Engine swap
Engine swap
I have a 1983 Custom Cruiser wagon. It currently has a 307 V8. with all the smog equipment on it, it is a real dog on the freeway. Would like to install a crate 350 V8. Given the weight of this vehicle, what would be a good HP rating to target going forward?
Also, would a mid '70's Oldsmobile 455 fit into this GM B body car?
Thanks for letting me bore you to death. lol.
Slickdriver
Slickdriver
Welcome to the site... A 350 would be a good choice for the 307 replacement... The mechanics would almost be a direct bolt in... Electronics/Carburetion would be a personal choice depending on your states emissions requirements... As for the 455, it will bolt in with the same electronic/carburetion concerns, but now you would have to deal with exhaust issues as well...
Slickdriver
Slickdriver
A 350 Oldsmobile is a direct bolt-in for the 307 as it is externally identical. All accessories, brackets, and manifolds bolt up. The 455 has a taller deck height and requires minor mods.
A 350 "crate" motor is code for Chevy and requires more work. It is not a direct bolt in, but obviously the B-body chassis can accept a belly button motor.
'69CutlassVert'
August 25th, 2011 07:19 AM
