65 98 dual exhaust
65 98 dual exhaust
My parts list so far.
S-manifold, Amazon!- $149. + ship
Fel-Pro flange gasket #60241, OR, Victor#F7187
Pipe Flange- AP#8778, Walker#31857, Arvin#578463,Maremont#F25 OR, Midas#X1140
Stainless manifold studs, McMaster-Carr
Thanks! Now I understand. It may help someone else that may be looking to add dual exhausts. What did you do about the trans shift rod that is in the way? Original dual exhaust cars had one with an arch in it. You can also modify your existing straight one.
I am getting to that next, and will reply how the pre-made exhaust system I bought on e-bay works out. So far it looks as if the downpipe goes under the straight shift rod. The e-brake cable looks like it will rub the pipe, but I have to lay out the whole system to get it all aligned. The pipe kit is like a puzzle and I have not figured out how it all fits together. None of the pipes are labled which side. I am also working on the right side crossover block off.
Was very surprised to find the s-manifold at Amazon. The flange was a little harder to find. The gasket is common to the 231 Buick V-6.
I did the same thing you are doing on a '68 Delta 88 about 10 years ago using the jeg's brand 2-1/2" kit for A-bodies (Cutlass/Chevelle). It worked out really good. I welded my system together and clamped at the mufflers. I enlarged the exit holes on the S manifold and the stock passenger manifold to received bigger donut gaskets and the accompanying flanges for the 2.5 pipe.
And that's a deal on the S. I paid $200 plus back then for mine.
Finally got back to getting it done.
I agree that if you have a shop close by you that you trust a custom system is better then exhaust in a box. The system I bought was from Classic Exhaust. I would not reccomend them. I had to tweek the pipes to get it done.I also had a dissagreement with them over the length of the tailpipes, and even sent them a pic. They were about a foot short of the rear crossmember. They said the res. delete pipes were shorter. I didn't want to fight them and figure on putting custom ends anyway.
If you get one of these exhaust systems in a box, call and pay the extra ship to get the pipes full length.
Oh, if you use the starter brace bolt it to the block before bolting up the S-manifold.
All told, the cost including manifold and shipping,exh.system, clamps and universal hangers ran about 600$. I don't know how that compares to paying for a custom bend system.
My shop did it from manifold back for $480+ tax that includes capping the passenger side manifold. That's all mandrel bent. Looks and works perfectly.
Experienced exhaust shops should be able to replicate anything made by the factory.
Cap't, I would have happily paid that plus the cost of the manifold if I had someone close and the car was on the road. This was mandrel bent 2.25 pipe, at least before I tweeked on it
Oldsmaniac, it ain't on the road but I heard that 425 breathe a sigh of relief, not unlike when you eat a couple of bean buritos and have to excuse yourself from the room.
Terrible to have all those cubes bottled up like that. Sounds good with stock mufflers and no resonator.
Well thats what I thought too and this is where Classic Exhaust fell on their face. I sent them an original 66 B body (88 to be exact) resonator with the short offset tailpipe attached. They tried 3 times and gave up to reproduce that tight offset bend. The 98 has the same bend but the assembly is longer due to the longer wheelbase. I still used Classic Exhaust but sometimes they dont get things quite right and yes it was a surprixe when I got my 442 exhaust and the long head pipes were cut in half... wtf.
Hi
are there any that you can use that go straight down like the drivers side one?
for the passenger one?
i really don't want to cap it.
i have my motor out so i can see what it will hit
my cross over pipe was rusted out as well as the rest of the exhaust
i was thinking about getting that ebay kit but now ill just see if i can find a shop to do it
thanks
thanks
Hi
thanks
thanks
i just got mine yesterday from here http://www.themotorcompany.com/home.php?cat=112
they show out of stock now, contact them and see if they have any more
it looks good taking it to get powder coated today
also i decided to use the stock pass side one going to sand blast it and to see if i can find a 2 1/8 freeze plug to cap it ill shoot some pics when done
They do make caps specifically to cap off the passenger side manifold.
it was an OEM part used by the factory so it would look "correct"!
http://www.ebay.com/itm/1964-77-Olds...&soutkn=R7ivJ9
Anybody lookind for manifold? http://www.ebay.com/itm/151541282589...S:3160&vxp=mtr
#34
Also going the same route on my Delta 88. I am currently bidding on that manifold that m371961 posted
I would surely appreciate a picture of the modified linkage, I had no idea I would have to modify my column shift linkage to fit this manifold till now.
#38
I have a fixture I built in order to make those U equalizers out of a std one or two. Not much demand, so it sits unused. It holds the ends in place and the U while you weld the pieces solid. You have to get some A-body equalizers to donate the parts.
#39
They would only be used on full size Olds factory dual exhaust cars fom 1965 to 1970. They are hard to find and it would be better to have one made. You do not really need this by the way. An exhaust shop can make a pipe to fit that will not require the special linkage.
2blu442
March 7th, 2014 06:09 PM
ah64pilot
May 29th, 2012 03:04 AM
65OldsDelta88SuperRocket
October 27th, 2011 09:16 PM
dynamic88builder
January 24th, 2006 10:52 AM
