trans with 7K miles. $500. With torque converter, cables, insp cover, etc. TN
- CV axles 1971 toronado
- NOS Trunk Lid Emblem 1967 Oldsmobile Delta 88
- NOS P/A MAST 1960's 88 98 Starfire Vista Cruiser Cutlass 442 hurst Olds
- 69-70 (maybe other yrs ?) 350 exhaust manifold shroud
- 1968 - 72 Cutlass / 442 conv windshield header finish panels
- turbo 400 metal trans flywheel cover
- 1968 Cutlass 442 inner fender to core support metal supports
- 1968 69 442 parts
- 70-72 Parts
- 1957 Olds 98 right front fender - $500.
- CLEAN Console Shifter Base 1970, 71, 72 Olds Cutlass 442
- 1970 - 1972 442 ignition coil 216BR
- 1970 - 1972 Cutlass / 442 Dash Housing
- 1970 - 1972 Dash pad
- Muncie M22 transmission
- pit free small block exhaust manifolds with shroud
- 1964-65 Rear inside vertical window moldings
- Cruise control lever
- Headlight/ molding
- Engine for Sale Olds 350
- .921 lifters usa made
- Nos 69 h/o parts
- 1970 Toronado Dash Pad
- "Original GM Coil, Bracket and Capacitor" - For Sale...
- "Oldsmobile Air Cleaner Assembly, Breather and Etc." - For Sale...
- NOS parts
- 1968 Cutlass Rear Bumper $80
- Th400
- Rallye Pac Gauge 1970 1971 1972 Olds Cutlass 442
- 442 1971 72 Oldsmobile Decklid Spoiler OEM
- 1965 oldsmobile 442 engine
- 66 and 67 442 hood and trunk moldings
- 1968 Dash wiring harnesses
- 88-91 delta 88 Radiator
- New double roller timing chain set
- 68 a body radiator automatic trans
- 68 442 glovebox door
- 68 Armrest backs
- 87 307 smog controls air pump distributor
- 68 olds 98
- Drag race Turbo 400 transmission and converter
- Lower Dash AC vent assembly
- OEM OLDS Chrome valve covers
- Parting out '65 Cutlass
- 1970 cutlass door
- 371 Connecting rods
- 455 timing chain set
- NOS Sport Mirrors
- NOS 1959-1962 Courtesy Lamp Pair
- Taylor Spark Plug Wires
- 1980’s? Cast Iron Exhaust Manifolds
- New USA Race parts- Billet crank and Howard’s ultimate Billet rods
- NOS Sport Mirrors 1974 1975 Olds Delta 88 Custom Cruiser
- 1965 Cutlass/442 battery tray
- GM A Body 1964-72 2"dropped spindles & brakes complete.
- 1970 Assembly Line Lug Nuts
- 1970 442 - NOS front bumper & NOS 70-72 fenders
- nos oil pan in the GM box 400 -425 - 455 except Toronado
- 7043250 carbs X 2 for parts or make one good one
- 7042250 carb - parts only
- 350 - 400 trans dust cover - plastic - used GM part
- 1964 engine and dash harnesses
- 1972 am fm mono radio
- SOLD 1966 Cutlass Drivers Side Quarter Panel, $300 plus shipping or $250 if picked up
- 442 parts Colorado Craigslist NOT MINE
- 1969 h/o starter 1108333
- OAI W-30 foam ring freebie
- Olds 455
- 70-72 Hood release
- Power trunk release
- Olds 15x7 bolt on cap wheels
- Illustrated Parts Book 1966 Olds Cutlass 442 88 98 Toronado
- Safety Sentinel Repair 1962 1963 1964 Olds 88 98 Starfire
- ‘71 Rochester Quadrajet Carburetor
- 1968 Cutlass tail light assemblies
- 68-72 NOS GM vista cruiser
- Nos gm parts in original gm boxes
- NOS GM parts - 1964-72 Cutlass 442 H/O
- NOS GM parts - 1977- 88 Cutlass 442 H/O
- NOS GM 1957-58 power brake switch
- 1970-72 Cutlass SSII Wheel 14X7JJ
- 1961 394 engine - disassembled but mostly complete
- 69 442 rear bumper brackets
- open face alt ...no stamping on case
- Willow Gold paint, reducers and clear for sale.
