View Full Version : Parts For Sale
- Passenger side alternator mount
- 15 x 7 bolt on wheel
- 1969 1970 Olds F-85 W-31 Steering Wheel
- 70-72 cutlass trunk trim
- NOS moldings 1973 Hurst Olds, 442, Cutlass "S"
- NOS CUTLASS 442 Rally WHEEL CENTER CAPS
- NOS 1966 Olds F85 Post Coupe Trunk Script 442 W-30
- Hubs for the dub ($20 Oldsmobile Hubcaps)
- Hoods in Dallas,TX $150 each
- 1973 Cutlass H/O S front upper header panel
- 1970 Cutlass Rallye 350 jack
- NOS woodgrain
- 1969-1972 bucket seat headrests
- 70 W30 Carburetor 7040256
- Sport Mirrors
- Olds parts only
- 69 Cutlass 442 Doors - Pair w Trim and Glass
- 66 88/98 front bumper ends.FREE. located in mass
- 70-72 442 standard black steering wheel
- NOS Rally-Pac Clock 1968 1969 Cutlass 442 Hurst Olds
- 15” ss3 rims
- 1970 Hood Extension Olds Cutlass 442 Vista-Cruiser
- Delta 67-68-69-70 black arm rest bases with ash trays
- 1968-69-70 2 door hardtop arm rest bases - black
- 1970-72 OEM 4-Speed Console Bezels
- 1970-72 350 Heat riser pipe
- 68-72 Cutlass hardtop mirror base covers
- 1955 Olds 98 AC under hood firewall box.
- 1970 442 Cutlass Factory 8 Track
- Courtesey Light harness and lamps 1970 Cutlass 442
- 1969 Cutlass Auto Console
- 1968-69 Hurst Dual Gate shifter
- NOS R.H. Mirror 1971 1972 Olds Delta 88, Royale, Custom Cruiser
- Ninety Eight emblems
- 1969-1972 Cutlass horns LOUD and proud
- 68-72 Cutlass hardtop sunvisor supports
- 68-71 Map- light rear view mirror - needs restored
- 1968 Cutlass jack hook #1
- 1954-55 Heater parts and ducts for sale. Parts added 2/27/2022
- Center Cap Emblem 1969 Sport Steering Wheel Cutlass 442 Hurst Olds
- 1970- 1972 Cutlass headrests sets x3 $120 set
- Edelbrock 400 425 455 Torker
- Wiper Motor Transmission Arm Assembly
- Derale 17 inch Heavy Duty Flex Fan
- Boxed Upper and Lower Control Arms
- 1964-1974 Buick A-Body Disc Spindles
- 64 Cutlass Parts
- 70-72 NOS weatherstrips + 4 speed console.
- NOS GM Underhood Lamp Unit Cutlass 442 88 98 and Toronado
- Ross racing 394 trans conversion
- 330 engine
- NOS 68 69 70 Oldsmobile hood script 230474
- 1965 Starfire throttle assembly parts
- Olds jetfire center console for sale 18470
- Trumpet tips
- 73-77 Cutlass parts. Not mine
- NOS R.H. Mirror 1970 1971 1972 Olds Cutlass 442 Vista-Cruiser
- NOS Underhood Lamp 1977-78-79-80-81 Olds Cutlass 442 88 98 Toronado
- 1967-75 Used Visor Vanity Mirror
- 1971/72 Front Hood Molding
- Sport Steering Wheel with grain 1970-1977 Cutlass 442 Hurst Olds
- 70-72 black rally wheel
- 65 Glove Box Door
- Complete MSD Ignition System
- 69 442 Air cleaner/carb
- 15x7 Bolt on wheel
- 1970-1972 Cutlass Center Console LINERS
- Olds 455
- 1973 hood hinges
- 1966-67 hood hinges
- 1966 headlight bases
- OB 67 Variable Pitch Th400 Trans Case and Valve Body
- "Oldsmobile NOS Door Edge Guards" - For Sale...
- 70-2 convert or all 4-door deck lid
- 1938 Oldsmobile Standard Radio- $100
- 1964-66 GM Flarestat Hazard Unit
- NOS 1970 Cutlass / 442 W-27 Cover 406785
- NOS Power Trunk Opener Parts 1968 1969 Cutlass 442 Hurst Olds
- NOS Metal Firewall Vacuum Reservoir 1960's Cutlass 442 Hurst Olds
- hood for sale(not mine)
- NOS 442 W-30 Air Cleaner Vent pipes
- NOS Oldsmobile 350 to 455 valve lifters
- NOS 1970 Cutlass “S” emblem Rallye 350
- "Steering Wheel, Horn Button and Hub Kit" - NEW - For Sale...
