ClassicOldsmobile.com Oldsmobile Enthusiast Community
Go Back   ClassicOldsmobile.com > Repair & Restoration > Major Builds & Projects
Forums Gallery Encyclopedia Tech Olds Junction Register All Albums FAQ Members List Calendar Search Today's Posts Mark Forums Read Used Cars
Welcome to Classic Oldsmobile Forum!
Welcome to Classic Oldsmobile forum,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Classic Oldsmobile Forum today!
Thread Tools Display Modes
Old February 17th, 2009, 03:59 AM   #1 (permalink)
wolfman98
Captain of my ship
wolfman98's Avatar
Question 69-98 covertible cleanup
Well this is taking me longer than expected but I guess that is fairly common as most of you know that a plan tends to change the more you look at it. After stripping down the motor ( more than I planned ) I got input from y'all that I might as well check the timing chain. Not an easy task as it turned out but I did check it. The roller chain and gears looked in great shape and only had 3/4 inch deflection which I was told is acceptable. the gasket seemed stuck to the block so I added some permatex ultra gold put the plate back on and also put the waterpump back on so I had all bolts to crank plate down to get a good seal. I have been stripping and refinishing parts that I have removed , though lots more to do. I took advice and removed the transmission pan to change gasket and strainer. I have the service manual so I checked everything while I had the opportunity. As some of you know I had a little accident with the underside of the hood with a wire wheel and grinder that got away and did a little dance on part of the underside. I had to strip down one section and repaint and tried to touch up some other scratches but blending is difficult with the clear on the rest of hood so I am removing back down to the paint so it will look better. I was at the doctors yesterday and had an injection of Methylprednisolone in my left shoulder. I will get the right shoulder done next monday. Hopefully it will help me to spend a little more time each day to work on the car. What is your opinion on removing the carb and changing the gasket?It does not seem to be leaking so I could just add a sealer around the bottom to make sure or just leve it alone. My only concern is that doing heavy cleaning of intake manifold up to the bottom of carb it may disturb something. Anyhow I have to get her back together and running by spring (late spring up here ) any other things can be done outdoors during the week. I plan on running it on the weekends and maybe attend some shows to see if there are others like her out there. here is the link with some new pics. http://www.flickr.com/photos/wolfman98/
wolfman98 is offline   Reply With Quote
Sponsored Links
Register your account for free today or log in if already registered to remove this ad!
Old February 20th, 2009, 11:43 AM   #2 (permalink)
jaysun
ate glue as a child
jaysun's Avatar
Glad to see your project moving along.
if it was up to me, i'd go ahead and remove the carb. and tape up the carb mounting flange tightly. That way there is little chance of getting dust or abrasives down the barrel of the carb into the engine when you clean up the manifold. also it would save you lots of time trying to mask up the carb when its time to paint.
Just remember not to overtighten the carb bolts when reinstalling the carb or it will warp it. if i remember right it's 15 ft pounds. just a little tighter than snug.
Oh as long as i'm thinking about it the valve covers and the oil pan needs a thin coat of primer before applying engine paint. otherwise it will flake off, no matter how clean it was when painted.
jason
jaysun is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
W30 4Speed Covertible Collection z11375ss 442 18 October 18th, 2008 08:35 PM
1970 covertible frame htlong Cutlass 2 August 13th, 2007 04:54 PM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.0.0
All content Copyright © 2008 by Internet Brands, Inc.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
