Pro Touring '72 now going LS2
#121
Thanks. It would have an Olds motor it it wasn't for criminals... I couldnt see myself paying to build another BBO when i could buy an LS for 2/3 the cost with newer technology.
#124
It wasn't a business, it was space my friend was sub-renting from someone else. It was a hobby building for him that was protected by his dog. Never had an incident before then. When the police raided they had animal control with them.
The police secured it the with what they thought was adequate means, but we found later they were supposed to call Balfour to secure the premises. There is an ongoing attempt to sue MSP and the City of Detroit, but I can't wait for a payoff that may not come....
#125
Small victory today, finally spun the motor over. I had been dealing with some small wiring issues because I used the Ford solenoid with my trunk battery placement. Once I changed and wired the LS harness to get its constant power from the alternator vs the starter, everything was good. I'm going to button up the oil cooler and finish the fuel lines. I should be ready to attempt a true fire by the next wknd....
#127
You can check this link for a conversion recently completed. The part is listed there.
http://www.pro-touring.com/threads/1...brakes-booster
If you have anymore questions feel free to hit me up.
#128
Looks like the guy i sent me ECM to did not flash it when he stripped my original harness as he said he would. Fired the car and it dies immediately. Everything I have read said it points to VATS not being disabled. After scanning I have a code P0141 which is bank 1 sensor 2 oxygen sensor. This also tells me it wasn't flashed because he was supposed to remove the after cat o2's. Not sure if I'm even going to deal with contacting him or send it to a reputable tuner that I've recently discussed a flash with.
#129
Nothing really new right now. Waiting on my ECM to return after having it checked for VATS. Was told VATS is disabled so I need to see if something is killing my run after start. I also need to check fuel pressure. In the meantime I mounted my vertical billet bulkhead and started to mock up my Vintage Air hoses. I also moved the ECM inside to clean up the engine compartment a little.
I'll be an expert at installing this evaporator when its all done...lol
#130
Got all the AC lines clocked and marked for crimping. Had to order special fittings from Cold Hose because the service fittings would not clear the inner fenders. These were known as their short drop 90 degree. Took the hoses to Pirtek on the way to work and had them crimped while I waited.
#131
Took some downtime to cut and access panel in my trunk. Its already paid dividends since i had to move fuel lines around after having fuel in the tank.
I also make a small bracket to mount my clutch master reservoir. I didn't want to bolt it to the firewall, so i found a convenient spot next to the brake booster. I'll paint it when the car is truly finished after paint.
#133
#135
Go right ahead. I got mine from Summit, bolts are not included though.
#136
Looks like I haven't been here in quite some time. So the one thing I realized is I would never really want to wire a car again...lol
I did get my Vintage Air mostly wrapped up with the wiring. I'm going to add a ground and "key on" distribution block to help some of the routing. I'm also getting an adapter plate for a Detroit Speed wiper kit i was given. The kit is for a 68, which mounted differently. A buddy from the Pro-Touring forum is making one for me to use this kit on the 72. I also fitted the DSE switch in the stock location. Since the adapter plate for the wiper switch is made for a Chevelle with side to side slide, I had to modify mine. If I could use the original **** it wouldn't be much different.
#138
It's a very nice kit. i think my issues were just because I'm mixing parts, ls2, smoothed firewall, etc... No way it was going to be a smooth install.
#139
Just switching gears a little to my seats. I finished up my Vintage Air, but I'm not ready to install my dash yet as there are a cpl more things in want to finish under there. I decided to move to getting my interior ready. I welded elevator bolts to my floor pan to use as studs for my Recaro seat brackets. My intention was to use my friends rear bench as a temporary setup until i could have my rear bucket setup installed. My intent was to use my friends old rear bench, but a '68 Chevelle rear seat is wider due to the armrest configuration. I ended up starting on my plan for the rear seats sooner than i expected. I also took the time to trim and install my rear carpet.
With some advice from by buddy that does interiors, I built this base for the new rear seat. Here is one of the rear seats as it will sit before my friend completes the upholstery. He will build filler between the seats and and both sides when he does the upholstery.
Here's the base installed with one seat is it will be when finished.
#140
Nothing major to add, just finishing up detail work.
Finally put the car back on the ground after swapping out my eBay lowers to SPC. Adjusted the ride height to where i wanted to be. Trans crossmember is about 5.5" from the ground, from what I have read this enough clearance.
Purchased my insurance and plate as motivation to push me over the finish line in the coming months.
#142
Thanks! Your Cutlass was an inspiration when you built it back then. I remember seeing it at GG Columbus when you finished.
When I ordered them in '12 Jason Rushforth thought the bronze was a great idea because no one was doing that color on muscle cars, especially without a polished lip. The craze back then was "murdered out" all black or something charcoal. The car has taken so long I'm behind the curve now.
#144
If you wait long enough trends repeat
I tried to buy mine back a year ago when it was for sale but could not come up with the funds. I'm hopping its still in his garage and on day I can "make that call"
#145
Thanks for the words of encouragement. It's been a long bumpy journey, but I can finally see light!...lol
That's what they say. Heck bell bottoms were back in style again for a little while...lol
You're buyer knows what he has, that car will be around I'm sure.
#147
#149
#152
#153
No updates here in a while.... I changed out my engine management from stock GM to Holley HP EFI. I was having couple of tuning issues that were stopping me from getting the engine to run as it should.
I also added a couple of performance upgrades because I got them for a song. Ported FAST 102. Got the intake for $500 from a guy going to a Supercharger. The TB i bought new. I sold My intake for a net cost of $300! The throttle body was necessary after my switch to DBC.
#155
Looking good. Power Tour is 9 months away. Good Guys Columbus is 10 months away. Keep the progress going. I told my dad I was disappointed in my current power output and now he is trying to get me to go LQ4.
#156
You can get those pretty cheap right now, but the mileage will be high. I personally like the LY6....
#157
I see LY6 has better flowing heads. Any other reason? I am still learning about all the engines in the LS family. I would really like to find a 5.7L just so my car can still have a 350 cubic inch motor.
#158
CNC porting my heads would cost 1k+. LY6 already has high flowing heads, so a cam swap would put you in a great spot. If I want to get supercharger the cheapest being OEM style, I would need to change my heads to the ones already on the LY6 because the charger is for rectangle port heads which the LY6 has.
Not to say that you want to build this 500hp motor, but the LY6 has a best base to start with IMO.
#159
Good to know. I think it is time to move on from the small block I have. I am debating Olds 455 or LS motor. So much potential in the modern engine and so much upside. Especially considering that my car should be an all purpose vehicle.
#160
Unless you're just dying to keep it Olds, I'd do the LS.
