Removing rear seat from 54 - what's the trick?
Old December 2nd, 2014, 04:30 AM
rctoyguy's Avatar
Starting the interior redo on my 54 Super 88. What is the trick to pulling the rear seat? I've looked, but only briefly, and it doesn't *appear* that it will shift back at all... I figured the bottom would shift back a little then lift up - but maybe not..
rctoyguy is offline
Old December 2nd, 2014, 04:52 AM
Bfg
Bfg's Avatar
Rear seat
I think there are some bolts that need to be removed from the trunk area?
Bfg is offline
Old December 2nd, 2014, 06:36 AM
Collector of Stray 55's
Olds Dad's Avatar
The lower portion needs to be lifted up from the front - there are two squarish cups in the floorboard that the seat frame sits in - if there is a lot of rust these could be frozen up. There are no bolts.
Once the lower portion is removed you'll see brackets in the lower corners of the upper half that set into the rear wheel arch on the inside - there are two tabs that are part of the floors that are bent over the brackets to secure them in place - again, if there is a lot of rust these might be gone. Once you bend those tabs loose the upper portion should slide upwards and out - it sort of just 'hangs' on the lip of the rear package shelf.
Hope this helps.
Olds Dad is offline
Old October 24th, 2015, 04:25 PM
ElmoIsBold's Avatar
BEND the tabs? Really?
All righty, then! Here goes!
ElmoIsBold is offline
Old October 24th, 2015, 05:00 PM
Rocketowner's Avatar
On my '55 you push the lower cushion back(by applying pressure to the bottom area nearest to the carpet) . As it moves back pull upward.It should come out. Larry
Rocketowner is offline
Old October 24th, 2015, 05:25 PM
Proud Viet Nam Veteran
redoldsman's Avatar
Larry, that is how the one in my 54 convertible comes out. Seems I had to do both sides separately.
redoldsman is online now
Old October 25th, 2015, 07:22 AM
ElmoIsBold's Avatar
(Rear) seat back came out without event, once I figured out that it DROPS after the tabs are bent down.
The metal strip that trims between the package tray and the top of the seat back looked awful. I didn't even know what was on it until the lower parts were exposed. It was apparently wrapped in red upholstery cloth at one time. It had turned black and decomposed.
New package tray in place. Cleaning up the metal trim strip: sand, acid etch the rust (glue?) off, rinse, repeat, prime, paint (leave it un-upholstered), vacuum, and put everything back. It'll look better than it did even when I was a boy going places in the back seat behind my Dad.
Thanks for the "bend" clue, Gordon.
Keith
Old April 9th, 2016, 01:24 PM
Fitti Fi's Avatar
Keith
Where did you find your package tray?
Fitti Fi is offline
Old April 10th, 2016, 07:02 AM
ElmoIsBold's Avatar
Fusick sells it.
Jandk
July 4th, 2015 11:45 PM
tmaleck
Drivetrain/Differentials
October 12th, 2013 07:58 AM
chip-powell
August 2nd, 2013 06:45 AM
Klayfish
June 17th, 2011 08:29 PM
richeyb
June 27th, 2010 06:57 PM
Quick Reply: Removing rear seat from 54 - what's the trick?
