Little intro/Little business
Old May 3rd, 2014, 02:14 PM
zak0331's Avatar
Just saying hi I am located in Indiana own a '72 Supreme, in the process of getting it back into daily driver ability. Ill post pictures one day but for now my speedo went out checked the wiring and gear all is in working condition so does anyone have a 72 speedometer up for sale, I got the floor shifter not column really appreciate any input.
zak0331 is offline
Old May 3rd, 2014, 02:56 PM
Welcome to the site. Yes we do like pictures.
On your speedo, did you check the cable from the transmission?
oldcutlass is online now
Old May 3rd, 2014, 03:45 PM
zak0331's Avatar
The connections are good on the cable a bit more info I guess is that neither the needle on speedometer or the odometer mileage move at all as in i can go put 1000 miles on it right now and it still will not show a difference. Is the unit bad or is there some other underlying problem.
zak0331 is offline
Old May 3rd, 2014, 03:49 PM
72 Olds CS
RetroRanger's Avatar
The cable can snap internally, the outside sheath will show no damage. You can disconnect the cable from the trans and from the speedo and see if the inside paice has snapped.
RetroRanger is offline
Old May 3rd, 2014, 03:51 PM
zak0331's Avatar
Ok will do that Ill post more once i get to it thank you for the inputs.
zak0331 is offline
Old May 3rd, 2014, 04:12 PM
You can disconnect it from the trans and hook a drill to it. Then watch your speedometer to see if it moves.
Old May 3rd, 2014, 07:04 PM
Octania's Avatar
Cable failure is more likely. Remove the lower end and spin it while someone watches for speedo activity in the dash. Of course, if you can pull the center core right out the bottom, and it's frayed and broken, there's your problem. Plastic gear in the trans can be worn also
Octania is offline
Old May 4th, 2014, 02:45 PM
zak0331's Avatar
Thanks to all for help once I know more I will post it up.
zak0331 is offline
Old May 5th, 2014, 05:29 PM
zak0331's Avatar
Speedo works, after hooking a drill up to the cable it worked so now to the plastic gear in the transmission, which either way it was going to get changed due to going to 3.73 rear end gears
zak0331 is offline
Leadfoot
February 5th, 2014 03:58 PM
Rocketboy52
February 9th, 2011 04:02 PM
ilde
November 21st, 2010 05:39 PM
Charlie_brown
January 18th, 2010 09:29 PM
Jamesbo
April 18th, 2009 05:32 AM
Quick Reply: Little intro/Little business
