Dipsticks and headers
So I have a 71 supreme with a 455. Its had some work done to it. I have installed the larger 1 7/8 Dougs headers and now I'm having trouble with the dipstick. 1. it will be resting on a header tube and 2. getting it pressed into the hole on the block. Any ideas? Saw an earlier post were the guy isn't using a dipstick. It seems I am trying to stuff 10lbs of s*** in a 5lb bag. The entire assembly barely fits in the frame.
I had to very slightly grind a VERY small amount of metal off around the flared section of the tube to get it into my block.Its now a snug fit, but wasnt so tight that i ruined the tube getting it in. If you do the same, perhaps you can bend it slightly so its not against the header.
Installing dipstick tube with headers
I'm new to headers, but will be installing a set on my project. The headers have a continuous flange, where the exhaust manifold has a notch for the dipstick tube. Do you install the dipstick tube after the headers are installed? Thanks!
Rodney
Rodney
Yes. The real trick is pulling the tube out of the block without breaking it.
TOONLOVESCHERYL
April 7th, 2011 10:38 AM
