Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
Go Ahead, Call Me Sacreligious
Old July 9th, 2016, 02:39 PM
Bobby455's Avatar
Is there anyone on here running an LS motor on their Olds? I know it's politically incorrect to run Chevy stuff on an Olds car, but I can't help but dream about cheap power for an Olds.
If you did an LS swap, was it really complicated? Tell me all about your LS Olds
Bobby455 is offline
Old July 9th, 2016, 02:51 PM
2blu442's Avatar
Hello Bobby455. I've moved your post to the Non-Olds Engines forum. If you have time to read through some of the posts here I believe you'll be able to connect with others who've gone the LS route with their cars.
John
2blu442 is online now
Old July 9th, 2016, 03:05 PM
Chevy budget Olds powered
coppercutlass's Avatar
Treat the car like a chvelle buy the ls install kit which has headers oil pan engine mounts etc ., and its pretty straight forward. Thse installs have been made really easy by the aftermarket. Going efi will require more elctrical work but you could run it with a carb and have a stand alone unit ecm for the ignition.
coppercutlass is offline
Old July 9th, 2016, 03:24 PM
Its been done on here, look at some of the threads in the non olds engine section.
oldcutlass is offline
Old July 11th, 2016, 08:37 AM
garys 68&72's Avatar
Should be enough to get you started here:
https://classicoldsmobile.com/forums...-iii-swap.html
garys 68&72 is offline
Old July 12th, 2016, 04:50 PM
Runner
Joffroi's Avatar
An LS swap Oldsmobile was just posted on my site for sale. There isn't to much detail about the process but its at least an example.
https://www.oldsmobilecentral.com/fo...lbuquerque.php
Joffroi is offline
Old July 13th, 2016, 06:14 AM
Bobby455's Avatar
Thanks for all the help everybody!
Bobby455 is offline
Old July 13th, 2016, 09:34 AM
72 Olds CS
RetroRanger's Avatar
I like that cutout rear bumper on that car
RetroRanger is offline
Old July 14th, 2016, 05:39 AM
jpc647's Avatar
I agree.
jpc647 is offline
76olds
July 5th, 2016 10:36 AM
61reoldsman
Body work
21
June 6th, 2013 04:58 PM
71boosted
November 8th, 2012 05:28 AM
slowolds
August 13th, 2009 12:18 PM
citcapp
November 5th, 2008 03:18 PM
Quick Reply: Go Ahead, Call Me Sacreligious
