| Forums | Gallery | Encyclopedia | Tech | Olds Junction | Register | All Albums | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars |
| Welcome to Classic Oldsmobile Forum! |
Welcome to Classic Oldsmobile forum, You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Classic Oldsmobile Forum today! |
Thread Tools | Display Modes |
#1 (permalink) |
My 66 Delta 88
Some updated pics of the never ending Delta 88 project.
__________________
"There are no stupid questions. There are just stupid people who ask questions" |
| Sponsored Links |
Register your account for free today or log in if already registered to remove this ad! |
#2 (permalink) |
Super Moderator
lookin good, nice clean engine compartment, you''l be done before the end before your know it, maybe.......................
__________________
Pat 1957 Super 88 with a 455 1948 2dr series 76 with a 455 |
#3 (permalink) |
Registered Abuser
Wow! If I didn't like red so much, I would so totally rip off your paint scheme. That looks fantastic. How did you get the stance and what rims/size/backspace ect. ? Damn, that looks good. |
#4 (permalink) |
Wow, great looking car! I brightened up the image a bit for ya. Gotta see that beauty in all it's glory!
#5 (permalink) |
18x7 in the front. we went with the 7 to be sure it was going to clear the fender once I lowered it. 20x8 in the back. Zero offset. Got the wheels from Coys. Could have gone 18x8 in the front with 20x8.5 in the rear, but I'll get some quality adapter/spacers to make up for it. Used cutlass springs to bring it down. I wanted to do air ride, but the budget wouldn't allow it. At least this way, I can easily put it back to stock in an afternoon if need be. thanks for the kind words.
__________________
#6 (permalink) |
Thanks. It was getting dark out when I decided that I needed some more current pictures. As soon as I finish the interior and buffing the paint I'll get my professional photographer brother to take some really nice shots of it. Right now I'm afraid he'd take some really nice photos that would capture every flaw.
__________________
#7 (permalink) | |
Landyacht Club President
Quote:
__________________
Ferris, my father loves this car more than life itself... Apparently, you don't understand! Ferris, he never drives it! He just rubs it with a diaper! Cameron Frye Ferris Bueller's Day Off 1986 |
#9 (permalink) | |
Quote:
If you want I can get some pictures of it up close & from different angles. Just let me know.
__________________
#10 (permalink) | |
Registered Abuser
Quote:
Tire brand, size? I'm trying to find the right wheel/tire combination that will fill out those giant wheel wells. I had already lopped off a coil in the front and it still sits a little high. What year cutlass springs did you use? Are they all the way around? |
#11 (permalink) |
85 Cutlass springs all the way around. Could have probably done a little more research and found something that would have put it just a tad higher in the front and a tad lower in the back. I was under the car the other day & noticed a scuff mark on the rear edge of the oil pan. Just have to be more careful on rough driveways.
__________________
#12 (permalink) |
I cheaped out on the tires because of my dwindling budget and went with Fuzions. 235/40 and 255/35. Again, could have gone bigger. I'll go ahead and burn these off and get some bigger ones if I can ever get it running right.
__________________
#13 (permalink) | |
Quote:
Man that would be great when you have time and thank you very much! Again Gorgeous looking car! |
#14 (permalink) |
Registered Abuser
I am also a huge fan of the trim removal along the bottom of the car. I was unsure how it would look if I didn't bother putting it back on after paint. It really looks cleaner. Leaving the Delta 88 emblems on is definitely more gooder. The red pin stripe sets it off well.
I'm glad you left the center trim on the good. Nothing better than getting sun glare off of that strip of chrome as you are racing down the highway. More pics pleeeeeeze!!!!! Glamor shots not needed. ![]() |
#15 (permalink) | |
Quote:
I lost my before shots. You wouldn't believe how rough this car was. Here it is midway through. Haven't taken too many photos, kind of trying to just get it done before I show it off too much. If you've seen my epic thread in the Big Blocks section, you already know that it may be a while still.
__________________
"There are no stupid questions. There are just stupid people who ask questions" Last edited by ijasond; July 22nd, 2009 at 09:07 PM.. |
#16 (permalink) | |
Quote:
Hope this helps. It was kind of tight with the camera down in there. I'll try to get some better ones next time I have it out in the light. The first one is the main bracket utilizing the 3 original mounting holes in the block. Once I had this on there, I knew I was going to be able to make it fit. The second one is C shaped bracket the I ran from the outer most bolt hole on the block around the compressor to the outer, lower front mounting hole. The third is the long straight bracket that I trimmed the end off of and ran from the block up to the lower rear mount on the compressor. The nice thing about the Sanden is that is has 8 possible mounting locations. The main bracket took care of two of them, so I figured two more on the opposite side should be sufficient. Once I had it mounted, I ran masking tape around the pulleys and marked a line, one line across both ends of the tape. Laid the tape out on the floor and measured from mark to mark. Some of the autoparts stores have the belts length listed on the website under the product description, autozone is one of them. Since apparently no one at a parts store counter knows what "longer" or "shorter" means, I surfed the site for about fifteen minutes, found a belt that was the length I needed and bingo. Perfect fit.
