1968 442 door lock problem
1968 442 passenger door problem - When unlocked door opens fine from either handle and door lock rod thru top of door or key lock locks and unlocks door easily. However when door is locked and you use any handle, the lever that usually rests against the Door Handle rod moves away from rod about an inch or so and door can't be opened nor unlocked until I manually move the lever back toward the Door Handle rod. Is there a spring missing? This can't be normal is it?
Answer is - REPLACE Lock Mechanisiam > Which is what happened.
Last edited by Elkstone; October 18th, 2016 at 03:34 PM. Reason: clarification and solution
goldie442
August 21st, 2015 11:01 AM