- 1973 Cutlass / 442 Rallye Gauge Rare
- "Air Cleaner, Air Filter, 2 - Breathers and Carb. Base Adaptor Set" - For Sale...
- Air cleaner - lid & base
- 59-69 vacuum power lock switches
- Fenders $150 each various years
- NOS AC GM Oil Pressure Sender for gauges
- 1970 442 hood moldings "hockey sticks"
- throttle actuator
- 1972 Cutlass 442 and others--GM "Guide" 12 inch Day-Night Rearview Mirror--
- NOS Antenna Mast 1963 1964 1965 1966 Olds Cutlass 442 Vista-Cruiser
- Power window setup
- Clock delete (2) $20 each plus shipping
- 1964 & 1965 Cutlass scraps for patches. Updated w/more added 2/19/2022
- 1968 rear bumper (2) $150 ea
- 1967-1969 Auto console parts lot $750
- 7029240 1969 Buick 430 carb $150
- E heads 1970 Cutlass cores $150 set (3) available
- 1970 - 1972 Cutlass rear window defogger
- Black Sport Steering Wheel 1980 442 W-30 1981 Cutlass Calais
- Black front arm rest bases - no chrome - F85?
- Black rear arm rest with ash trays 68-69 Cutlass 442
- GM NOS L+R Grills 1980 Oldsmobile 442 W-30
- For Sale: 1970 Olds 455 W-30 Aluminum Factory Intake Manifold
- Transmission tailshaft housings
- 1978 1979 Blue Sport Steering Wheel Olds Cutlass 442 Delta 88
- 1963 Olds parking lights
- 1960 Oldsmobile Fenderskirts
- 68 weather stripping
- 1970-1972 cutlass 4 barrel accelerator cable and bracket
- Cruise control switch (cores) tested didnt see lights
- 1970 Toronado hood latch parts
- 1969 and 1971-72 Cutlass core supports for patch panels
- 1968-1972 speedometers and fuel gauges
- NOS Temp sending unit switch for standard gauges
- Rare NOS Oldsmobile Pete Jackson Gear Drive
- NOS Cutlass / 442 yoke.
- New Olds Cutlass/ 442 EGR block off plate
- NOS Cutlass/ 442 oil dipstick tube and nice used indicator.
- NOS 1968 Cutlass/ 442 valve cover Grommet
- Sbo harmonic balancer
- Sport Steering Wheel 1978-1979 Olds Cutlass 442 Delta 88 1969-1987
- Fan Shrouds big car 71-76 3 available
- Flywheel covers plastic
- 1968 manual quick ratio steering box- restored
- 69 Cutlass 442 Hurst Olds NOS water outlet
- NOS GM Mini-Console 1970's Olds Cutlass 442 88 98 Toronado
- TVS Switch $175 shipped
- 1971 -1972 cruise control turn signal levers
- 1972 Cutlass supreme hood with street scoop and filter assembly
- Original 1970 W-30 Intake and Complete Fuel Injection System
- NOS Quarter panel
- Used 1968-72 Exterior Door Handles
- 1971 Cruise Control T/S Lever Olds Cutlass 442 W-30 V-C Near NOS cond.
- 405233 Hurst Olds Intake manifold
- Radiator top plate 1970-72 Cutlass Supreme
- 1970-1972 Automatic console insert
- 68-69 D heads
- pistons and rods 455
- 1970 OAI Hood Lock Plates
- Fuzz
- 71 Delta 88/98 NOS Grill Molding RH
- 1971 Olds Cutlass Frame for sale $700.00
- 1968-70 NOS GM DASHPOT 442 H/O W Cars
- 1970-1972 A body OEM speedometer and clock for sale
- NOS Ignition Coil Delco 1115238 1964-1974 Oldsmobile
- Nice Olds die cast original thermo housing
- 1971-72 New Repro Grille Mounting Brackets
- 1971-72 New Repro Park Light Lenses
- NOS GM Rally Wheel Center Caps 1975-1987 Olds 442
- 66 Cutlass hood, AC parts, rear bench seat
- Olds Hurst Dual-Gate Shift Knob Daka-Ware 1968-1975
- 1970-1972 A body brand new tic tock tach for sale
- 1970-1970 OEM A body speedometer, fuel. gauge and clock for sale
- 71-72 Coolant overflow tank, not complete #410008
- WANTED: Holley street dominator olds 455
- 403 sbo
- New Repro 1972 Tail Light Lenses
- Stock SBO cam, lifters, rockers, etc
- 403/ sbo harmonic balancer $35
- 1970 Cutlass/442 front bumper
- For sale 350 olds engine
- 1970-72 New Repro Quarter Panel Extensions
- New 1970-72 Chrome Remote Drivers Mirror
- 1970 open alt 1100880
- 70-72 NOS parts
- 69 253 service carb
- 68-69 ve1 impact strip
- Nos 69 antenna
- 15X7 Trim rings
- New 1972 Supreme Grilles
- 1947 Olds Engine Overhaul Parts & More
- FREE tissue dispenser
- '71 Supreme, parting, trims and small bits
- cruise control parts with dash switch / wood grain also 4 spoke sport steering wheel
- For Sale 70 to 72 Cutlass non dual gate shifter
- 455 Speed Pro pistons std bore and rings
- Hurst Dual-Gate top plates 1970, 71-72, 73-75 Cutlass 442 Hurst Olds
- 67 Delta 88 (Free+ Freight or pick up)
- For Sale 70 to 72 Accelerator cable and 4 bl carb bracket Very Nice!