__________________
#17 (permalink) |
Those are just fine that gives me a good indication of what I need to do to make mine work! Thanks again those pics!!!
#18 (permalink) |
Any time. I can only hope to be able to give back a fraction of what I get from this site.
__________________
#19 (permalink) | |
Just A BaBy {:
Quote:
Holy! that's 1 hot car! you will be wining a lot at car shows {:
__________________
+1984 HURST/OLDS ![]() |
#20 (permalink) |
From what you started with and the end result is nothing short of .........."Man that is hot"!!
#21 (permalink) |
I hope you are right. That's what I'm hoping for. Even if I don't win, I still get to drive it and have the satisfaction of knowing that I did it all(or almost all) myself. And that's a good feeling.
__________________
#22 (permalink) |
Nice Ride!
#23 (permalink) |
Will them springs work on my 65' Jetstar 1 wait, I don't have springs in the back
? Any help would be great thanks. Also you think 19 x 8 w/ 245's would clear my front wheel wells? They will be chrome Iroc Rims they stick out a little wider I think.Last edited by nickd; July 24th, 2009 at 07:07 PM.. |
#24 (permalink) | |
Quote:
19x8 will fit fine as long as you get your offset right. on these cars, you generally want to stay near zero offset. Plus or minus a few mm to get it just where you want it depending on how wide your wheel is. I generally want as much offset as possible to still be able to turn without hitting the fender. Most wheels look best when they are out as even with the wheel well lip as possible. My opinion. Some cars, or at least set ups look best with 15s and 16s that might have been available when the car was originally hitting the streets for the first time.
__________________
"There are no stupid questions. There are just stupid people who ask questions" Last edited by ijasond; July 24th, 2009 at 07:18 PM.. |
#25 (permalink) |
I don't have springs in the back how would I install them?
#26 (permalink) |
What do you have?
__________________
#27 (permalink) |
65' Jetstar 1
#28 (permalink) |
Registered Abuser
I think he meant, what do you have instead of springs. I was not aware a car came without rear springs, ever. |
#29 (permalink) |
You kind of threw me with that one. Is the car just sitting with nothing to hold it up? or has someone altered it? Going to need you to be specific if you want advice.
__________________
#30 (permalink) |
Leaf springs? They don't look like leaf springs to me . What are they ?
#31 (permalink) |
Very nice car! I love the 1966 B-body lines. I have a 1966 Dynamic conv. buried in one of my buildings for 10 years. I hope I live long enough to dig it out and fix it
Something always comes up to stop me. Good luck, Ken |
#32 (permalink) |
I do have springs in the back
Would help if I got my lazy *** under there to start with. I was wondering if you think I could get away with 20 x 8.5 with a +10mm low offset (fronts 245/35/20)(rears 265/35/20). There are also 20x8 with a 0 offset (fronts 245/35/20)(rears 255/35/20). I know you said 19's would be fine up front but the 20 inch package is alot cheaper way to go. Which ones would be closer to the wheel wells? Thanks for all the helpLast edited by nickd; August 8th, 2009 at 09:02 PM.. |
#33 (permalink) |
Jason you still around?
#34 (permalink) |
Super Moderator
Car looks great. Any updated pics?
__________________
-Richard 66 Cutlass ragtop my way ![]() Keep watching your cotton candy coated TV while your world falls apart around you... |
#35 (permalink) |
I'm still here. Just haven't made any progress lately. A lot of other stuff going on. I've got the crankshaft at the machine shop, everything else checked out ok in the engine. I still don't have the pistons, hopefully soon.
__________________
#36 (permalink) |
You said go with a zero degree offset for both front and back? It looks like I'm going to have to go with 18" front and 20" backs. I don't believe they make 19" Iroc style rims.
#37 (permalink) |
I went by to check on the engine today. The crank has been fixed and she's ready to drop the pistons in. Unfortunately I'm still a little broke, so I can't spring the cash to get the pistons and balancer that I need to finish it up. I'm going to have to get creative and figure out some alternative funding sources...
__________________
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Now a 67 Delta 88 Custom AND a 66 Delta 88 coupe ... in Australia ! | Aussie67Delta88Custom | Eighty-Eight | 10 | February 22nd, 2008 05:49 AM |
| 1965 Delta 88 2 dr and '66 Delta Convrt Production Numbers | JoshF85 | Other | 1 | December 23rd, 2006 08:24 AM |
