new to this
Old February 13th, 2016, 02:32 PM
86cutlass salon's Avatar
new to this
hello my name is Bryan I have a 86 cutlass salon I'm trying to buy new rims from my car and I'm trying to figure out specs for the rims if any one can help me out on this that would be very helpful 'm trying to put a 15x7 on I have 14" rims on it now
86cutlass salon is offline
Old February 13th, 2016, 02:52 PM
Welcome to the site, the 15x7's will be fine. The wider you go the more careful you need to be to prevent tire rubbing issues.
oldcutlass is online now
Old February 13th, 2016, 02:53 PM
wheel specs
trying to buy new rims for my 86 cutlass salon but i'm trying to figure out wheel specs but trying to use a 15x7 but I have a 14" rim on it now?
Old February 13th, 2016, 02:56 PM
As I said in your newbie post the 15x7 will work fine. You need to be careful as you go to the wider selections to prevent issues.
would a 15 in. x 7.0 in., 5 x 4.75 in. Bolt Circle, 3.76 in. Backspace work for it?
Old February 13th, 2016, 03:15 PM
Yes the 15x4.75 is correct, there is not much back space deviation in 7" wide wheels. It starts to be problematic when you get to the 8"+ widths.
Old February 13th, 2016, 03:16 PM
Olds Fever
CRUZN 66's Avatar
If you want to avoid any clearance issues, keep the back spacing at 4.0/4.25... This is standard for 15x7 SSIII wheels... OEM=4.0... Reproduction=4.25...
Last edited by CRUZN 66; February 17th, 2016 at 03:34 PM. Reason: Correct OEM wheel Dimension
CRUZN 66 is offline
Old February 13th, 2016, 03:31 PM
ok guys thank you for your help
Old February 14th, 2016, 08:18 AM
Originally Posted by CRUZN 66
If you want to avoid any clearance issues, keep the back spacing at 4.25/4.5... This is standard for 15x7 SSIII wheels... OEM=4.5... Reproduction=4.25...
You sure about that? Offset should be close to zero on the original wheels. That means backspace on the stock 7" wide wheels would be between 3.75 and 4.0, allowing 1/4" to 1/2" for the inboard wheel lip. Larger backspace will push the tires closer to the pinchweld on the wheel opening, potentially causing rubbing.
joe_padavano is offline
Old February 14th, 2016, 09:40 AM
Olds Fever
CRUZN 66's Avatar
Now you have me second guessing myself... IIRC those numbers came from when I measured an 84 Hurst SSIII and a Reproduction SSIII... Measurement was taken from the rear face down to the seating surface... I'll have to remeasure when I get a chance... Too damn cold out to do it right now
CRUZN 66 is offline
Old February 17th, 2016, 03:39 PM
Olds Fever
CRUZN 66's Avatar
Thanks Joe, I rechecked my wheels... I had the reproduction number correct... However, the OEM wheel is 4.0 as you stated... Just another senior moment on my part... I'll have to start writing info down as I accumulate it and not rely on my memory as much...
CRUZN 66 is offline
Old February 17th, 2016, 08:13 PM
Hookers under Hood
76olds's Avatar
Bryan, What type of rims are you planning on putting on your 86 ? I had an 86 Cutlass Supreme going back many years and had cragar SS rims all around , 15x8 225-60-15 and 14x7 on the front running 215 70 14 . I forget the offset but the rear were deep dish with no rubbing the front were regular no offset. I have many pictures of the car but didn't have a computer back then to load them up haha.
Post some pics of your car when you get a chance, we all love pics.
Eric
76olds is offline
Sickle
August 31st, 2013 08:28 AM
ah64pilot
September 19th, 2012 10:55 AM
ah64pilot
August 17th, 2012 02:36 PM
skinny
April 23rd, 2007 02:46 PM
redrumloa
March 10th, 2007 06:45 PM
Quick Reply: new to this