- 1968 455 engine
- 1970 hockey sticks hood trim cutlass 442
- "F" Head with 51 Julian Date
- Olds rocket breather
- NOS GM Static Collectors
- NOS Barn Find 1970-1972 Sport Steering Wheel Olds Cutlass W-31 442 W-30
- Glass Windshield Washer Jar and Mounting Bracket
- 1968 Horn Cap
- 1969 Cutlass/442 Shift Indicator Lens New
- 1970 Sport Mirror Gaskets New
- 67-69 Cutlass/442 Auto Console Shift Seal New
- 68-72 8 track knobs and bezels
- 1970 Olds Rear End
- NOS Accessory Thermometer 1972 1973 1974 Cutlass 442 Hurst Olds
- NOS Accessory Thermometer Olds 455 GMC Motorhome 1973-1978
- NOS 1970 Sport Mirror Door Panel Escutcheon Cutlass W-31 442 W-30
- 1970 Oldsmobile NIGHT WATCH option Cutlass 442 Vista-Cruiser 88 98
- Water pump cores + parts
- #8 heads under 2k mi. Since rebuild $500 obo
- 1969 442/Cutlass Ash Tray Door Assembly
- 74 350 4bbl factory intake manifold $50
- New 1968-72 Front License Plate Bracket
- 66-67 442 Parts including 67 442 hood
- 64-67 68-72 Heater Cores
- 1968-72 Heater Hoses New
- Switch pitch / kickdown switch
- Early 70's NOS Nite-Watch Switch - Not Mine
- 65 cutlass/442 two tone moldings
- Edelbrock Performer 455 intake and 750 Demon
- 1975-85 Delta 88 and 98, 1977-90 Custom Cruiser Gauges
- FS '79 Delta 88 98 Tilt & Tele column
- FS Olds B Body 2Dr & 4Dr "Vent Shades"
- FS '88-'90 Custom Cruiser Pass Power Seat Track
- 1967 F85 Steering Wheel
- Wiper Motor
- 1970-1972 OEM gauges for sale
- Brand new Tic Tock Tach for sale
- Oldsmobile/Chevy Valve Cover Spacers Cutlass 442 Hurst Olds
- 1967 442 Rochester 7027156
- OLDSMOBILE Trunk Mat
- NOS 14" Trim Ring for 75-76 Starfire
- Transmissions - TH350 & TH400
- 1973 Rally Pac Guage + Floor Shift Speedometer Cutlass 442 Hurst Olds
- '70 - '72 Assorted Trims
- '70 - '72 quarter panel inner backing pieces
- 69-70 parts
- 1965 Tail Lights
- 1969 Head Rests
- 70-72 glove box doors
- 70-72 dash lower vents
- 70 442 grills
- 1968 cutlass 8 track player
- 1970 Post car side door trims
- Electric Trunk Release
- '70 - '72 lower dash vents w/ 8 track option
- 1965-67? A-body steering column for 3 on the tree
- 8 Track 8-Track 8track Player with housing
- Rally wheel hub
- 70-72 power trunk option
- 70-72 8-track housing
- 68-72 GM A-Body door hinges
- 1970 442/Cutlass AM/FM radio
- 70 442/Cutlass front turn signal housing
- 70-72 cutlass supreme rear quarter extensions
- 7040253 service replacement carb
- olds 455 block - local pick up only
- 68-69 floor console
