ClassicOldsmobile.com Oldsmobile Enthusiast Community
Go Back   ClassicOldsmobile.com > Repair & Restoration > Electrical, Interior, and Other > Interior/Upholstery
Forums Gallery Encyclopedia Tech Olds Junction Register All Albums FAQ Members List Calendar Search Today's Posts Mark Forums Read Used Cars
Welcome to Classic Oldsmobile Forum!
Welcome to Classic Oldsmobile forum,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Classic Oldsmobile Forum today!
Thread Tools Display Modes
Old October 12th, 2009, 03:19 PM   #1 (permalink)
smokinjos
Steering Column Woes
I'm having an unbelievable hard time removing my ignition lock cylinder from my 71 Supreme convertible.I've depressed the release inside the column, but just can't get the damn thing out. Anyone with similar problem? Might have to buy a new column. Anyone know where to get one besides Year One?
smokinjos is offline   Reply With Quote
Sponsored Links
Register your account for free today or log in if already registered to remove this ad!
Old October 12th, 2009, 03:40 PM   #2 (permalink)
My442
You need a service manual to properly disassemble the column.
Lots of small parts, and a definate method to do it.
Otherwise, you are in for some disappointments.
My442 is offline   Reply With Quote
Old October 12th, 2009, 03:46 PM   #3 (permalink)
70 cutlass s
Do you have the key in it and have turned to the Run position. It won't come out unless you do.
70 cutlass s is offline   Reply With Quote
Old October 12th, 2009, 04:09 PM   #4 (permalink)
Bluevista
Cruisin' the Vistas
Bluevista's Avatar
This link has some info.
http://www.buickperformance.com/tilt...lumnwobble.htm
The tang in the slot is being pressed in fully? You have to rotate it counterclockwise to install it and seat the tang so maybe you have to turn it before pulling up?
Bluevista is offline   Reply With Quote
Old October 12th, 2009, 07:20 PM   #5 (permalink)
66400
Quote:
Not true for 69 and newer. Henry
66400 is offline   Reply With Quote
Old October 12th, 2009, 07:25 PM   #6 (permalink)
66400
Quote:
Get a replacement lock cylinder at most any local parts store. They were used on most GM cars 69-77. Once you have the replacment look at it to help visualize the removal of your olds one. Also a good spray of wd40 or some such product will help.
Henry
Old October 12th, 2009, 08:11 PM   #7 (permalink)
joe_padavano
Super Moderator
The lock cylinder can be removed without the key. I have had problems with the spring loaded tab hanging up and not fully depressing. Try pushing in on the lock cylinder, then depressing the tab fully, THEN pulling the lock cylinder outward.
__________________
Joe Padavano
64 Jetstar 88 Conv
66 442 L-69 Conv
68 W-30
69 H/O
69 442
70 W-30
72 442
84 Custom Cruiser
86 Caprice wagon (w/307 Olds)
joe_padavano is offline   Reply With Quote
Old October 13th, 2009, 07:29 AM   #8 (permalink)
70 cutlass s
Quote:
Yeah that's right I was thinking about a newer style one. I haven't changed a 69-77 in 20 years. Just newer ones so I forgot. Thanks for giving him the correct advise.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
1970 steering column? stevengerard Electrical 4 September 3rd, 2009 12:30 AM
Steering column adjustment? vista461 Chassis/Body/Frame 2 August 4th, 2009 03:50 PM
Steering Column, 56 olds rket56 Eighty-Eight 10 October 31st, 2007 06:02 PM
69 Cutlass steering column kandrgto Parts Wanted 0 June 28th, 2006 01:43 PM
Steering Column souldoubt1 Chassis/Body/Frame 1 November 6th, 2005 11:22 PM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.0.0
All content Copyright © 2008 by Internet Brands, Inc.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
