Speedometer Cable for 67 Oldsmobile Delmont
hi guys
i have a problem for the speedometer cable,I bought this that was suitable for my car, but no good, is short and more like a nut in the photo, but my old one is longer and has no dice, it has only part of the tachometer.
where can I find? you tell me why is it different?
thanks
thanks
and first I put no good.
I had only one hand and out of the wheel and has done so.
I think its a problem now
Where did you order the bad one from???
hi guys
thanks
thanks
Rockauto.com only has the upper cable for vehicles with cruise control. This is not an easy cable to find. When you are searching make sure you look for one WITHOUT cruise control.
If you still have the original cable why not see if someone in Italy or close by can copy or repair it.
I took the cable from rockauto that I knew was wrong but I took the attack to retrieve the tachometer and the pin because I lacked in Italy theres the problem of fillets and the sheath that we have here is too small.
I realized that it was difficult to find with this car are now accustomed.
Thanks to all
are very stubborn and today I made the commitment and the cable I started to play, recovering from the nut to rock, I did the photos and when it is over you'll show.
I apologize if my English is not the best.
I've seen, and may still have one of these cables that have rubbed on something like the steering componets. They wind up with a section of housing abraided with no insulation on it. Is this what happened to yours? I'm not sure I can lay my hands on it but can try to find it next weekend if that would help. John
hate to bump this ancient thread but im in search of a new spindle type speedo cable for my 67 olds 98. Jaybird do you still have one or know who would. maybe you can point me in the right direction on where to find one.
This one is for 67 Olds Delta 88 with Cruise: http://www.ebay.com/itm/NOS-STEWART-...3eb611&vxp=mtr
This one is supposed to fit 66-70 Olds Toro - slightly longer: http://www.ebay.com/itm/66-67-68-69-...e24790&vxp=mtr
Here's one that's 61" long for Olds 1958 - 68 non cruise: http://www.ebay.com/itm/1958-68-GM-C...b84303&vxp=mtr
57" http://www.ebay.com/itm/1958-68-GM-C...1f4cc7&vxp=mtr
I found all these and more on eBay using the search words 1967 oldsmobile speedometer cables
Don't know if that helps.
yep. when I first looked for them I went to summit and rockauto and found ones that said they would fit my car for less than 10$ I thought it was going to be an easy fix. That's before I noticed they were the transmission type, different from mine.
I've been looking for a source for the cable this guy needs for a long time. So far the only one i've seen is on Ebay for 150 bucks. If your cable just has the insulation rubbed off count yourself lucky - install a new inner cable and wrap the thing in duct tape to keep the moisture out, because you're going to pay a lot of money for a new cable if you ever find one. Unlike yours my cable was kinked when I removed my engine and now is useless as it breaks every inner cable I install. These were specific to big cars in 1965 also and no online parts store has them. NOS or from a dead car only...best of luck sir!
Speedometer Cable
I went through my stuff and found a used cable for my 1967 Delta 88. The total length is 72 inches.
I don't know if it would be any use to someone or not.
There is a new cable listed on eBay right now. If you need one, jump on it right now before it's gone!
http://www.ebay.ca/itm/1963-64-65-66...p=mtr#payCntId
Below is two pictures of my used cable.