- 455 Oldsmobile Procomp Aluminum Heads (Bare)
- RC 15 and RC 27 radiator caps and oil cap F/S
- Brand new throttle cable set F/S
- free E head SSI and SSII wheel
- NOS white PF30 oil filters 1968-1972 Cutlass 442 Hurst Olds
- 1965 1966 442 Chrome air cleaner FRONT to the BACK
- MASTER Cylinders
- Olds radios
- 1965 Cutlass Seat Belts
- FS:71/72 W29 Hood Black
- 1950 Olds 88 oil pan, fuel pump, gaskets, hub cap
- Crower 56264 cam
- 1970-1971-1972 Olds 4 spoke steering wheel
- 1967 Olds Cutlass convertible right side quarter pannel (SoCal)
- 1968 Wood Wheel Hub Cutlass W-31 442 W-30 Hurst Olds
- 1965 Cutlass parts
- Power Trunk Switches 1970 1971 1972 Cutlass 442 Hurst Olds
- NOT MINE !!! 258 carb for sale
- '68-'72 SSII & SSIII Wheel Bezel Rings
- 1966-67 nos gm oldsmobile belt
- 4 Nice 1972 1973 Oldsmobile F85 Cutlass Omega Wheel Covers/Hub Caps
- 1975-1977 NOS OEM Cutlass, 442, Hurst Olds w pulse delay wipers GM# 419319
- NOS 1965-1971 Original Parts Book Cutlass W-31 442 W-30 Hurst Olds
- 71-72 Cutlass NOS Front Bumper Brackets
- 65 442
- Set of 14" Tires and Rims
- 70 442 steering column (box to wheel)
- 15inch trim rings
- Fresh ground 455 crankshaft
- 1968-1972?? NOS OEM Rear Window Defogger Kit GM 983387
- 1973-77 NOS OEM Cutlass Series Rear window Defogger Kit GM 983387
- Treasure trove - 21 boxes of Series 76 parts $2,000 OBO
- A-body 8.5" Corporate Rear ('71-'72 Buick/Olds)
- BEREJIK Olds trunk lid emblem 442 W-30 Cutlass W-31
- 1973-77 Cutlass 442 F85 NOS OEM Opera Window mouldings GM 9727043 -44
- Wanted- 74 Cutlass Supreme 350 exhaust manifolds
- Aeromotive in tank carb fuel pump kit
- Three Spoke Steerimg Wheel
- Gauges anyone ?? Rally Packs
- 1968 Olds 442 Cutlass Rear Backup Lights Excellent GM Parts
- Rust free 1969 cutlass/442 passenger door
- 68-72 Cutlass 442 Convertible Top Motor--Excellent real GM part
- 15” trim rings
- NOS GM 1976-1977 Cutlass Front Fenders Pair
- Sport Steering Wheel 1970 1971 1972 Cutlass 442 Hurst Olds
- 1968 Wood Grain Steering Wheel Cutlass 442 Hurst Olds
- NOS Oldsmobile Power Antenna Switch Early-Mid 1960's
- NOS Delco Coil 216 B-R 1970 Olds 442 W-30
- New cam and lifters. OE#406768
- New L2323F Standard Speed Pro/TRW USA made
- Black 4 Spoke Steering wheel, hub and cap Nice!
- Core carburetors $75 ea plus shipping photos added 11/14
- Used Olds parts
- "Oldsmobile Ultra High Compression Air Cleaner Decal" - NEW - For Sale...
- 66 88 convertible/2 dr hardtop doors and more.FREE
- FS Oldsmobile 403 Engine
- 1968 Cutlass 442 Tailight Harness-- Good used GM
- Edelbrock ML 0E6 6x2 Stromberg (Not Mine)
- NOS 1970 Oldsmobile "Cutlass" fender emblems 230948
- 68-72 Cutlass 442 Convertible Pillar Chrome Weatherstrip Channels
- 1970 71 72 Cutlass 442 Doorjamb Windlace--Convertible-Black
- FS Oldsmobile carbon fiber valve covers
- NOS Under Dash Maplight 1960's Oldsmobile
- Nice leather wrapped steering wheel
- 10 bolt 8.5 OLDS Cutlass axle 1971 1972
- 1966 Cutlass hood insulation, new
- 1970-1972 SSII complete rim set (5)
- 1970-72 GM NOS front fenders
- Nos parts olds gm
- Cruise Control Servo 1970-E1971 Olds Cutlass 442
- 68 442 OG Air Cleaner Assembly
- Ex. original 1968-1972 Hurst Dual-Gate shift knob
- NOS R.H. Sport Mirror 1971 1972 Cutlass 442 Hurst Olds
- Near NOS Dog Dish Hubcaps 1970-1972 Olds Cutlass W-31 442 W-30.
- WTB 69-72 Floor Shift Steering Column Bowl Non-Tilt
