Quarter window channel gasket
Old October 6th, 2015, 05:10 PM
malibru's Avatar
Does anyone know where I can source the rear quarter window glass run channel? The factory looks like it has a metal backing to it, and mine is all bent up. On my front doors the replacement material was just rubber/felt and installed easily into door frame window channel.
I'm not even sure what the correct name is for the material other than "window channel run"...
Thanks all.
malibru is offline
Old October 6th, 2015, 06:20 PM
oldspackrat's Avatar
Can you get a picture of what you're talking about? Some of us on here may have good ones for you.
oldspackrat is offline
Old October 7th, 2015, 08:32 AM
therobski's Avatar
x2, I replaced mine on my 64-post car build.
therobski is offline
Old October 8th, 2015, 05:44 AM
malibru's Avatar
Here's what I'm talking about....
malibru is offline
Old October 8th, 2015, 05:46 AM
malibru's Avatar
Therobski did you just use window channel run in these rear quarters?
malibru is offline
Old October 8th, 2015, 09:03 AM
therobski's Avatar
Call Restoration Specialties 814-467-9842 I ordered 5V-72-WIN. That's what I used in number 11 in the attached picture. Ask for those clips I traced in red X410-WIN.
Old October 9th, 2015, 05:57 PM
malibru's Avatar
Hey TheRobski thanks! That seems to be the stuff I'm looking for. I assume, looking at my old material, that I will have to drill small holes to mount the clips into, and bend that channel to fit the curves etc. But this looks to be the right stuff.
In measuring the vertical piece, closest to the front door and in the "post", it seems to be a bit wider there. Maybe I will also order some of the channel that is 5/8" across and test to see what works the best.
Thanks again!
malibru is offline
Old October 10th, 2015, 06:48 AM
therobski's Avatar
What I did because I did not what I was doing I sent the vertical pieces to them and they basically rebuilt them for 420.00 a piece. #11 the C channel-I drilled out the tiny rivets and the new material is rigid but bends, I used 3-M weather strip adhesive and glued them together using small clamps and let it set up over night. As far as installing the C section into the quarter channel I had trouble getting the replacement fasteners to pop into place-the ones in the picture traced in red so I glued those in and used various clamps etc to hold them in place to set up. Not real happy with the result pass. side came loose in the corner. If you can figure out something else let me know. There's not a lot of info regarding this part of a restoration especially on a "post car"
Old October 10th, 2015, 06:49 AM
therobski's Avatar
WOW not enough coffee this am 20.00 apiece!!!
Old October 10th, 2015, 12:36 PM
You can always go back to a post you made and 'Edit' it if you need to change it. That little "EDIT" button on the bottom of the post will only appear for posts you have made. Makes it a lot easier. Plus you can put the reason for editing so others will know what to look for.
Coffee is a good thing. early in the morning isn't.
Allan R is offline
Old October 10th, 2015, 01:10 PM
malibru's Avatar
Wow! $420....not so good. $20.....much better! I am on coffee #2 today with 11 more hours of work to go. No time to work on the car today.
Rob I looked at your old threads on the build and all I can say is that I am impressed. Looks like you are doing a fine job. On my car it has been six years of ownership, and still she is far from running. But it's a labor of love(hate?). I am certainly not restoring my car, but building it the way I want and re-purposing and re-using what I can. I just cannot afford to buy every new repro or NOS part that is out there. So I pick and choose. In this case the window felts are original to the car and basically fell apart in my hands like some of the plastic interior trim.
I will order some items and when I find time to work on it, I'll take photos and let you know how and what I did. Thanks again, and that is one sweet ride you have!
malibru is offline
jensenracing77
March 2nd, 2014 08:55 AM
oldspackrat
January 20th, 2014 05:17 PM
tcarroll
August 1st, 2013 08:14 AM
Oldssupreme
February 20th, 2013 09:59 AM
70vistacruiser
February 17th, 2005 03:00 AM
Quick Reply: Quarter window channel gasket
