View Full Version : Parts For Sale
- 1967 442 Harrison radiator
- 8 track tape player 1968-1972 Cutlass 442 Hurst Olds
- 1970 Cutlass, 442, W-30 “like new” wire harness
- Super Nice Restored - '71/2 Front Turn Signal Housings
- '70-72 Original Hurst Dual Gate Setup - nice restored unit
- 1964 Saginaw 3sp
- 455 main stud set W/ windage tray
- 12 bolt oldsmobile YUKON DURA GRIP POSI UNITS 28S
- 1966 Olds Cutlass 442 Trunk Lid
- 68-70 442 Cutlass 19" Factory Original Clutch Fan
- 70-72 Cutlass/442 Factory Power Trunk Lid Release - Complete
- Pennzoil oil filters
- Snap on center caps
- Wheel center caps
- 68-72 horn pads
- 1968 and up 350 and 455 manual transmission flywheel
- FS: Bucket seat piping kit
- 1967 442 Hood
- 1970 Olds Cutlass 442 BLUE survivor 8 track pad
- 1970 Olds Cutlass 442 Tape Player Rear Support and Ground Strap
- 1970 Olds Cutlass 442 8 track tape player knobs
- 1970 8 track faceplate Oldsmobile Cutlass W-31 442 W-30
- NOS Outside Thermometer 1972 1973 1974 Cutlass 442 Hurst Olds
- 65 Cutlass fenders
- 67 442 front parts
- 1972 Cutlass S rear seat cover
- Oldsmobile 455 4 bbl. cast iron intake manifold #410448 D1B For sale
- Big Block 455 Intake manifold
- TVS Vacuum Tree Temp controlled switch
- 68 Toro parts
- 70-72 Black wells
- 64-66 Cutlass Tilt Steering Column
- 64-67 suspension parts
- Factory OE Olds Intake Manifolds. 330 4bbl, 350 2bbl
- Edelbrock Torker 455
- Original Rear Hood Molding, 1968-72 Olds Cutlass, 442. Professionally polished
- Sold King Pin set for 1939 through 1956 Oldsmobile $50 Sold
- 1969 Big block 455 bored to 468 short block
- NOS Ignition Switch Lock 1969 Oldsmobile Cutlass 442 Hurst Olds
- 1966 Dash Wiring Harness Olds Cutlass 442 Vista-Cruiser
- New Edelbrock 61025 Aluminum Heads
- NOS LH Parking Lamp Assem. 1964 Olds 88 98 Starfire
- 1949-1952 Olds Holiday Parts-Lot for Sale
- 70-72 survivor washer bottle.
- 70 rally pack
- 70 W30 intake
- 71 / 72 black seat belts
- 70 doors and decklid
- Seat Belts - standard - nice
- 1968-1971 Drivers Side Alt Set Up w/ AC
- 425 Short Block
- 70 Cutlass/442 Deluxe seat belts
- Deluxe Seatbelt Assortment
- W-body console door
- 71-72 Cutlass Flat Stock Hood, Rust Free
- 68-72 Cutlass New Repro Lf Shoulder Skin
- Misc. Olds parts list
- 67 442 4-Speed Hump
- Front Turn Signal/Parking Lamps - 69-70 Cutlass/442 - Refinished Originals
- Replated/Refinished original Rear License Plate Lamps - 68-72
- 1970 NOS RH Roofrail Weatherstripping - Cutlass S and 442
- nOS GM Fan Belts
- FS: 1970 442 PUI front and rear seat covers
- 64-65 Cutlass Gas Tank
- Ford 9" rearend for 64-67 GM A Body
- 1965 442 frame & trans crossmember
- 1965 Cutlass/442 Sport Coupe Interior NEW PUI
- 455 Long Block
- 1966 Olds 425 engine intake to pan B Heads
- "E " heads
- Pair of 69 Tailights Nice!
