Sound Deadening/Insulation under dash
Old November 10th, 2015, 05:40 AM
jpc647's Avatar
Not sure if this is the right area, but when I replaced the heater core and I took out the heater box, I lost some of the insulation/carpet/sound deadening material that was up there.
It ripped, it dusty, and in pieces.
It's probably not a big deal, but what are my options to replace it? It probably does almost nothing, nut without removing everything, dynamat doesn't really seem like an option. Do they sell the material?
jpc647 is offline
Old November 10th, 2015, 11:15 AM
steverw's Avatar
In my 67 the rubber backed insulation for the firewall IS the seal for the heater/ac box inside the car. These are available for all A bodys im sure. If you only want to patch it im not sure what to tell you. If its all gone from around the heater box you could probably get some sticky back foam seal tape from Lowes or Home Depot
steverw is offline
Old November 10th, 2015, 11:46 AM
RandyS's Avatar
I'd bet it's all deteriorated like it was in my 66. The repop's are fairly inexpensive. You will need to remove anything screwed or bolted to the firewall to replace it.......
RandyS is offline
Old November 12th, 2015, 06:42 AM
jpc647's Avatar
After what I just went through for the heater core, I'll sell the car, or total it before I take it apart that far again.
Thanks for the warning!
jpc647 is offline
Pewter442
March 15th, 2015 04:14 PM
thewoff
August 14th, 2014 04:37 PM
61reoldsman
August 2nd, 2012 06:58 PM
spider
August 27th, 2011 07:30 AM
dingusboy
May 13th, 2009 12:58 PM
Quick Reply: Sound Deadening/Insulation under dash
