Water Shields Install
Old April 15th, 2014, 03:31 PM
scott_442's Avatar
What's the best thing to use to re-install the water shields between the doors and the door panels? Factory used something that looks like black silly putty and is still somewhat pliable (but not sticky) after all these years. Is there a special removable type silicon that could be used? Thanks.
scott_442 is offline
Old April 15th, 2014, 03:36 PM
mrolds69's Avatar
No...don't use silicone, you won't be able to remove them again w/o destroying them Use 3M strip caulk, or I think it's called Mortile weatherstripping, you can get it from Home depot. It's not black, but doesn't harden. A few pieces of duct tape to hold the top and MAKE SURE you tuck the bottom in the slot or your door panels may get wet.
mrolds69 is offline
Old April 15th, 2014, 03:38 PM
nicks1966's Avatar
I like to use 3m strip calk
051135-08578 is the number I use.
nicks1966 is offline
Old April 15th, 2014, 05:09 PM
scott_442's Avatar
Great info! Thanks.
Old April 16th, 2014, 07:45 AM
Tom442's Avatar
Best material to use?
THREAD HIJACK!
Tyvek? Something else? What have you guys used?
Tom
68 442
70 F85
Tom442 is offline
Topless72
March 26th, 2011 01:55 AM
ddx77
April 29th, 2010 12:20 AM
19Starfire62
June 18th, 2009 08:24 PM
wolfman98
May 30th, 2009 05:02 AM
wolfman98
May 29th, 2009 02:17 PM
Quick Reply: Water Shields Install
