Dash pad install
Old March 24th, 2017, 05:46 PM
jennzdad's Avatar
Dash pad install
The dash pad on my 70 Cutlass Supreme has a 3/4" gap on the drivers side between the front of the pad and the metal dash. How can I close that gap?
jennzdad is offline
Old March 24th, 2017, 07:04 PM
steverw's Avatar
Is anything damaged? Got pictures? An original dash pad should go on no problem. Be sure theres not a mounting stud jammed up just off its corresponding hole. Got pictures?
steverw is offline
Old March 27th, 2017, 12:55 PM
oddball's Avatar
Two screws go through the plastic dash between the gauges (and behind the gauge dress plate) into the metal dash to retain the assembly up against the metal dash.
Then there's the one stud in the upper corner that just has a pinch retainer in the metal dash - no speed nut.
oddball is offline
rr1964purple
May 9th, 2022 12:53 PM
AJFink
December 1st, 2015 07:19 AM
Bryan59EC
June 3rd, 2010 10:36 AM
floater98
May 27th, 2010 03:45 AM
DJMatthews
December 12th, 2006 06:36 AM
Quick Reply: Dash pad install
