| Forums | Gallery | Encyclopedia | Tech | Olds Junction | Register | All Albums | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars |
| Welcome to Classic Oldsmobile Forum! |
Welcome to Classic Oldsmobile forum, You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Classic Oldsmobile Forum today! |
Thread Tools | Display Modes |
#1 (permalink) |
Under dash insulation
There is insulation material packed under the dash which has become dry, crumbly and messy. Any time that I reach under to work on the wiring, the stuff rains down in pieces. Is this stuff necessary? Can it be removed from underneath and replaced? Does someone make a replacement insulation? It's not on the firewall, its directly under the dash.
| Sponsored Links |
Register your account for free today or log in if already registered to remove this ad! |
#2 (permalink) |
I have seen it made for some cars but not others. The major suppliers (Fusick, OPG, Legendary) will have it if it is made for your car.
If not, you can use the self-adhesive foam dynaliner (or other brand) insulation and make your own. HAMM36 on this forum did that. If the dash is disassembled, then replacement is pretty easy. Since I did not pull my dash all apart, I left that nasty stuff there, which may not have been the best idea.......
__________________
-Rob Young 1972 Cutlass Supreme Convertible (442 clone) -"Lady" (My mistress...) http://www.flickr.com/photos/robsalbum/sets/ 1986 Cutlass Supreme Coupe - "Pristine" 1978 Ford (Old Faithful) a.k.a. "the Tramp" 1997 Cadillac STS (for sale - too many cars!) 1999 Harley Davidson Sportster - "the Freedom Machine" |
#3 (permalink) |
Thanks Rob. I also hope to not have to take apart the dash. If I just dug all that crud out of there, would that cause any problems? Does it really need to be replaced?
#4 (permalink) |
No real issue in removing it, aside from the mess. Hold a shop vac hose under it as you peel it away to help capture the dust.
The purpose was to help insulate for temperature and noise. Since it was so delapitated (sp?) anyway you probably will not notice much (if any) difference in heat or noise gain. When you do ever redo the dash, you can add some new.
__________________
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 67 dash | Giftman23 | Parts For Sale | 1 | March 8th, 2009 06:51 AM |
| engine hood insulation | d4rksabre | Eighty-Eight | 7 | September 2nd, 2007 08:46 PM |
| 1961 dynamic carpet and insulation | eightyeight394 | Interior/Upholstery | 5 | August 29th, 2007 12:22 PM |
| Removing dash and dash pad in 70 cut conv. | DJMatthews | Interior/Upholstery | 9 | December 12th, 2006 07:36 AM |
| Need Dash Help | slimchef24 | Interior/Upholstery | 2 | July 16th, 2006 07:48 AM |
