1968 cutlass Trim
1968 cutlass Trim
anyone have any leads to where i can purchase a full weather stripping & trim package for a 68 convertible cutlass S?
also can you find the chrome trim package in black? or would i have to buy the chrome ones then powder coat them??
Look up the Fusick catalog at www.fusick.com. I believe you will find all the weatherstrip kits you need for your car as I did for my '68 4-4-2 convertible (same body as yours). The roof rail weatherstrip (7 pieces) is part number RR682. The windshield pillar weatherstrip is part number WP680. The door weatherstrip is part number DW68. The vent window weatherstrip part number is VR680A. The vertical vent window channel part number is C909-680. The window channel kit is part number CK68A. The quarter window vertical weatherstrip is part number QW8485. If you need the quarter window chrome sash channel, it is part number SC682L for the driver side and SC682R for the passenger side. The body pillar sealing strip is part number BP5455.
Fusick is a great place to look for other things that you need.
All of the trim pieces are either chrome or stainless/flash chromed. You would have to take further steps to make it black.
Hope this helps.
Randy C.
Hope this helps.
Randy C.
You can also look on ebay for a company call tamraz. I believe they make the parts fusick sells. The complete 69-72 Buick Oldsmobile Body Weatherstrip Seal Kit Convertible is available for quite less and has more parts than the one offered by fusick. I used and installed it on my 69 convertible, it is fine, you have to play a little with some parts but it turned out very well.
c294mpd
February 14th, 2016 04:18 PM
oldspackrat
April 4th, 2014 09:39 PM
Oldssupreme
May 28th, 2013 05:35 PM
orthoK
May 16th, 2011 10:10 PM
allwood2006
November 12th, 2009 11:52 AM
