How to remove back seats...? (1969 Cutlass Supreme)
Old December 29th, 2014, 02:30 AM
Christophe2m6's Avatar
How to remove plastic seat backs...? (1969 Cutlass Supreme)
Hi guys!
Tried to remove the plastic seat backs on my 69 Cutlass supreme.
Removed the 3 screws under the plastic panel, but can't remove the release button... And the plastic Seat backs.
Any tips?
Thanks a lot!!
Christophe2m6 is offline
Old December 29th, 2014, 03:53 AM
Christophe, I cannot answer your question from memory, but I looked at it for a while before I realized what you meant:
Because of the differences in languages, what you mean to ask is "How do I remove the plastic seat-backs from the bucket seats?"
Adjectival word order between English and French can be tough, since both have rules, but neither language actually follows them.
In English, "back seat" can really only mean the place where you take your girlfriend when you go to watch the submarine races.
MDchanic is offline
Old December 29th, 2014, 04:30 AM
Thanks a lot for your help and answer Eric!!
Yes, indeed, I meant the plastic seat backs!!
(Change words order in the thread and title)
Any help will be welcome!
Old December 29th, 2014, 08:07 PM
2blu442's Avatar
OK, its been a few years but let me take a stab at this. You've removed the screws on the bottom, the ones you can see when you tip the seat back forward, correct? Being a 1969 the release button should be in the center of the back, kind of a squarish button. Take a couple putty knives and wrap a layer of tape over them to keep from scratching the plastic. Then slide them under the edge of the release button on opposite sides. The button clips in, so you'll need to gently pry/pull it straight out. The edge is actually chrome plated plastic, so if your too rough it will crack or break the area surrounding the button. Once the button is out then slide the seat back up a little and it will come off.
John
2blu442 is online now
Old December 30th, 2014, 02:25 PM
Thanks a lot John for your detailed and helpful answer!!
It worked perfectly!
(Behind the chrome release button, there are 2 last screws, then it comes off perfectly!)
Thanks!!
Old December 31st, 2014, 05:56 PM
Glad you got it. Christophe! John's the greatest.
MDchanic is offline
srbz
April 10th, 2015 06:53 PM
olds70supreme
August 1st, 2011 05:22 PM
1983oldsmobiledelta
September 23rd, 2010 06:50 PM
KRICHEN922
July 1st, 2010 09:17 AM
Mason
July 21st, 2009 06:56 AM
Quick Reply: How to remove back seats...? (1969 Cutlass Supreme)
