View Full Version : Parts For Sale
- '71 and '72 Headlight Bezels
- Bracket and the tube from a 1970 with 455 BaT Cable to Starter
- (2) NOS Delco Voltage Regulators 1118897 12V Neg. Ground
- NOS Delco starter solenoids Made in USA 1114458 1114496
- NOS 72 Cutlass S & 72 Cutlass Supreme -H/O grills
- 71 Cutlass Supreme L.H. Pot Metal Grill
- 70 Sport mirrors (need work)
- 70-72 NOS LH Door Skin Cutlass 442
- Dash Pot with bracket DASHPOT for sale
- 72-76 alternator brackets
- 68-71 power steering pump brackets (2)
- Dog Dish Hubcaps
- 70-72 Cutlass 442 black inner fender wells
- KC KF pulleys - 3-groove w/AC 68-70 (?) 350, 400, 455
- NOS 442 SSII Bolt on Center Caps
- 1972 442 Front Grills
- 71-72 Cutlass 442 Front Bumper Brackets
- 69-72 Cutlass/442 Condenser Brackets
- 69-71 Front Alternator Bracket A/C
- 69-71 PS pump Brackets
- NOS Vacuum Trunk Opener 1968 1969 Cutlass W-31 442 W-30 Hurst Olds
- GMPP Tall Cast Valve Covers
- Walnut Grain Sport Steering Wheel 1964 Starfire Jetstar I Olds 98
- NOS power steering pump
- 1968 442 complete O type 12 bolt rearend
- 425 intake and 2 barrel
- 1969-1972 convertible misc
- VERY low mileage 442 TH400
- Billet 4.00 Stroker D/DX Cranks
- Notched Valve Covers - Super Nice and Ready For Final Paint
- Single Armrest Base/Pad - '69-72 Abody
- '69 - '72 Cutlass/Abody Armest Bases and Pads - nice survivors
- 12 bolt cover OLDS Type O axle housing Removed from a 1967 FIREBIRD
- Manual Trans throttle linkage
- Restored '70-2 Cutlass/442 Reverse Lamps
- 1970 1971 Oldsmobile Deluxe Steering wheel
- 1970 XT Steel Wheels - Set of 4 - Twilight Blue
- 1970 442 grilles (Fusick)
- 68-72 Cutlass 2Dr Frame, AZ Original Rust Free
- NOS Rocket Emblem
- NOS and Mint 1970 Cutlass F85 W31 Grilles
- NOS Cutlass 442 Accessory Lot
- Cutlass 442 NOS New Parts Lot
- 1970 1971 Cutlass 442 Black Deluxe Steering Wheel
- NOS Delco Turn Signal Switches 1969-1972 Cutlass 442 Hurst Olds
- Repost - nos Delco points
- Vintage NOS GM Power Antenna Mast
- NOS GM Accessory Seat Belt Retractors 1960's
- 1972 Cutlass Grilles
- Olds parts-25 years! 68-72
- Sanderson Headers, powder coated *SOLD*
- 64-72 Magnaflow "Stainless" exhaust system + headers
- 15" Locking Wire hubcaps complete
- 68-72 Magnaflow stainless exhaust w/ headers
- Bucket Seat backs only
- 1965 Olds 330 CID Engine
- 394 dual exhaust manifold
- 1964-1965 Oldsmobile factory valve covers
- 69 442 parts
- 68-74 Oldsmobile cutlass or 442 wheels
- 1970 442 Grill
- FS: 1972 1973 14" Wheelcover
- Battery tubes 65-72 and G body
- 1968-1969 Cutlass 442 Convertible rear quarter top rails for interior panes
- 1969 Blue sport wheel
- Optional Vacuum Trunk Opener 1966 Oldsmobile 98
- Kilduff Lightning Rod Shifter for TH350/TH400
- Remote Control Mirror Housing 1966 Olds Cutlass 442 Vista 88 98
- Offy BB Dual Quad Tunnel Ram Manifold Sale
- Turn Signal Parts 1966 Olds Tilt Telescopic Column
- 1969 Cutlass rear bumper
- 1970 Cutlass Flat Ridge Fender
- 1965 Oldsmobile distributor # 1111042 5C 10
- 1970 1971 1972 Sport Steering Wheel New Car Take-Off Olds Cutlass W-31 442 W-30
- Trans Portable radio from 1958
- 68-72 boxed lower rear control arms and braces
- NOS V-8 Distributor Cap 1951-1955 Olds Delco D-305
- 1965-69 Olds full size left hand exhaust manifold - 384785
- Last 3 mins
- Power Trunk Lid Opener 1970 Olds Cutlass 442
- 1961 - 68 Olds F-85 Vintage Seat Covers
- Power steering pump n brackets KA pulley
- 1964 Olds Starfire vacuum trunk release
