installing headliner today.
Old February 15th, 2015, 02:25 PM
biggus's Avatar
Installing the headliner in my 68 Cutlass today and it's not going to bad. Have it fit and the clips all around it holding it in. It seems to have a lot of wrinkles. Will a heat gun or blow dryer tighten these up. I know I have read that they all tighten up but how much? Kinda wondering if mine needs to be tighter before I start gluing it in
Thanks...
biggus is offline
Old February 15th, 2015, 04:03 PM
This thread over on Chevelles.com seems pretty definitive to me.
I haven't done this myself yet, but I did bookmark this thread for whenever I do.
MDchanic is offline
Old February 15th, 2015, 05:10 PM
Frank Ignachuck
ignachuck's Avatar
If it's cloth, spray a little water on the area and it will gradually tighten up. Humid weather will also help over time.
ignachuck is online now
Old February 15th, 2015, 05:14 PM
Run to Rund's Avatar
Mostly, you have to get it tight on installation, or the wrinkles will stay. I struggled with a couple of them that weren't cut tight enough on mfg. between the passages for the wires, and there was no way to get them tight enough.
Run to Rund is offline
Old February 15th, 2015, 06:31 PM
Gary
Gary's 2 442-S's Avatar
X2 on this. I used this tutorial when I did mine. You are basically going to have to pull the headliner tight to get the wrinkles out. It much easier to do with the glass out.
Gary's 2 442-S is offline
Old February 15th, 2015, 06:50 PM
1968_Post's Avatar
Thanks for the link Eric. I'll be doing this in the spring after it warms up.
1968_Post is offline
Old February 15th, 2015, 07:38 PM
biggus's Avatar
Thanks guys. Yea my windshield is out, making it a lot easier in the front. Don't want to take my rear window out but..... I just thought I seen something about heat guns or steaming or something. Guess I'm just gonna have to fight with it.
biggus is offline
Old February 16th, 2015, 05:45 AM
Rocketbrian's Avatar
Good timing on this thread, as I'll be doing the same soon. My windows are still out, so I'll get a push on this as soon as my order from Legendary arrives.
Rocketbrian is offline
Old February 16th, 2015, 06:51 AM
garys 68&72's Avatar
If you're in a warm climate, let it heat cycle a couple days. If wrinkles are there, they'll be staying.
I wouldn't recommend a heat gun, some synthetics don't respond very well to heat and it can be easy to over heat it. No way to fix after that.
garys 68&72 is offline
Wil Lopez
January 16th, 2008 05:24 AM
59-59-59
Brakes/Hydraulic Systems
September 4th, 2007 10:16 AM
shaks 442 clone
July 18th, 2007 05:03 AM
shaunr
January 19th, 2007 12:54 PM
n9ljx
Alero
August 14th, 2006 06:24 PM
Quick Reply: installing headliner today.
