Q-Bond Plastic Repair
Has anyone tried this stuff? I used some to repair a couple center consoles and it worked great. I have not repaired any metal with it yet but it has the metal repair included.
[QUOTE=501Paratrooper;542546]Has anyone tried this stuff? I used some to repair a couple center consoles and it worked great. I have not repaired any metal with it yet but it has the metal repair included.
https://classicoldsmobile.com/forums...-repaired.html
See my comments from the previous post, this is good stuff!!
I've tried on a console so far. The repair seems very strong.
I put masking tape underneath as per directions and then filled with powder a little at a time and glue, I repeated this until it was slightly above level and then sanded a bit. I drilled new holes yesterday and it did not seem brittle at all.
I repaired the mounting posts on a 67 dash plastic where they had broken from the original positions. This claims to bond molecularly and I believe it. That plastic is usually very hard to bond back together but Tech-Bond worked great. Where there were pieces missing, I used some clear acrylic and shaved it into a large particle dust for filler and built up the missing areas. Drilled the repair to the correct size and threaded the metal posts into it. Made a very high strength repair.
oldfarmall
January 7th, 2011 11:08 AM