- '49-'50 Olds 98 front fenders
- '56 324 with JetAway
- Olds Lakewood blowproof manual bellhousing
- 1970 Power Steering Pump with Rounded Reservoir Tank
- 1970 Oldsmobile Cutlass Ralley 350 bumper cores
- 14x7 SSII Wheels, Set of 4 (bolt on center cap style) $25
- 1953 88 4 door
- 1965 Olds 330
- 68-72 emergency brake cable
- 70-72 parts and more
- 68 69 70 71 72 Olds 350 400 455 Power Steering Bracket Set
- NOS Delco V-8 distributor cap D308R 1971244
- In case anyone is interested...(not mine)
- NOS Delco ignition coil 1115202 1953-1963 all Oldsmobile
- NOS Delco 1119515 Voltage Regulator 1964-1972 Olds Cutlass 442
- 72 350 intake and carburetor 2bbl
- 61-63 slim Jim damper plate
- 70-72 NOS cutlass clock
- #5 and K heads
- 3 speed Hurst Indy Shifter
- 1965 Cutlass/442 Sport Coupe Seat Covers - Blue
- 1969 Cutlass/442/Hurst Olds Rear Door Panels
- Misc OEM Fasteners and Clips
- For sale Two SSIII rims 15X7 with rings and caps
- Edelbrock performer 350 intake
- 70 71 72 Cutlass 442 Door Mechanicals-Parts
- 68-69 cutlass parts for sale
- SSII 15x7 Rims
- M20 Muncie Trans
- 62 to 70 Parts
- 72 Cutlass Seat Belt Retractor Covers - RCF-401
- 70 442 rear
- Chrome valve covers
- 1970 shoulder belts - male end - 49C69 Hamill
- Batten Al Stage II, Two intakes and Batten valve covers.
- Toronado Manifolds Intake and Exhaust
- MSD 8529 Billet Distributor
- Motor mounts
- 62 Olds 88 Starter rebuilt
- 1968-69 power steering pump, brackets, 3 groove pulleys
- NOS RH outside sport mirror
- NOS 1968 cutlass/442 drivers side hood hinge
- 1970 455 Engine with brackets , exhaust intake manifolds , etc
- Gold engine paint
- Edelbrock 600 carb, like new
- 1970-72 front inner fender braces
- 1970 4 barrel air cleaner complete
- Milodon 455 Main Stud kit with Olds windage tray 81217
- 1967 330 cid 320 hp parts
- Venolia Piston/pins
- Valve Springs
- Milodon Cylinder Head Stud Kit
- Oil Pump D'shaft
- 1963 Remote Control Mirror Oldsmobile Starfire 98 88
- Olds parts
- 66 Tri-Power intake
- Oil pan
- Water pump 384783
- Edelbrock Performer 2151 Intake NIB
- 1966 Tilt-Telescopic STEERING WHEEL Oldsmobile Toronado 98
- 14 x 7 SSi and 2 sets of tires
- 70-72 Complete Cutlass/442 console
- 1969 Olds Cutlass 442 Front Fender Filler Panel & molding
- NOS Voltage Regulator '49-52 Olds
- 2 Pair '71-72 Original Front Turn Signal Lenses + 1 extra RH side
- edelbrock SP2P intake #3380
- 1967 Window Cranks ( Blue )
- Very clean unweathered Carb for sale 7040250 date 0930
- 1970-1971-1972 4 Spoke Sport Wheel w/GRAIN Cutlass W-31 442 W-30 Hurst Olds
- Manual flywheels
- 350 pistons?
- NOS Courtesy Lamp Pkg. 1960's Oldsmobile
- Two Oldsmobile key rings and three GM "key gloves" F/S
- Slightly crispy 1972 Cutlass speedometer and fuel instrument gauges free.
- 1966 Olds Cutlass 442 Vista-Cruiser Seat Belts
- 1961-63 NOS F85 throttle return
- '64-'69 442 Hurst 4 Speed Shifter - Restored/Rebuilt/Rechromed
- Olds 98 needs
- W Z exhaust manifolds for sale
- NOS N93 Center Caps 1964 Oldsmobile Starfire 98
- Holley dominator intake
- California A.I.R. 1966 1967 Oldsmobile Cutlass 442
- 64-69 four speed console top plate
- NOS Oldsmobile REAR of HOOD molding 1976 1977 Cutlass 442
- '78-88 G-Body Metal Chrome Coat Hooks
- '70-2 Under Steering Column Plastic Covers + new correct screws
- 384786 330 400 425 Water Pump with cast iron impeller
- 68-72 Cutlass 2dr frame and frame sections
- "Oldsmobile Steering Wheel Parts" - NOS - For Sale...
