Replace antenna base on 66 442
Old June 22nd, 2015, 11:55 AM
Chuck_66's Avatar
I need to install a new antenna base and mast on my 66 442. It looks like I need to remove the cowl or maybe the inner wheel well I am not sure. Please let me know how to install this it would be greatly appreciated.
Chuck_66 is offline
Old June 22nd, 2015, 12:03 PM
RandyS's Avatar
You need to remove the wiper arms and the wiper panel. You can then access the base of the antenna mount. Unscrew the black **** to remove the mast.
RandyS is offline
Old June 22nd, 2015, 12:20 PM
Many moons ago when I changed antennas I loosened the mast nut and the braket under the fender swung around and the antenna pulled up through the hole. I would cut the old coax and strip back the wires and wrap the new plug with them and tape it. Then I would pull the old coax from the passenger compartment to guide the new cable though. Then remove the tape and the old wire and connect it to the radio.
oldcutlass is online now
Old June 22nd, 2015, 05:46 PM
Chuck_66's Avatar
Thanks Randy and Eric for the fast reply.
Randy how do I remove the wiper panel are the screws hidden by the windshield chrome?
Chuck_66 is offline
Old June 22nd, 2015, 07:22 PM
Chuck_66's Avatar
Randy I found it in the assembly manual 1.4.2. Just the 5 small bolts I thought there was another 5 bolts on the other side. Thanks again that looks easy enough.
Chuck_66 is offline
curtis mayfield
February 21st, 2023 07:13 AM
fennjones
February 2nd, 2015 05:59 PM
442mark
September 14th, 2013 03:27 AM
442mark
April 15th, 2013 05:44 PM
scr8p
July 13th, 2011 08:38 PM
Quick Reply: Replace antenna base on 66 442
