Go Back   ClassicOldsmobile.com > Vehicle Lineup > Ninety-Eight
Forums Gallery Encyclopedia Tech Olds Junction Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Display Modes
Old 06-15-2006, 12:58 PM   #1 (permalink)
DonFrost
Member
Arrow Carb Problems
I am a decent mechanic when it comes to 90% of things. My carb is always wet and I am not sure if I should A: rebuild my carb (QudraJet, QuadraJunk, whichever you prefer) B: take it to a shop and have them rebuild it C: buy a new carb.
Keep in mind that it is controlled by the ECM and has an idle stop solinoid and all the fancy crap that the CA regulations made GM put on or however that went. It is an 81 Regency with a 307.
If your answer is A , Is it that hard to do, or is it just about keeping things organized between your kit and your torn apart carb?
If your answer is C , My question is then : Do they make a carb that will bolt on or do I need to replace the intake as well?
__________________
81 Ninety-Eight Regency 307 CA car Clean never seen salt and I'm in MN. (nuttin Special) Just in love with my Oldsmobiles. Had a 79 with the 350, liked that better.
DonFrost is offline   Reply With Quote
Old 06-15-2006, 03:33 PM   #2 (permalink)
Oldsmaniac
Senior Member
Oldsmaniac's Avatar
Find a carb shop that will rebuild then run carb on a test engine to set up emissions, throttle position etc.....It worked for me and I breezed thru NJ emission testing....All ya have to do is unbolt the carb then re-install making a note of all vacuum lines.
Oldsmaniac is offline   Reply With Quote
Old 06-15-2006, 04:05 PM   #3 (permalink)
texasred
Super Moderator
texasred's Avatar
Wet carb is usually caused by the top plate screws either loose or overtightened and warping the top plate. If the screws are not loose, try 2 top plate gaskets stacked.
I'd try that first and then Oldsmaniac's suggestion.
JMHO
C.J.
texasred is offline   Reply With Quote
Old 06-16-2006, 12:00 PM   #4 (permalink)
DonFrost
Member
What if it is leaking by the Accel Pump? Is there a diaphram needing replacement in there like on a TBI. I did one on a suburban but it is a little intimidating on a car like mine with all the extra emissions stuff to just start ripping the carb apart.
__________________
Old 06-16-2006, 05:38 PM   #5 (permalink)
texasred
Super Moderator
texasred's Avatar
True enough. Hadn't thought of the accelerator pump. It's easy to change. Nobody makes QJet rebuild kits any more, though. See if you can find an "olde tyme" auto parts store and maybe they can dust one off for you.
C.J.
Old 06-16-2006, 07:47 PM   #6 (permalink)
goodwrench1984
Junior Member
Rebuild
I have rebuilt many Quads with the mixture control (MC) solenoid and they are not that bad. I think AC delco still makes kits for them. The important thing is the lower stop and the upper stop for the mixture control solenoid. You will need a few special tools to turn them, also when adjusting them with the car running. If you decide to do the carb yourself, just make sure you count the turns from bottom on both screws when the carb is apart.
If the throttle shaft is worn excessively, then the carb should probably go to a rebuilder. If you know anyone who works at a GM dealer, some one there probably knows how to rebuild them, and can give you good advice. Good luck with it.
Chris
goodwrench1984 is offline   Reply With Quote
Old 06-18-2006, 06:33 AM   #7 (permalink)
Oldsguy
Oldsguy's Avatar
Quote:
Chris
Good point Chris. Don, he is talking about the lower most plate closest to the manifold, if the shaft is worn exessively then you have an air leak that adversely affects the carburetor operation, on old carbs they just run lean, on newer carbs with sensors on the engine it might make the carb run rich but don't quote me on that. At any rate Chris is right. If you do decide to rebuild the carb like Texasred said then I would also add that you could take LOTS of pictures to help you re-plumb all the vaccum and electrical connections when you are done. Good luck.
__________________
Dan
'46 2 door
Oldsguy is offline   Reply With Quote
Old 06-18-2006, 04:06 PM   #8 (permalink)
texasred
Super Moderator
texasred's Avatar
Theres a guy here in San Antonio named Dan Sarvis. He's an Olds man and rebuilds Q-Jets and sets them up. He's done quite a few by mail. He redid the one for my '71, rebushed the throttle shafts and drilled the throttle plates. Very good and very reasonable.
Contact him at Wblue70@aol.com
C.J.
Old 06-19-2006, 01:53 PM   #9 (permalink)
DonFrost
Member
Thanks alot people. I appreciate it all. I will let you know how it goes.
__________________
Old 07-09-2006, 09:36 AM   #10 (permalink)
DonFrost
Member
Ok all I just purchased a ReBuild/Reman Q-Jet for my ride (not here yet).
Well here is the thing (it needs it but) The carb problems I was having Dissappeared, YES DISSAPPEARED (if its spelled right) when I fixed my AIR PUMP. IF you are going to be on the road and doing day to day driving, and your car originally had the AIR system, It needs it to not run RICH. Just to let you know the the Problems all began when I busted a pulley for the AIR PUMP. I did find a replacement and put it on and it 3/4 solved my problems. My carb still leaks (thus the replacement coming). I just thought that I would fire up the old debate about AIR Pumps.
__________________
Old 07-09-2006, 03:04 PM   #11 (permalink)
Oldsguy
Oldsguy's Avatar
From what I understand, AIR pumps were added to introduce air into the exhaust which oxygenated the exhaust gases enough to enable efficient operation of the catylitic converter. Or, did I remember that wrong? At any rate, usually changing/removing something on the newer (post smogger year) cars could adversly effect the operation of the engine. I am not so sure about that AIR pump. Maybe someone else has a better line on this one.
__________________
Dan
'46 2 door
Old 07-09-2006, 06:36 PM   #12 (permalink)
Oldsmaniac
Senior Member
Oldsmaniac's Avatar
It is important to have the AIR system working....It does send air into the head at the exhaust valve outlet which is designed to help burn any unburned gas from the cylinder as it is exhausted. It also sends air thru the air pipe to the converter to help with combustion there as well....A car may run rich in the eyes of the oxygen sensor if the AIR system is not operating and give a check engine light.
Old 07-10-2006, 03:50 AM   #13 (permalink)
DonFrost
Member
My check engine light has never come on but my car was running poorly. Is there possibly a problem with my ECM. The light does come on when I start the car (like normal) and when I check the codes I get the old 1-2 blink and nothing else. Any thoughts on that?
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
1978 Oldsmobile Parts bjtstarfire Parts For Sale 1 05-26-2007 08:00 PM
Drum brake hard parts mitsudave Brakes/Hydraulic Systems 5 01-28-2007 12:25 PM
need help decoding VIN and Cowl tag for my 66 Toro DesertToro Toronado 2 01-16-2007 07:10 PM
rear-end help. Joel n Eighty-Eight 3 12-03-2006 09:48 AM
adjusting the headlights on Alero ventport Alero 6 11-05-2006 04:17 PM
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.0.0
All content Copyright © 2008 by Internet Brands, Inc.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34