- 65-69 4 speed console
- 1965 cutlass reverse lights 2 sets
- 64 jetstar1 center console
- 1970 W30 Intake Manifold (Early)
- TCS Switch and bracket 455
- 1967 air cleaner
- Bare L 69 Intake Manifold 1966 3x2 TRI CARB
- 12 Bolt Oldmobile Rear
- 1967 TORONADO 425 Engine
- Hurst Lightning Rods & Console Hot Rod Olds
- 1970-1971-1972 Rally-Pac GAUGE Olds Cutlass 442
- Black seat belts, 3 mixed pairs, 68-72
- 67 cutlass f-85 post car project or parts,
- 1970-72 442, W-30 big block W & Z manifolds
- 1965 cutlass side mouldings and wheel well trim assorted pieces
- 1964 Oldsmobile cutlass hood letters
- 1970 OLDS W-30 intake
- Powertrax 8.2 Posi System
- 1966 Oldsmobile Delta 88 High Compression Air Cleaner
- 1966 Oldsmobile Delta 88 Hubcaps
- New 70-71 SX repro fender emblems
- 1972 Cutlass Supreme - Original Factory Spare Tire in Maryland
- 2-67 rally pack guage with harness
- 71 72 Cutlass 442 Set of GM Sort Mirrors--Complete Nice Setup
- 70-72 Cutlass Supreme Headliner Windlace Set-- Excellent Real GM
- 442 NOS hood pin parts
- 1956 Olds 88 Complete Front End
- 1956 Olds Rear End
- 1956 Oldsmobile Hood Hinges Chrome
- 1965 Cutlass/442 Front Bumper $700
- Bucket seat piping end caps
- Motors and parts clean out
- NOS Mallory Unilite distributor
- TH400 Kick down
- 68-70 seat belts - black
- 1966 to 1968 Dealer Literature, Fabric Books, Service Bulletins, etc.
- 70 open face alt
- 1968-69 Cutlass 442 NOS left outer wheelhouse
- 1974 Rally Pac Guage Cutlass 442 Hurst Olds
- Top Plate 1973 1974 1975 Hurst Oldsmobile Dual-Gate
- NOS cruise control modification kit
- 1965 Cutlass 442 Rear Bumper
- Convertible rear defogger
- 442 & Olds parts
- Big Block Exhaust Manifolds
- 1961 Starfire speedometer
- NOS GM Clutch/Brake Pedal Pads - later version
- NOS1966-67 Toronado lh door panel molding
- MSD Pro-Billet Distributor
- Shorty Deluxe Seat Belts - '72 General Safety
- 1973 Oldsmobile Script Valve Cover Pair
- (1) 1968 C head; (1) 1970 6 head
- 8 track wiring harness 1968-1972 Olds Cutlass 442
- 1968-69 W-30, Ram Rod, W-31 KA KB pulleys
- Rear Defroster Unit
- 1967 442 Harrison radiator
- 8 track tape player 1968-1972 Cutlass 442 Hurst Olds
- 1970 Cutlass, 442, W-30 like new wire harness
- Super Nice Restored - '71/2 Front Turn Signal Housings
- '70-72 Original Hurst Dual Gate Setup - nice restored unit
- 1964 Saginaw 3sp
- 455 main stud set W/ windage tray
- 12 bolt oldsmobile YUKON DURA GRIP POSI UNITS 28S
- 1966 Olds Cutlass 442 Trunk Lid
- 68-70 442 Cutlass 19" Factory Original Clutch Fan
- 70-72 Cutlass/442 Factory Power Trunk Lid Release - Complete
- Pennzoil oil filters
- Snap on center caps
- Wheel center caps
- 68-72 horn pads
- 1968 and up 350 and 455 manual transmission flywheel
- FS: Bucket seat piping kit
- 1967 442 Hood
- 1970 Olds Cutlass 442 BLUE survivor 8 track pad
- 1970 Olds Cutlass 442 Tape Player Rear Support and Ground Strap
- 1970 Olds Cutlass 442 8 track tape player knobs
- 1970 8 track faceplate Oldsmobile Cutlass W-31 442 W-30