- 1960-87 GM car and truck Brake or Fuel Line Frame Clamps & Bolt
- Optional Trunk Light 1964-1969 Cutlass 442 Hurst Olds
- 1964 Cutlass
- Olds aluminum intakes
- White PF24
- 1966 1967 Olds Vista-Cruiser padded arm rests
- 1964 Cutlass Glass
- 1971 442 AUTO cast Iron Intake Manifold 407567
- Doors, fenders, bumpers, less than 125 each in Dallas,TX
- 1964-72 Olds 442 Cutlass Hurst Car & Parts ID Manual Restoration book
- V8 Engine Spark Plug Wire Set, AC Delco- Packard
- 1968-71 Oldsmobile 442 W30 88 98 Cutlass F85 455 fuel pump 70412
- 68-72 Cutlass/442 small block battery trays
- KM two-groove pulley, slightly bent
- 1971 Cutlass radiator top plate, 3 row, unrestored - NE Ohio
- ‘72 Oldsmobile radiator for sale
- 1970 4 Core Radiator Top Plate
- Camshaft Melling MC1287
- Comp Timing Gear Set
- New(other) Summit Radiator
- nos left outer wheelhouse 68-69 Cutlass 442 hardtop
- Air Conditioner Oil Charge for R-12
- 1969 SSI disc brake wheels -- code LY
- 1970 rear defog blower fan
- 1970-72 ash trays
- 66 w30 tri power air cleaner for sale
- O-Type 5.00 Gear Set
- O-Type 3.91 Gear Set
- 1970 NOS 4.66 Gear Set with OTC Paperwork from Olds
- Center Caps SSIII Delta 88 1977 1978 1979
- 1966-1967 Dash Pad + Glove box door Olds Cutlass 442 Vista-Cruiser
- M20 trans and bell housing
- Cam off a 1970 442 W-30
- 1969-72 GM Oldsmobile Cutlass Hardtop Trunk Lamp with Bracket, Screws, Wire- NOS
- 1967-72 GM Original 11’ Delco Moraine Power Brake Booster
- 70 front fender trim pc
- 15" SSII wheel trim
- 1966 4bbl. Carb Choke Olds Cutlass 442 88 98
- Tri Carb ! 3 separate lots !! Parts...
- Set of 4 1970-72 OEM Marker Lights
- 1966 1967 CHECK VALVE Power Brake Booster Cutlass 442
- '48 Olds Drivetrain Parts
- Glove Box 1966 Olds Cutlass 442 Vista-Cruiser
- 1100879 W-31, Rally 350, etc Alternator - Will be rebuilt/restored if sold
- 1967 titled 442 Sport Coupe Shell with doors/trunk lid only
- 1939 Olds Water Pump - $30 (Westerly, RI) - not mine
- 1957 1958 Olds Switches Power SEAT WINDOWS ANTENNA CONVERTIBLE TOP COURTESY
- FOR SALE Daves Small Body HEI distributor
- Rare 1970 NA9 California Emissions Complete Setup
- 1980 Toronado Steering Wheel
- For Sale: '68 Cutlass/442 Quarter Panels
- 70 W30 parts for sale or trade.
- 69 Red wells and air cleaner - pick up only - Ky
- '68-'69 442/W30/Hurst Olds Choke Housing-Restored Original
- Free to a good home
- '70 442/Cutlass Headlight Housing Pair - rehabbed
- 68? - '72 Convertible Piston Covers Set - Original and RESTORED - Super nice parts
- Yukon 8.2 BOP Posi
- 1970 442 Delco Coil 216B-R 216 BR 1115216
- Aluminum Thermostat housings Numbers 1 and 2
- NOS 1970 Olds Sport Mirror Door Panel Escutchion Cutlass W-31 442 W-30
- NOS 1970 Sport Mirror Olds Cutlass W-31 442 W-30
- 76 350 108,000 miles purrs like a kitten, in delta 88 4dr
- 1970 Olds Cutlass 442 SSI wheels
- Oldsmobile Valve Covers & Oldsmobile Scripted Air Cleaner
- NOS fuel cap locking ring 1971-74
- Olds 455 engine parts, exhaust, headers
- 77-78 Front Clip/Grilles
- 1970 W-31 Fender Badges - Mint Used Set
- NOS 1970 W-31 Tailpipes with GM Tags - Also fits V8 F-85 / Cutlass
- 1970 Black Bench Seat Headrests
- FS: new reproduction SX fender emblems
- 1971 72 Cutlass 442 12" Front Armrests-- Real GM--Nice
- 68-71 Cutlass 442 Black Seatbelt Set - Real GM
- 68-72 Cutlass 442 Convertible Rear Access Covers--and More
- 65 98 center hub cap
- Brackets from a 1970 442 Console garden variety automatic shifter NOT dual gate
- 65, 98 fender skirts
- AC rebuildable fuel puel pump
- 68-72 Cutlass 442 Convertible Top Lift Cylinders and Lines-- Real GM
- PROFORM Holley "RACE" Carb
- New without the box OLDS 455 Torker
- OLDS 455 04B Edelbrock Intake not cut for Quadrajet
- OLDS 455 Air Gap aluminum intake manifold POLISHED
- 425 crank
- Olds 1968 400 and Turbo 400 trans
- 1967 Olds 442 K66 UHV parts
- NOS SSI Center Caps 1966-1972 Olds Cutlass 442
- N.O.S 74-75 Delata 88 conv quarter driver side
- NOS Hurst Dual Gate Shift Knob 1968-1972 442 Hurst Olds
- Various 64 F85+big block+power steering parts going to Nats
- 1964 F85 rear axle stuff
- Valve Cover Breather
- 1970 Distributor
- OEM type Side Body Moldings
- Buffing Supplies - Wana buff your own Stainless?
