Rear seat bottom ?
Rear seat bottom ?
Somewhere in my cars" past a gorilla fubared the seat frame where it fits into the floor hooks. Am I correct that with no upholstery or the upper section in place, the lower should just drop in and slide forward to grab the hooks? In other words, is the lower just held in the hooks by the tension against it from the upper back?
Typically, to get the lower rear cushion in or out, you've got to push hard on the bottom of each side, toward the back of the car, and then it snaps back forward when it's in or out of the clips.
I don't know how it behaves without upholstery or the upper cushion in place.
It needs enough pressure, at a low enough point (on the frame, at the very bottom), that it's hard to do it with the front seat in place without hurting your back.
Thanks. Time to fire up the torch and reshape the seat frame parts that align with the floor hooks. One was bent forward so bad it would not reach the hooks, and both are bent too high to reach low enough, as the frame bottoms out on the floor with the frame hooks above the floor hooks. The previous owner even flattened two of the four floor hooks down on floor. Would have been interesting to watch and hear the guy when he removed and then was re-installing it. I may have heard some new curse words. (but I doubt it, I know most of the good ones)
Ddbord
August 4th, 2011 11:05 AM
ctrain22
August 15th, 2010 08:46 PM