- 1972 455 olds engine rebuilt $5500.00
- 68-72 GM Delco Remy Wiper Motor Cutlass 442
- 403 engine and 350 tranny out of 79 trans am
- 72 Gauges
- 1970 Rallye 350 Carburetor 7040250 dated 0930
- F/S - Dial Back Timing Light
- 1966-1970 B Body Convertible Top Frame
- NOS 1976-77 "Cutlass Supreme" Fender Script
- 64 trim(complete) + fenders- Heading to Nats
- Blue Sport Steering Wheel 1978 1979 Olds Cutlass 442 Delta 88
- NOS L.H. Grill 1979 Olds Delta 88 GM 562551
- NOS LH GRILL 1982 1983 1984 1985 1986 Olds Cutlass Supreme
- 1971 W30 air cleaner base
- Air cleaner top
- 1970 442 4 speed drive shaft & misc parts
- 17" Wheels & Tires 70 442
- Restored 1970 W-31 W-350 Aluminum Intake - Vapor Blasted
- Small Block Forged Crankshafts
- 1970 cutlass 3 core radiator top
- Manual Steering Box
- Big Block Intake '72 4 Speed
- '69 Hood Inserts
- Big Block Torker Intake Manifold
- Big Valve "C" Heads
- "G" Big Block Heads
- Chrome Valve Covers New
- Holley Aluminum Valve Covers
- '69 H/O Hood Scope
- Blems!
- 404847 X Water Pump
- NOS rear floor mats - blue
- JORNEY WITH OLDS 2004-14 Can deliver to Nats
- 1970 Cutlass 442 driver side mirror $215 shipped
- 1970-1972 rear defrost parts lot $175
- 1967 AM-FM Radio dash side plates Olds Cutlass 442 Vista-Cruiser
- AM-FM Radio 1967 Olds Cutlass 442 Vista-Cruiser
- 68-69 olds floor shifter
- 1973-1977? Cutlass Vista Cruiser Wagon Right Rear Wheel Opening Molding
- trade 1971 W30 engine and hood for W27 rear diff
- 70-72 parts
- !968 G block
- 1965 Oldsmobile 425 $3k
- Selling Off All My Extra Small Parts
- 70+? Toronado Emblems
- 1970 442 block and heads
- Olds Pertronix Billet Flame Thrower Distributor
- 1970 Speed Minder Floor Shift Speedometer Restored and Works
- C heads, Torker, Edlbrock $250 for all
- Head Light Buckets and Rings buy the box FULL
- GF432 432 Gas Fuel Filter with GM Delco box
- Fuel Pressure Regulator HOLLEY and Earls Super Stock lines with some fittings
- 1965 Oldsmobile Starfire Exhaust Tip/Extension
- 1965 Starfire Super Deluxe N96 Wheel Disc
- 1965 Starfire Tail Light Lenses
- Various Cutlass/442 Parts
- 1968-72 Cutlass/442 Quarter Window Weatherstrips
- 1970-72 Cutlass/442 Back-up Lens
- Harrison radiator tanks XQ IF M date code
- Hood latches $65
- NOS 70-72 Cutlass S & 442 door edge guards
- Comp Cams 42-224-4 Camshaft For Sale
- '67 Bucket Seats
- 66/67 Cutlass Instrument Panel Bezel
- 64 cutlass frame
- CompSolidFlatTappet
- For Sale: NOS 71 72 8-Track Applique - 407816
- Sanderson Shorty Headers
- olds 455
- For Sale: NOS '69 '70 442 Hood Extension Emblems
- NOS 1968 W-30, 1969-70 5400, 6400, 98 403983 Fan Clutch in GM Packaging
- 1970 400548 Original Factory Hose with Stamping 68-72 350
- 70-72 Cutlass Left 2dr Sedan Door Shell
- 1969 Cutlass rear bumper
- NOS Cutlass front bumper
- 455 race engine
- Garage Sale
- Parts at the Nationals
- 15” trim rings for 15” x 7” wheel
- 69 Cutlass/442 hood excellent cond
- 1963 Olds Starfire Complete Front Clip
- Late66/67 rally pack with harness
- Sale 68-72 Cutlass A/C Interior Boxes
- Sale 68-72 Cutlass Wiper Trans Assembly, Hidden or Non
